Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > 1st Gen. Ram - All Topics
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 12-22-2002, 06:24 PM   #1
mymaur
mymaur's Avatar
MORE Turbo whine
I drove a 2002 Dually, 4x4 with an automatic the other day. The turbo absolutely screamed. It was great. I looked under the hood, just a stock filter and no apparent mods to the air box. What have you guys done to not only get more air into the turbo, but get the turbo whine more pronounced. DOes K&N make an open element filter that I can just attach to the turbo hose?
__________________
-2004, 48RE, HO, 3.73 rear, 2500, 4 door, long bed, 2wd, fold flat floor, towing mirrors.
-95 Long bed, 2wd, 2500, KDP tabbed, auto, 3.54 rear.
-Small fleet of 2nd gen CTD's
-USAF, Ret. F-15 puke, 1st TFW, 27th TFS, LAFB
mymaur is offline   Reply With Quote
Old 12-22-2002, 06:34 PM   #2
richard
richard's Avatar
Re:MORE Turbo whine
You can run another filter setup like a SCOTTY II, or a K&N drop in, and also take the silencer ring out of the inlet side of your turbo. Then you will hear more turbo! ;D ;D
__________________
1991 2wd d350, cummins, 12' reading service body,
1997 12v longbed xcab 4x4, 4:10 lsd, tow pkg, cd changer, galaxy dx66v, Cooper Discoverer ST 235/85/16 10 ply, 8' dump body, Custom fab steps,laser cut delivery valves, Bosch 70hp injectors,TST #10 plate, 3KGSK, Larry B's starter contacts, K&N air filter, Skyjacker 2.5" lift front springs, 9' plow, Air lift Super Duty Airbags,. Central hydraulics,LED hideaway strobes.
2005 3500 slt, qc 4x4 dually, knapheide sevice body
richard is offline   Reply With Quote
Old 12-22-2002, 08:53 PM   #3
Guest
Re:MORE Turbo whine
Here is the silencer ring and here is the Scotty II
Old 12-22-2002, 09:54 PM   #4
GSchlegel
Re:MORE Turbo whine
Removing the silencer ring won't increase HP or reduce EGTs, it will only increase the &quot;turbo whine&quot;.<br><br>There are a lot of after market air filters that will to varying degrees also increase the &quot;turbo whine&quot;, and help decrease the EGTs. I have a K&amp;N 0880 cone type filter that does well. I'm at it's limits and will probably move to a Scotty II sometime in the future.<br><br>Gene
__________________
'96' 3500, 5-sp, 3.54 LSD, Ext. Cab, 200,000 plus miles, K&ampN RE-0880 air filter, Jannety heat shield, TST #10 plate slid forward 1/8&quot, AFC spring kit, 16 cm exhaust housing, Jardine 4&quot exhaust w/5&quot stainless steel tip, South Bend Clutch, SPA digital EGT and boost gauge, relay controlled back-up alarm and rear facing halogen tractor flood lights, 20 yr. old marine air horns, bed liner, Tonnou cover, Geno's man. trans. filter, brite box. Dyno run 1-27-02; 375.6 hp and 798 tq
GSchlegel is offline   Reply With Quote
Old 12-23-2002, 05:15 PM   #5
atc250r
atc250r's Avatar
Re:MORE Turbo whine
Before you go and order that 0880 K&amp;N make sure you get the right one. I just returned a RU0880 because it was TINY, it would have almost fit into the stock inlet pipe. I ordered a RF-1024 and will see how it works. It is a oval cone that is 10 inches long with a 4 1/2 inch inlet. I'll see how it works and I'll let you know. Does anyone know the full 0880 part number that is supposed to fit these trucks?<br><br>John<br><br>
__________________
1996 Ext. Cab, 5 spd, 3.54's. home made #100 plate almost all the way foward, 16cm2 turbine housing, HX40 Compressor housing. 5 inch Turbo Back exhaust, K&N cone on home made bracket, DiPricol EGT and Boost gauges. Mechanical fuel pressure gauge. Timed to 17*, 4K GSK, and a SB 13inch FE Clutch. 2" leveling kit and DSS in front, add-a-leaf in the rear, and Bilstein shocks all around.
atc250r is offline   Reply With Quote
Old 12-23-2002, 05:51 PM   #6
Guest
Re:MORE Turbo whine
RE-0880
Old 12-23-2002, 09:57 PM   #7
atc250r
atc250r's Avatar
Re:MORE Turbo whine
Ahhhhh. Do you put it directly onto the turbo flange?<br><br>
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
