| View Poll Results: How many have replaced a carrier bearing? | |||
| Yes, one time. |
9 | 27.27% |
| Yes, more than one time. |
1 | 3.03% |
| No, not yet. |
23 | 69.70% |
| Voters: 33. You may not vote on this poll | |||
Thread Tools | Search this Thread | Display Modes |
#1 | ||
How many have replaced their carrier bearing?
#2 |
Had to replace a set in my '97 at 114k. I thought it was a little unusual for a Dana 60. Also, it was only the one side that was going bad. I replaced both, of course, but I never thought I'd have the problem at all.
#3 |
Are we talking Carrier Bearing as in center bearing of The 2 piece driveshaft?
Or Carrier Bearings in a Differential as Stated above? 1 Center Carrier bearing for me @ 170000 miles
__________________
98.5 Ram2500,24Valve,CTD,4x4,285's 410's,5 Speed Amethyst,Lukes Link,New Rotors, Stock AF,5th Gear repaired,Newballjoints,NewShocks,New Walbro setup 20PSI ,19.5MPG.#53 Block(just cracked)Lock N Stitched BUT Still Seeping AntiFreeze.HomeMaid Repair Stopped Leak in Block.Looking For An Engine NO!!! Found A NEW 2001 CTD with 8500 miles HI My Name is Bob And I have Been #53 Free Since April 2 2006,Just Say NO To Antifreeze,Just Added a EDGE Comp,Joined the 200000 Mile club. |
#4 | |
Quote:
FWIW, I had to replace one at 170k......there is 223k on the truck now. I put on a NAPA bearing.
__________________
03 3500 QC DRW 4x4 6spd HO-4" PRXB w/04.5 down pipe, MBRP 304 Duals, Smarty Revo 4.19A, Commander/X2 Race, Flux 1's, Icebox, home brewed intake horn, ported HE351, Turbosmart, South Bend Con-OFE clutch, leveled, 5100's, Dynatrac Freespin hubs, Accuride 19.5's, DSS 98.5 3500 QC 4x4 24v 5spd-SOLD 94 2500 4x4-SOLD CJ Juggy-Goes really fast, goes really slow, lots of smiles per mile "Madness takes it's toll....please have exact change ready" |
#5 |
My buddy dodgediesel4x4 just had his seperate on him after towing 15k+ lbs. He's got 101,000. First one for him and he's lifted and needs ladder bars bad.
#6 |
Not yet, but need to soon.
__________________
1998.5 Ram 2500 4x4 QCLB, Full DTT setup, HRVP44 with tapped Edge Comp (WOW), 275 Injectors, Vulcan Big Lines w/ Holley Blue pushing, BHAF, Magnaflow 4" SS exhaust, B & W Turnover Gooseneck, Pyro, Tranny Temp and Boost Gauges in pillar, Fuel Pressure gauge in cup on steering wheel, 16"x8" Polished Atlas rims w/ BFG MTs 299/680 Fall Brawl 2005 1971 Nova | 2001 Grizzly |
#7 |
yea, i'm gonna have to do mine sometime in the near future
__________________
98.5 24v 5spd 4x4 cb/lb, in the process of buildin a 12v puller |
#8 |
What are the symptoms of a bad carrier bearing?
Mark
__________________
1999 Ram CTD 2500 QC SB Laramie SLT 4x4 24V Goerend Built Tranny 4.10 gears Pilot 195 4" Round Driving Lights Lucas Clear Fog Lights Dipricol FP, Boost & EGT Skyjacker D25 2-1/2 inch Coils Tuff Country 2" Rear Add a Leaf Bilstein 5100 Front Bilstein Yellow/Blue Rear Cooper Discoverer ST 285/75/16 DT Adjustable Track Bar RV275 Injectors Edge Comp Box Scotty Big Fuel Lines Walbro 392 Fuel Pump Kit Vulcan Draw Straw 3rd Generation Door Badges |
#9 |
oohhhh you ll know it....clucnk, clunk bang......etc etc.
I replaced one and FWIW early 98's are different then all others. It took serior effeort to get the correct one. Mine is bigger then the one all the books call for (except the oem #)
__________________
98 12 valve,Twin turbo& triple intercooled, hx 40 (16 cm )/ht3b(26cm) 4x4,quad cab,DRW,NV5600 conversion,velvet ride shackles,KDP fixed,.020 over marines, ported head, helix 2 cam, lots of coatings, quick spool valves, ats ported and coated manifold, total seal rings,DDP4's,4000gsk, 5 dp to 4 inch home made exhaust with us gear exhuast brake, bhaf, alcoas,gauges.60 lb valve springs, southbend, magtec. |
#10 |
my old man replaced one on his 95 at about 150K, ive replaced mine because 4 wheeling over large banks of dirt and rocks with steep angles dont mix...i hit the bearing on a rock and bent it back, removing the rubber and bearing from the metal housing itself
#11 |
I was having a severe driveline vibration issue and it tore the rubbe support so I'm replacing it with the u joints.
__________________
2004.5 Cummins 600 With 6 Speed Black Sport Quad Cab 2500 Laramie LWB 4X4 4.10 Line X Rockers and Bedliner. Dipricol FP Boost EGT Custom Autometer mount/HVAC Relocation. Waag wheel to wheel steps. Recon clear cab lights H2 Tires. Fox weatherboots. Fold-A-Cover. Another Tomeygun Special. IAFF Local 1568 "It is not getting any smarter out there, you need to come to terms with stupidity and make it work for you." Frank Zappa |
| Display Modes | |
