Thread Tools | Search this Thread | Display Modes |
#1 | ||
how many miles?
#2 |
Don't worry about the miles. I have almost 400K on a 98.5 with no mechanical problems. These engines are hard to kill. Mine is tagged for 33,000 pounds and has pulled this and more on several occasions. One that isn't worked so hard would probably go a million miles without any problems. I've only replaced the VP-44 once and several lift pumps. 200K is only broken in.
__________________
98.5 White, 3500 Laramie SLT, Quad Cab, 6 Speed, 4.10 LSD, Fog Lights, Alarm, Tow Package, Edge EZ/Boost Elbow, Westach Boost/EGT, Fuel Pres., Trans./Diff. Gauges on A Pillar, 275 Injectors, No Muffler, 90 Gal. Fuel/Toolbox Combo, Fiberglass Running Boards & Ground Effects, Amsoil Remote Bypass, AFE Mega Cannon, Tekonsha Brake Control, 33ft. Travel Supreme 5th Wheel, 36ft. Trail Master Gooseneck, Cobra 29, Kenwood TS50 & TR751A, 400K miles. |
#3 |
I think for a rebuild on our engines is an "as needed" thing. Set the valves every 100,000, regular oil changes, routine maintenace, etc, will keep these engines happy and running a long time before anything major (like a full rebuild) becomes required.
__________________
J.R. U.S. Coast Guard , Electronics Technician 1st class Extra class Amateur radio operator - K5DTR 2001½ SLT 2500 2WD, auto, short bed Hi-flow banjo bolts FASS DDRP Scotty Air II Isspro EGT (pre-turbo),fuel pressure, boost, and transmission temperature (sensor in hot line) guages |
#4 |
You will have to replace the injection pump on that motor if you decide to keep it for another 200k. That's about it.
__________________
1996 Ram 2500, Club Cab, Long Bed, 4x4, 47re, 3.54 |
#5 |
Thanks for all of the help.
Hopefully I can pick this rig up by next weekend. Ken |
#6 |
Registered
Kennys. If we could all get 200k per vp, we would all be happy campers. what's your secret?
#7 |
All I have done is add Marvel Mystery Oil about every other fillup. Original pump ran 274,003 miles. It did die in a good place, in the yard. It could have happened several hundred miles from home.
| Display Modes | |
