Main Page Classifieds Tech Facts Member Photos Articles Links Forums Chat
Go Back   Dodge Diesel - Diesel Truck Resource Forums > 3rd Generation Ram - Years 2003 and up > 3rd Gen High Performance and Accessories (5.9L Only)
Register FAQ DTR Store Members List Mark Forums Read
Thread Tools Display Modes
Old 11-06-2009, 05:52 PM
dodgediesel's Avatar
dodgediesel dodgediesel is online now
Question MP8 & Quad Boost Fooler??
I'm going to be adding a TS MP8 to the mix and already have a Quad Boost Fooler. Can I run both or should I remove the Quad? Does the MP8 boost fool even if it is in the off or lowest position? Thanks for any ideas or tips...
__________________
2007 Laramie 5.9 4x4 SB
6" BDS AutoLong Arm
BDS Traction Bars
20" XD Badlands
37"/12.50/20 BFG AT KO's
Smarty REVO TNT POD
Floor It DIY CP3 Kit
FASS 95/150
AFE Stage 2
MBRP Dual 4"
AFE Bladerunner
Fluidampr
DTT Shift Enhancer
DSS Steering Stabilizer
Mag-Hytec Front & Rear Diff Cover, DD Tranny Pan
Quadzilla Commander W/Fuel Pressure Kit
Quadzilla Boost Fooler
Excell Full Billet 48RE
Old 11-06-2009, 09:12 PM
Spooler's Avatar
Spooler Spooler is offline
MP8 does boost fooling. Really no need for the Quad boost fooler.
__________________
2004.5 Dodge 3500 Dually 4x2 Quadcab, 325/600, 4.10 gears with LS, 48RE, Banks Monster Exhaust, Banks High Ram Intake, ISSPRO Gauges, Fuel Pressure, EGT, Boost, Trans Temp, 3 gauge Pillar mount, single steering colum mount, AFE Stage 1 with PGM7, Amsoil, Timbrens, Brakesmart,Bilsteins,Quad X2 Std.(Pressure Only [off]),HTT 62/71/13ss,Smarty,AirDog 100, Opie's Bypass,Goerend TC (15 blade left cut), VB, Billet Input shaft, flexplate
Old 11-06-2009, 10:19 PM
Just wondering if it will still boost fool with the MP8 off or does it really have an off position??
__________________
6" BDS AutoLong Arm
BDS Traction Bars
20" XD Badlands
Smarty REVO TNT POD
FASS 95/150
AFE Stage 2
MBRP Dual 4"
AFE Bladerunner
Fluidampr
DTT Shift Enhancer
Old 11-07-2009, 01:13 AM
Spooler's Avatar
Not sure about the MP8 when it is turned off.
__________________
Old 11-07-2009, 01:24 AM
Quote:
Hmmmmmmmmmmmmmm...
__________________
6" BDS AutoLong Arm
BDS Traction Bars
20" XD Badlands
Smarty REVO TNT POD
FASS 95/150
AFE Stage 2
MBRP Dual 4"
AFE Bladerunner
Fluidampr
DTT Shift Enhancer
Old 11-07-2009, 03:14 AM
jlibert's Avatar
jlibert jlibert is offline
as long as the mp8 is on at least 1%, it won't throw codes. When I have it all the way down, it will throw overboost codes. Ditch the quad, keep it above 1%.
-jp
__________________
Smarty, Brown's Diesel dual CP3, source twins, flux, south bend
Old 11-07-2009, 12:07 PM
Quote:
-jp
I guess that should be save for daily driving too? A guy should obviously run the Smarty TNT on stock rail pressure too??
__________________
6" BDS AutoLong Arm
BDS Traction Bars
20" XD Badlands
Smarty REVO TNT POD
FASS 95/150
AFE Stage 2
MBRP Dual 4"
AFE Bladerunner
Fluidampr
DTT Shift Enhancer
Old 11-07-2009, 01:35 PM
Redsmoke's Avatar
Redsmoke Redsmoke is offline
what does the quad boost fooler do exactley?? can some one explain
__________________
REDSMOKE!
1st you see a RED Dodge and then all you see is MY SMOKE in UR Face!!!!
2005 Dodge Ram 3500 sport lamie Quad Cab Short Box
Step Bar, Tinted out, Crome Bush Guard with KC lites, Airaid intake, 2.5 inch Revtec Leveling Kit, BDS Shocks, 35 inch tires, air horn, Edge juice with Attitude programer, AFE 4inch Exhaust, High proformance Tranny with Single disc torque Converter, Valve Body (soon to be updated to Mutidisc converter and Billet shafts), CAN'T Wait for TWINS!!
Old 11-07-2009, 05:37 PM
jlibert's Avatar
Quote:
Get a rail pressure gauge. Keep it around 18-19k for extended periods of time (i.e. highway driving). With the smarty on stock rail pressure, you'll probably be somewhere around 10-30% on the mp8 to achieve this pressure.
__________________
Old 11-07-2009, 11:03 PM
I have the Quad commander. My pressure is around 17k on the highway, 22k WOT and 6k idle on TNT #9
__________________
6" BDS AutoLong Arm
BDS Traction Bars
20" XD Badlands
Smarty REVO TNT POD
FASS 95/150
AFE Stage 2
MBRP Dual 4"
AFE Bladerunner
Fluidampr
DTT Shift Enhancer
Old 11-07-2009, 11:10 PM
diesel4play's Avatar
diesel4play diesel4play is offline
Quote:
It modifies the boost pressure signal to the ECM fooling it into thinking the pressure is lower and therefore the ECM allows you to make more boost. This gets you higher boost for very little money. I think you will need a separate boost gauge of some sort to see you actual pressure.
__________________
Diesel4play
'06 Ram 2500 Quad LB Bright Silver, Volent intake, ProComp Extreme ATs, EBC Greenstuff pads, Nfab steps, Bilstein 5100s, Rhino liner, Diamondback HD bedcover, Red Ram head mats & flaps, Recon LED lighting, Wrangler horse blanket seat covers, DeeZee SS bed rails, and going
Old 11-08-2009, 06:38 PM
With the MP8, where does a guy tap into for rail pressure? I'm tapped onto the blue wire at the plug now but do I now tap onto the blue wire on the MP8 side closest to the rail pressure sensor?
__________________
6" BDS AutoLong Arm
BDS Traction Bars
20" XD Badlands
Smarty REVO TNT POD
FASS 95/150
AFE Stage 2
MBRP Dual 4"
AFE Bladerunner
Fluidampr
DTT Shift Enhancer
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.7
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2003, DieselTruckResource.Com
