Go Back   Dodge Diesel - Diesel Truck Resource Forums > 3rd Generation Ram - Years 2003 and up > 3rd Gen High Performance and Accessories (5.9L Only)
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 01-14-2009, 06:33 PM   #1
AH64ID
AH64ID's Avatar
More guages installed...
Over the last few weeks I went from 2 gauges, boost and EGT, to 6... I also made my dual a-pillar a single a-pillar.. The visibility is much better now.
I added Rail Pressure (for fun, I don't mess with pressure), fuel pressure, oil pressure, and drive pressure (mainly for exhaust brake pressure). I also moved my pryo probe to the collector and put the drive pressure in the old pyro hole..
I have played with the drive pressure a little, but nothing too much.. I will be curious how it runs when towing.. It gets to about 40 and holds with the WG on... over 55 with the WG off and stock fueling.
The Fuel Pressure sender. I "T"ed into the line after the Cat 2 mic and before the CP3.
Click the image to open in full size.
The new pyro location and DP hookup.
6' of copper tubing to dissipate the DP heat.
Inline filter to keep any soot (in case of an air leak) from getting to the gauge.
Where I tapped into the oil.. On the drivers side above the ECM.
Rail, Fuel, Oil
EGT
Boost, Drive
__________________
'05 3500 SRW 4X4 QC LB NV-5600
Smarty UDC Custom Tuned
AH64ID is offline   Reply With Quote
Old 01-14-2009, 06:38 PM   #2
Topper
Topper's Avatar
Man you need more gauges on that puppy!
Nice job,
Topper
__________________
06 dually
Bored 40 over
Issopro egt,boost & trans temp
Zilla FP & RP
Single shot of Nitros
Smarty TNT
Hamilton big stick
#110 lb springs
II PS62/S474 twins
FASS
2 mic ff
Arson III
DDP 90's
fluid dampener
ARPs (625)
EEP pressure by pass
Generation 2 1 micron oil bypass filter
Full Goerend built trans w/converter
BD flex plate
Leveled
35s
AFE Blade Runner Intake
S&B cold air intake
Magnaflow 5' SS dual exhaust.
Firestone R R
RBP Grille
Topper is offline   Reply With Quote
Old 01-14-2009, 07:06 PM   #3
92'1stGen
92'1stGen's Avatar
Very nice install. How did the windshield pod mount and how do you like it? Also, I was just reading the thread on your Amsoil bypass install and noticed that you put a "T" on top of the OEM oil filter housing for a possible pressure gauge there in the future. How come you didn't end up going with that route for your gauge?
__________________
- 92' W250 "The Tank" - Ext Cab - 4x4 - Cummins 5.9 - Auto w/3.55 - Blue/Silver - 177,400 as of 1/12
- 06' Ram 3500 - DRW - Reg Cab - 4x4 - Cummins 5.9 - Auto w/ 4.10 - Patriot Blue - 77,600 as of 1/12
- 11' VW Golf TDI - 6-Stick - 45+ mpg - 14,000 as of 1/12
"One of the first and the last"
Traded But Not Forgotten
- 04' 1500 - Black - Quad Cab - 4.7 V8 - 2x4
92'1stGen is offline   Reply With Quote
Old 01-14-2009, 07:33 PM   #4
AH64ID
AH64ID's Avatar
Quote:
I really like the windshield mount, its not obtrusive and easily visible.. Thou I don't get good vis on the oil psi gauge, but that's okay it's not as important.. to get it to stick really well I got the sticky back velcro hot, almost melting/burning, with a lighter.. it stuck like crazy glue..
I didn't use the T because the sender wire is too short (and the way the harness works I couldn't route it down the pass side) to reach, so I could either splice the wires or move the sender. Thanks to the OE port above the ECM I just went that route. It was a PITA to get it installed behind the wiring, but its done.
Old 01-14-2009, 10:45 PM   #5
Big C
looks good! where did you get the filter for your dp gauge?
__________________
05 2500 4x4 dual cp3s, smarty tnt, S400 with a 74mm comp. wheel, big sticks, fass 150 pump w/filters, studded and o ringed head, valve springs, snow stg 2 water injection, 5" downpipe to 7" single stack, fully billet auto with a manual valve body and a rachet shifter, and a whole bunch of pullin' goodies
757hp and 1545tq with a a5000
Big C is offline   Reply With Quote
Old 01-15-2009, 07:38 AM   #6
AH64ID
AH64ID's Avatar
Quote:
I got it from the local Parker Hydraulic store. It has a copper waffer in it, we'll see how well it works, thou in a perfect system it wouldn't be needed.
Old 11-15-2009, 05:08 PM   #7
AH64ID
AH64ID's Avatar
Update:
I got tired of the overhead pod falling off on hot days, and didn't want to have to do the major mounting I have read about on here. So a change was in order.
I went with a tripple dash pod, ditched the mickey mouse, and put a single pod down by my trailer brake controller.
I ended up keeping EGT in the A-Pillar, put boost, fuel pressure, and oil pressure in the tripple dash mount, and put drive pressure down by the trailer brake (as my primary use is exhaust brake pressure). Rail pressure was removed and sold (wasn't really needed with my setup and couldn't find a home for it in the truck)
I have about 8K miles on the new setup and a few tows, I really like it. There is a little more glare on the gauges on the dash, but nothing crazy.
I also removed the DP filter, it froze in winter and plugged the rest of the time. mech boost gauges are cheap, if the gauge gets plugged i'll get a new one.
How she looks now.
