#1 |
Manual Tranny Question
Can anyone tell me why a truck with the manual tranny has the torque reduced to 610ft/lbs while the auto gets the full 650?
Thanks Greig
__________________
2001 3500 4x4 6 spd.H.O Patriot Blue, Edge EZ, U.S Gear Exhaust Brake |
#2 |
So that they can use a lighter return spring for the clutch pedal.
Then you don't overwork your left leg and make it deformed. Then you would sue Chrysler cause your affliction would be all their fault!
__________________
Jerry 2010 3500 Dually, Laramie, Austin Tan w/ Brown & Beige interior. B&W Turnover G/N. Dually Depot fuel tank Soon: Rhino Lined, Raptor Stainless Steel Nerf Bars, MyGig Lockpick. Gone: 2006 Flame Red MegaCab 2500, but not forgotten. |
#3 |
Jerry, are you saying the clutch is the weak point?
#4 |
Yeah, that's basically it.
GM did the same thing in their trucks. If you got the Allison, you had higher ratings than if you went with their ZF 6-speed manual.
__________________
Maroon 2001 2500 QC 4x4 SB SO pumped HO 6-speed 285/75R16 BFG Mud Terrain T/A KO, Smarty, TST Powermax3, KSB1-1, DD2s, Autometer EGT/Boost, Westach Fuel Pressure, Amsoil EaAU4091 |
#5 |
i would say because you lose torque and hp thru the converter and tranny unlike a manual. the clutchand manual tranny are way stronger then the auto. but the clutch is the weak point in the std tranny, it will give away first most of the time. only gave away once on me the other 5 times the tranny went first
__________________
SIX IN A ROW BUILT TO TOW,CUZ WELL WE ALL KNOW , HAVING A V-8 AIN'T THAT GREAT Dodge trucks that havent made life expectancy 96 3500,-175k 98.5 3500 -164k ,98.5 3500-275k, 01 3500-140k, 03 3500 -155k, 07 3500-68k waiting for possible P-Pump conversion and now I'm killing the 06,3500-116k as of 10-01-09 and counting and yes i make my trucks earn a living buy towing professionally |
#6 |
The clamping pressure needed for the kind of torque you can get out of these motors would require more force to depress the clutch pedal than John Q. Public would expect. You can get a nice aftermarket setup from SBC and run your torque up substantially if you are willing to press harder on the clutch. My current setup is too much for the clutch so I have to really baby it. I can slip the clutch in 6th gear with very little effort. In addition to what is in my sig, I have aftermarket injectors and turbo.
__________________
2003 Quad Sport Shorty 4X4 ETH/DEE 3.73AS everything but leather, white/slate, fast coolers, aFe drop in w/torque tube. Mopar Molded Running Boards, Edge Attitude, Jacobs E-Brake, Bedrug, Leer 100XL shell and a Handy Industries Fuel/Tool combo box. ON ORDER 2010 Laramie Crew 4X4 Manual Tranny 3.42AS Pretty Much Everything but a Sunroof. |
#7 |
Have any of you driven a 2010 6spd manual? I did about a week ago and was not impressed at all...I think Dodge has done more than derate the torque by 40 ft/lbs. It was a crew cab shortbed with 3.42 rears, the truck literally didn't want to get out of it's own way, I felt I was pushing it much harder than I should be to get in moving down the road. In comparison I drove a 2009 leftover quad cab shortbed and thought that it had much more get up and go to it. I realize the new trucks weigh a little more, but not to the extent that it should make that much of difference.
I thought manual was the way I wanted to go, but I was much more pleased with the auto. When I'm seriously ready to get one I'm going to have to try both out again just to make sure but I was really puzzled with the initial drive. Any thoughts?
__________________
2007 Chevy 2500HD CC, SB, LBZ Duramax, Allison 6spd, 4" MBRP Catback, Diablosport Predator, Edge Insight Past Toys: 2005 Ford F250, CC, SB, 6.0L Powerstroke, Torqshift, 4" MBRP Catback, AFE Drop-in 2004 Ford F250, CC, SB, 6.0L Powerstroke, 6 spd manual, 4" Banks Turboback, Bully Dog Intake, Edge Juice w/Attitude 2002 Ford F250, EC, SB, 7.3L Powerstroke, 6 spd manual, 4" ATS Turboback Duals, AFE Intake, BD 60hp Chip |
#8 |
Well I have a 2010 3500 CC SRW manual on order - should be built this week. I'll let you know. I prefer to choose my own gears, but I have not actually driven a stick since they are few and far between in stock. Any other experiences with them?
#9 |
I drove a 2009 truck with a manual a while back, and was very disappointed as well. The engine seemed very disconnected from throttle inputs. It probably has a lot to do with emissions control then anything.
__________________
2004.5 3500 4x4 Quad Cab SLT SWR SWB, 6-speed, 3.73 gears - Down for now, but will run again. 315's, MRBP exhaust with Donaldson muffler. AFE Intake, ATS exhaust manifold, SPS-62/14, Edge Hot Juice, Edge EZ, Smarty. 2006 2500 4x4 Quad Cab SLT SWR SWB, auto, 3.73 gears Flux 1.5, Helix 2 cam, studs, valve springs, SPS-62-14, CFM intake, 325/60/20's, 2" leveling kit, Magnaflow 5" ehaust, K&N intake, Bullydog Triple Dog, Xzillaraider(pressure only), NADP Heavy Hauler "Race" Tranny |
#10 |
Do you know if the same clutch and tranny are used in the C&C trucks or do they use a heavier clutch to handle the extra weight?
#11 |
i really liked the manual i had in my 07 2500 ctd with 3.73 gears, no complaints, lots of power too. problem you had was most likely the gearing in the rearend, 3.42 is pretty high gearing for a HD truck- good for mileage on the interstate, but makes the truck gutless off the line and around town. get some lower gears (i prefer 3.73's, best combination of mileage and power/throttle response) and you'll notice a world of difference.
it's always been my understanding that part of the reason for automatic transmission trucks having more power was to sell more automatics- less work for dealerships replacing clutches and easier to sell, the other being that it makes up for the increased power losses through the automatic powertrain. |
| Thread Tools | |
| Display Modes | |
