Go Back   Dodge Diesel - Diesel Truck Resource Forums > Specialty Forums > General Diesel Discussion
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 07-05-2005, 04:52 PM   #1
Flatty
Mega Cab?
So what is the story on this truck? I am in the market for a enw truck, but if this one is coming out soon, I may have to get this one. Does anyone know an estimated price on a 6speed manual, cummins 4x4 mega cab?
DIma
__________________
1968 FJ40 TBI 350, TH350, 60's, 40's, Hummer beadlocks,... Will be driven daily
Flatty is offline   Reply With Quote
Old 07-05-2005, 06:59 PM   #2
1320
I don t think the mega cab is available with a cummins....either at all or until the next model year or something....
__________________
98 12 valve,Twin turbo& triple intercooled, hx 40 (16 cm )/ht3b(26cm) 4x4,quad cab,DRW,NV5600 conversion,velvet ride shackles,KDP fixed,.020 over marines, ported head, helix 2 cam, lots of coatings, quick spool valves, ats ported and coated manifold, total seal rings,DDP4's,4000gsk, 5 dp to 4 inch home made exhaust with us gear exhuast brake, bhaf, alcoas,gauges.60 lb valve springs, southbend, magtec.
1320 is offline   Reply With Quote
Old 07-05-2005, 09:00 PM   #3
graphitecumnz
graphitecumnz's Avatar
you can get them with a Cummins...
"With two class-dominating engines offered, the all-new 2006 Dodge Ram Mega Cab provides the ultimate in full-size pickup power. The 5.9-liter High-Output Cummins Turbo Diesel, available on the 2500 and standard on the 3500 model, is rated at 610 lb.-ft. of best-in-class torque and 325 horsepower. It is available with a new six-speed manual transmission or an automatic transmission. The 5.7-liter HEMI V-8, standard on the Dodge Ram Mega Cab 1500 and 2500 models, leads the crew cab segment with 345 horsepower and 375 lb.-ft. of torque, and is available with a five-speed automatic transmission. "
__________________
P-pumped 2002 2500 QC short bed 4x4
Dodge Makes it, Cummins Shakes it...
"Politicians never accuse you of 'greed' for wanting other people's money --- only for wanting to keep your own money."
graphitecumnz is offline   Reply With Quote
Old 07-06-2005, 10:59 AM   #4
1320
Is it that you can t get a 3500 in a mega cab? Or a dually ? Cause its something like that.....I think.
The whole purpose of the mage cab is for a 3500 dually......but thay don t make it yet do they?
Old 07-06-2005, 11:16 AM   #5
pmpislander
pmpislander's Avatar
what the problem is, is that you cant get it in a long bed they only are short beds. They use the extra two feet of the frame for the cab and they arent using a new frame to do it. so untill they come up with a new frame for the truck you are stuck with the short bed mega cab.
__________________
92 d250-auto 2wd-club cab-all stock.....for now
09 2500 mega cab 4x4 with 6 spd man trans, egr delete, egr cooler delete, cat delete, dpf delete, s&b cai, smarty 14me, valair dd clutch, airdog 165 on order
Semper Fi!! Do or Die!! KILL KILL KILL!!!!
pmpislander is offline   Reply With Quote
Old 07-06-2005, 12:12 PM   #6
graphitecumnz
you will only be able to get a shortbed but no duals. They are currently using the frames from the longbed QC's and putting on the shortbed giving them the extra cab room. I suspect that in the near future, they will build a new frame to accomodate a longbed in the 1500/2500/3500 and a dual wheeled option for the 3500
Old 07-06-2005, 02:09 PM   #7
mr T
they're duallys with short boxes...no long box offered so far...i think they're supposed to be out 2006...not sure though maybe they're available 2005.5
__________________
SOLD:
1995 CTD 2500, 4x4, long box, ext. cab, BLUE, 3.5 rear, 47RH, 363 000 km, WAAG bush guard, 285/75/16 tires
3K GSK
homemade #10 plate
BHAF
silencer ring MIA
wastegate blocked
5" stacks
15.5* timing
TC lock-up switch
mr T is offline   Reply With Quote
Old 07-06-2005, 08:53 PM   #8
kingofdodge7131
There only offered in 2500 and 3500 series truckks. Hemi and diesel are available. Short bed only with no duals. Now if you want ot put your own dual kit on then thats your wishes
__________________
The newest addition to the family 1/20/2010 a 2007 dodge ram mega 6.7! Smarty/edge combo solid axle manual hub conversion, bfa, and soon well be doing some nasal reconstruction!
New baby as of 7/24/04 2004.5 Ram 2500 4x4 silver diesel. 600 cummins. All the nice lil electrical things that will die in about 5 years haha. Stock and with these payements at 20 will stay that way
97 4x4 360
99 CTD 4X4 intake and exhaust,
kingofdodge7131 is offline   Reply With Quote
Old 07-06-2005, 08:55 PM   #9
graphitecumnz
Quote:
according to Dodge, you'll also be able to get a 1500.... per their website.
Mega Cab Specifications
Old 07-13-2005, 05:22 AM   #10
Barry Smith
Barry Smith's Avatar
That showed a NV5600 on the spec sheet?????????????????????????????
__________________
2009 Ford F-250 4x4 Crew Cab 6.4l Lariat Loaded Black w/ Black Leather DPF delete Mini Max.
Old Truck: 1999 2500 4x4 QC SLT 5 speed Power Max 3 w/remote, Pac Brake, Dynamax muffler, Auto-meter Ultra Lite Fuel, Boost and Exhaust gauges, 114,000miles South Bend Clutch Con OFE, Vulcan Big Line Kit, Carter LP.
2002 H-D Electra Glide Suede Green and Black
F & A.M. Lodge 266
Barry Smith is offline   Reply With Quote
Old 07-13-2005, 10:20 AM   #11
thecatsfan
thecatsfan's Avatar
Quote:
That's the standard transmission for the diesel models. The 48RE is optional.
__________________
Purchased 01/31/09: 2008 3500 Laramie, QC, DRW, 4x4, 68RFE, 3.73, light Khaki.
Sold 01/23/09: 2001 2500, QC, SB, 4x4, 5sp, 3.55, Edge EZ, AFE Stage 2, Jacobs E-Brake, 4" DUAL exhaust. Dark Garnet Red, ARB Sahara bumper, ARE tonneau, MM 12K lb. winch. Pyro, Boost and FP. BFG ATs 315/75/16 on 16x10s. SkyJacker D25 coils, Rancho RS9000x. DT ext. control arms, DT Track Bar.
2005 Wildcat 31QBH Fifth Wheel. Destroyed in an EF4 tornado 5/22/08.
2008 Raptor 3612ds Triple Axle Toy Hauler.
thecatsfan is offline   Reply With Quote
Old 07-13-2005, 12:12 PM   #12
graphitecumnz
I'm sure the spec sheet was created before the switch to the G56...
Old 07-13-2005, 12:57 PM   #13
thecatsfan
thecatsfan's Avatar
Ah yes. I see. I forgot the NV5600 was gone this year.
Old 07-13-2005, 11:19 PM   #14
kingofdodge7131
hum, Im a little confused because when they debut the truck chrysler said it was only in the heavy duty modles, oh well
Old 07-14-2005, 11:46 PM   #15
Barry Smith
Quote:
That's ashame!
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