Old 11-15-2009, 05:44 PM   #8
steve936
steve936's Avatar
My gosh...do you get to look at the road much at all? lol
__________________
05 QC SLT SWB 4x4 2500 AUTO EJA/S&B/HBS/Bilstein/HELO/Nitto/ARE/NFab
steve936 is offline   Reply With Quote
Old 11-15-2009, 09:51 PM   #9
AH64ID
AH64ID's Avatar
Quote:
whats a road??
Old 11-15-2009, 10:14 PM   #10
ratsun
ratsun's Avatar
I have had all the different mounts in the various trucks and have finally settled on the dash pod and srt pillar the same as you have.
The dash pod seems the most convenient to look at and I can kinda keep one eye on the road.
I found with the overhead it was hard to focus on the gauges and I had to take my eyes off the road, the pillar was the same though not quite as bad.
__________________
2003 3500DRW QC Laramie 4X4 NV5600 4" Superlift~Rumble Bee Scoop~FASS 150~Dr.P/Smarty Stack~SBC OFE~Performax Gauges~BD Brake~AFE II~DTT Intake~Audio Addicted
__________________________________________
Sold
1998.4 12V LB/QC 2500 4X4 AT
PDR Twins Helix II 913 modded pump
Sold
1998.5 24v LB/QC 2500 4X4 AT
PDR Twins Comp-Hot
Wifes car
04 Jetta TDI Sport
GAS IS FOR WASHIN PARTS
ratsun is offline   Reply With Quote
Old 06-08-2012, 02:37 PM   #11
AH64ID
AH64ID's Avatar
Bringing back an old thread...
My Pricol pyro started acting up this past winter, and after a few tows with it acting funny it was time to give it the boot. I really wanted a matched set, so I sold the other 4 Pricol's and ordered up a set of 5 ISSPRO EV2's.
I have been wanting to change the locations of my a couple gauges and add a time delay relay for a while, so this worked out well.
I had the alarms set to where I want them, which is a GREAT feature of the EV2.
Boost 0-40, warning > 38 psi
EGT 0-1600°, warning >1300°
Fuel Pressure 0-20, warning <3 psi
Oil Pressure 0-100, warning <15 psi
Exhaust Backpressure 0-100, warning >65 psi
The gauges came with the dimmer and that made install VERY easy. You are able to daisy chain them, and I was able to route the wiring from the dimmer **** to the Oil in the A-Pillar, to EGT, Boost, Fuel on the dash and down to DP by the trailer brake controller.
Previouslly the EGT was in the A-Pillar, and Boost/Fuel/Oil were on the dash, with DP down by the brake controller. I liked DP by the controller as I mainly use it for the exhaust brake, and next to the brake controller made sense. What I wanted to do was put Boost/EGT next to each other on the dash and move oil to the A-Pillar.
Additionally I have been wanting to add a time delay relay to the gauges. I don't like how when you start the truck the gauges reset and readings have to wait on the gauge to power back up. I got a TDR from a friend of mine, and wired all 5 EV2 to it. Now the ignition has to be off for about 2 minutes before the gauges shutoff. This does 2 things I like, it allows quicker and more accurate oil/fuel pressure readings during and after start and it lets me monitor EGT's after shutting the motor off. If they really climb I can tell I didn't allow enough cooling time.
All in all I like the EV2's. I still think some of the markings on the Pricol's were better, and a mechanical boost gauge is much smoother than an electric one. The boost gauge does read about 1 psi lower than the ECM sees, but I think that's due to being at 3K feet elevation. But overall these are great gauges, and very precise!
Old 06-08-2012, 10:21 PM   #12
justen920
justen920's Avatar
Soon it will look like this:
Looks awesome.
__________________
2006 3500 Mega Cab SLT.48RE. 4x4. Silver. De-Badged. Bushwacker Pocket Flares. Line-X bed, rails and under carriage. Bully Steps. Ultra Star lamps. Amsoil ByPass and VP Max Fuel Filter. Timbren rear supports. ISSPRO EV2 Gauges: Boost, EGT, & Trans Temp on the pillar, Fuel Pressure on the column. Magnaflow 17132. Prodigy Brake Controller. Smarty Jr.:SW1 TM2 TQ4 POD99. Lock box for my Custom Springfield 1911.
2001 32 foot Alfa Gold 5th Wheel
Mega Club Member 338.
1977 F250 Custom 4x4
justen920 is offline   Reply With Quote
Old 06-08-2012, 10:30 PM   #13
AH64ID
AH64ID's Avatar
That's old school... now we fly like this..
Old 06-09-2012, 01:40 PM   #14
Danderson
Danderson's Avatar
Here in Ca,you'd probably get pulled over for "distracted driving".
In addition to being Mr. Filter,you are now Mr. Gauge. Nice job.
__________________
'07 2500 Reg.cab, 4wd,G-56,5.9, Northstar popup 24/7. SBC G-56 OKHD.
Danderson is offline   Reply With Quote
Old 06-09-2012, 03:14 PM   #15
MikeyB
MikeyB's Avatar
Which scan gauge is that?
MikeyB
__________________
2003 2500 2wd SWB Quad Cab Laramie, 305/555, NV5600, 3.73LS, Line-X, Westach boost/EGT combo gauge, PML diff cover, Airbox mod, Hurst 6spd Shift ****, Adjustable boost elbow, Toyo OC AT 285/70/17 E, Daystar 1.5" lift, Monroe Reflex, Raptor RP100, Lazarsmith Intake Horn, HID
SMARTY Sr./Van Aaken C3.2
MikeyB is offline   Reply With Quote
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
