Thread Tools | Search this Thread | Display Modes |
#1 | ||
mpg friendly mods
#2 |
It depends on how deep you want to dig into your pockets.
![]() Free: tone ring mod modified stock air box (I would reference the "cool tube" design. [I have mine with a large hole in the bottom & during winter here in WI I've gotten some water into the intake. I only knew since there was dried salt marks by the silencer ring.) cheap: Rokktech sensor TRM & Rokktech both advance timing about 2* Anything that you do to make the engine breath better: Cold air intake aftermarket intercooler high flowing intake horn port & polished heads matching low HP injectors (~50hp range) cam (you'll need new springs) exhaust manifold turbo (will help with right amount of fuel, correctly size for application & free flowing intake & exhaust) free flowing exhaust Since you have an auto trans, a different torque converter & valve body will get more power to the ground. Plus don't forget about synthetic fluids for everything. Then there are the chips & programs. That's a personal preference. I went with Quad because of their EXCELLENT customer service. Just for reference, with my mods I get 18-19 mpg city/suburbs & 23.x mpg all Hwy at 70-75mph. I'm currently saving for my 48re before I would get a turbo & cam. That's probly where I'll stop (maybe )Just remember parts work together in combination. You need the right combinations to everything properly. (fuel, injection pressure, valve timing, injection timing, cool air flow, etc.) I always look for the bigs bang for my buck & start from there. A good article to read is from Diesel power magazine, August 2007. If I remember corrently it was '97 1ton that they were able to get 30.x mpg at 60mph with some very cheap mods. Not that I would recommend blocking your air flow to the radiator. But you can see some of the easy stuff that can be done. lowering these bricks that we drive & do aerodynamic mods will greatly improve your mileage without doing anything to the engine. If you really want the best bang for the buck you could try diesel blending or bio-diesel. Just pour in & go & alot less cost per gallon ![]() Good luck & have fun.
__________________
2005 Black Sport QC 2500 auto 3.73 Swiss cheese Air box w/ Proguard 7 stock replacement filter, Airaid MIT, TAG, ATS ArcFlow, Quad Boost Fooler, Quad Commander w/ fuel pressure kit, Smarty S6 POD, 4" BMRP muffler with Aero in place of CAT, '06 metal intercooler (10mm [little more than 3/8"] thicker than original plastic), AD II 165, Roadmaster active suspension, Goodyear LT 275/70R18 |
#3 |
I have found the very absolute best solution for this is a blindfold or just not caring like me, my truck holds 90 gallons of fuel and I top it off once every two weeks.
#4 |
have to agree with jd dont look our just quite caring im happy with th 16-17 i get driving 80
__________________
2006 2500 mega stock except fo road armor lonestar sold 03 2500 quad 6sd |
#5 |
Ditto...my fat truck is not ever going to get better than 16-17.
I would rather get 13 and drive it like I stole it!
__________________
04 HO: Custom Audio, 4.5" up w/ 2.5 Kings, Thuren Springs, 37" XAT on XD Hoss, Custom headache rack/steps/bumpers, bedliner, flares, SS aux tank, Brite Box, B&W Hitch, Trailer Brake, Turbo Timer, Diprocal's, HTT IC, Opie Bypass. Ultimate Trans w/ Opie Fat Shafts & ATS Commander MPI Twins, Flux's, F1 Springs, Helix 2, Evil Twins, Opie's Gusher LP, GDP 2 mic & Intake, ARP 625's w/ Orings, Smarty, TST, MP-8... DTR "Twins" Club Member #3 |
#6 |
cover the bed with a cap or a Tonneau, run STOCK tires at max air pressure, keep boost at 10psi or less, keep highway speeds at 65mph or less.
__________________
2003 4x4 2500 CTD Quad-Cab 48RE 10.5/4.10's My own Ram Air with Pro-Gaurd 7 drop in filter - Click for link 2nd Gen Intake horn Rhino lined Bilstein HD shocks - They look better black! Timbren overloads Hellwig sway bar Sulastic Shackles Defiant steering box brace Brite Box Silent Might muffler Isspro Gauges Smarty SO6, Quad Race pressure box Chuck Lancy built transmission drivers seat mod - Click for link Next - Lift Pump, Turbo, Injectors |
#7 |
Xs 2, I didnt get this truck for the mpg, I got mine to haul heavy and go fast.
__________________
Black 05 dually G56 4x4 QCB, Smarty/mp-8, Flux 2.5s, F1 sportsman springs, ARPs, 5" straight pipe, B&W turnover, westin platinums, geneva tool box and bed sprayed with proliner leveled, 2" spacers, 315/70R17 MTZs, isspro fp, boost, and pyro in A pillar, rail guage, ranch hand legend, 2 probox 8s, jl 500/1 & 300/4, GDP 392 performance, MK2+big line kit, tank vent mod, fluidampr, SBC sprung hub 3600 DD and hydros, Opie Bypass, BD R850s DTR "twins" club member #47 |
#8 |
i just drive it and fill it up when it get below a quater lol.don't even worry bout the mpg.
