Thread Tools | Search this Thread | Display Modes |
#1 | ||
Mayden towing trip with all the new mod's
__________________
Tow Rig: 99 CTD/Club Cab/4x4/5sp/80HP injectors/xmonitor/afe intake/Edge hot comp/4inch with a muffler/Vulcan bigline relo kit/315 75 16s w/ level kit/Bilstiens up front/pac brake/mag diff cover/Ride Rite Airbags Old Girl is Gone 92 CTD/4x4/auto OD/2 turns on fuel screw/POD's/3200 RPM Gov Spring/PDR Custom Fuel Pin/Autometer Diesel tach, pyro(pre-turbo), trany temp, and boost/BHAF w/ direct flow to turbo/H1C/16cm/4in stright pipe |
#2 |
What were you pullin? I know the first time i pulled a trailer full or round bales i was amazed at what just my 16cm housing and pump felt like. i really didnt have high temps mainly round 900. goin wasnt the problem stopin was. NO Trailer brake
__________________
FEarTheDeerE _________________ Workstock Puller OverBored 2007 Dodge 2500 HD 6.7 CTD 6sd manual PMT-MP-8 Stack Fass 150 4in straight pipe 3850 SBC Dual Disk Arson JR DIY Intake Traction Bars -Waiting of Funds List- Fleece boost Controler. Homemade Cheata Turbo |
#3 |
pulling my old landcruiser on a flat bed trailer. cruising on flat highway doing 60-65 was pulling between 950-1000.
oh yeah air temp on teh hill climbs was about 80-85 out. jiMMy |
#4 |
Did you go up icehouse or what?? When i head up grades like 50 or icehouse, i can peg my pyro on demand pretty much. On grades i mostly let it sit right at 1200*.
Did you just turn in your screw or did you also spin your afc?? When i turned mine in and messed with the afc, i noticed a pretty big difference in towing a trailer. I went from being able to do like 55 up to the con. To bein able to do like 70. But some of the long hills i have to let off because my EGT temps hit1200, i usually back off to 65 mph. My motor tempature never really gets hot. I can run the ac all day long up hills and it barely hits the secont mark on the temp guage. BTW jimmy i live in sac right now, i go to sac state. I saw you the other day on watt/northrop, kinda near where i live. Im fully jealous of the colors of your truck that is the color i wanted but didnt find a deal on one. Nice rig. Ian-
__________________
92 dodge 250 turned up pump Rockracer hauler! |
#5 |
IAN, SICK i live off watt and pope (near whitney and marconi).
(i went to fordyce so i was cruising hwy 80) i just turn in teh fuel screw abit (1.5 turns) and of course the other mods. i have touched the pump otherwise. and my 2/3's on teh temp gauge i mean about 1-2 oclock as the needs sits. is that HOTT or OK. cuz around town unloaded it never gets past the 10-11 oclock mark. |
#6 |
Hey Jimmy, my FSM says 2/3 on the temp gauge is normal in hot weather on a steep grade while towing. It's not a bad idea to flush the cooling system, but don't be surprised if you need a new radiator afterwards. A lot of times the crud is all that's holding the coolant in on an old truck. I don't think you'll need a pusher fan with a clean cooling system. Also, did you ever get that auxilliary trans cooler installed? That'll help with temps because the trans is dumping a lot of heat into the water through the heat exchanger on the side of the block.
__________________
Faith '93 D350 - DPS 6x16's, HTT Stage IV/14wg, PowerStroke IC, Snow water/meth, Walbro 392, Con-FE, pump tampering by owner. 390 HP/800 TQ on #2 only, 413 HP/852 TQ w/ water/meth - needs more air! Dead KDP's = 72 |
#7 |
never did get the extra trany cooler, it is on the list of goodes to buy though. good to hear that the 2nd tic on the temp gauge is OK. id pulling the hill in the fast lane and it would just slowly climb to there hit the half mark and the fan would kick on and i would kick it out of OD and into D and just take it easy on the ol girl. id crest the grade and things would come back down . very nice to accelerate the whol grade though. jiMMy
#8 |
Flush your radiators from the BACK side. That's what cooled mine down.
Check this thread: http://www.dieseltruckresource.com/d...radiator+flush
__________________
SUPPORT OUR TROOPS ! 1999 Ram 2500, SLT Laramie, Quad Cab, LWB, 4X4, 5 Spd, Camper/Trailer Tow Pkg, LS/RE, Westin step bars, Ram molded splash guards (front and rear),diamond pattern bed caps and toolbox, Isspro EV boost, pyro and FP pillar mount. FASS II on 6/5/05. Rancho RS9000's on 8/23/05. RV275's on 12/11/05. AirRites on 3/5/06. MBRP 4" on 3/14/06. DSS on 4/8/06. Smarty on 10/12/06. New front rotors and axle seals: 8/08 Jammer 3's on 9/6/08, South Bend Con O on 1/30/09 304/718 on 4/1/06. |
| Display Modes | |