__________________
2012 DODGE LONGHORN LARMIE DRW 4X4. IN THE WORKS. 2001- stock and ready for mods. SOLD-07 DODGE 2500 CTD LARMIE QAUD LWB CAB 4X4 SUN ROOF, SMOKED RECON CAB LIGHTS, AFE STAGE 2 PRO GAURD 7,QUADRACE BOX/SMARTY,FASS,SILENCE RING MIA,5" CAT BACK,LIMO TINT ,2" LEVELING KIT,35"BFG'S,LINE X BEDLINE. |
#9 |
I find it interesting when someone declares they don't care what their mileage is.
There are two reasons why I do care. One is range. The more range the truck has the better. And I mean on the standard tank. Others with auxillary tanks must care too, but say they don't. Why would you go to all the trouble to increase your range with an aux tank and say you don't care about mileage? Better mileage would do the same thing for less cost and hassle. The other reason is the cost and sending money to people who hate us. When I start throwing $100. per week into the truck for fuel you better believe I care about mileage. So for those that don't care I simply ask what it will take for you to care? Just curious. $5./gal fuel, $7./gal fuel? Why not $3./gal fuel? Maybe some of us have so much money that it doesn't matter, not me. As far as mods go, a Smarty on a low setting with timing, tires smaller than 315s, reducing speed and no heavy acceleration. Well, at least not all the time. Another practical thing is taking the TDI when the truck is not needed. The biggest gains come from just driving it easy. I know some like to proudly say "drive it like you stole it" and that's fine, but I can tell you that if I drove mine like I stole it, it would not have lasted for one week or maybe one day. And I'm not about to get a new one every week just so I can break it. Wetspirit
__________________
John I only exaggerate enough to compensate for being taken with a grain of salt. '04 2500 4WD std cab, HO, Smarty, 48RE, TC, VB, Hytec pan, Dynatrac, '08 steering linkage, track bar, '08 H2s, Toyo MT 295/70 E, Walbro, gauges, Brakesmart, exhaust "out the side", intake tube, billet filter lid, Kilby guard, KYB front, Rancho 9000s rear, Timbrens, PW flares, front 1" lift, Wet Okole, wheel well liners, debadged, splatted bugs, hood pal. |
#10 |
Save yourself allot of money, just get a 1/2" piece of wood and glue it to the floor under the accelerator pedal...best MPG mod there is..
Rick
__________________
2004.5 2500 6 Spd QC, 4X4, SLT, AFE Stg II, Di Pricol Gauges, 3 Pillar Mount, 4" Duals, Jordan 2000, B&W turn over ball, KORE Suspension, SPS/62, ATS manifold, SB 3250 DD, F.A.S.S., Buckstop Bumper, Warn 12000, DSS Steering brace, 05 wheels, Nitto Dura 285/75/17 AT's, Ranchhand Steps, VA3.1/, Smarty 2012 VW Jetta Sportwagon TDI with DSG Truck Specs "Well, my days of taking you seriously are certainly coming to a middle." |
#11 |
lots of air in the tires,some say removing the fan helps{with an electric fan}some say manual hubs help{ill post soon as i removed my front d-shaft to repair a ujoint,probaly keep it off all summer}tonoue cover or remove tailgate,and let the engine breathe,muffler delete,remove air intake restrictions,bhaf,and a scangauge2 will help you change your habbits,it monitors engine load and throttle postion and shows mpg and fuel used and lots of other goodies,
__________________
gone but not forgotten,2001.5. 3/4 ton,4x4 sb,5 spd,,.silencer ring,mia.bhaf.130 hp xxx injectors yahooooo.edge comp.5"stacks.now smartified. new to me 04 6spd longbox,305,555.diablo predator and quad x2race box and comander.bhaf,scangauge2.stix on the wayyyy |
#12 | |
I didn't see a bit of difference in mileage when I got my cap.
Quote:
__________________
Trevor 2005 Dodge Quad Cab Laramie 4x4 Auto |
#13 |
If you read some of the threads I've started most are about mpg improvements.
__________________
2001 2500 Qcab 5spd 4x4 all stock. |
#14 |
do not remove the tailgate or let it down. all research shows that this does not help mileage, and can actually make it worse. with the tailgate up the air gets trapped in the bed making a "bubble" of stagnant air that lets the moving air flow over it.
google it for lots of answers, or watch it on mythbusters
__________________
2001 Ram 2500 24V 4x4 Auto 4.10s Silverline 4" Turbo-back Stainless Westach 30psi FP Gauge Airtex LP DIY Cab Lights Crank Case Vent Mod. |
#15 |
Tailgate doesn't matter below 55mph.... Above that you notice better mileage with it OFF. Try this..... take it off for a week and run around and up, down the highway a few times... then put it on and do the same then check and see how full your tank is each time you get done.(fill it before you start each time)..There a difference, most people don't believe it but I go by what I know and have done not by what someone says.
__________________
2006 Dodge Quadcab, Laramie, DRW converted to SRW 4x4 CTD, G56 6spd, K&N cold air intake with Amsoil Nanofiber filter, AMSOIL in everything, FASS 150, B&W gooseneck hitch, Edge J/A, CFM Intake Elbow, 19.5 Vision wheels wrapped with M143 Toyo 285/70/19.5s, EMS Free spin hub conversion...180,000 and counting.... |
| Display Modes | |
