Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > 12 Valve Engine and Drivetrain
Register FAQ DTR Store Members List Mark Forums Read
Thread Tools Display Modes
Old 11-20-2009, 03:11 PM   #1
TIMMY22
TIMMY22's Avatar
Lost Tach and Overdrive (intermitant)
Truck sometimes looses tach and O/D also stops charging. Starts off in third gear.
Then you start it up the next day, everything is fine till all of a sudden, same thing.
I want to say PCM trouble.
Any ideas?
Thanks in advance!
__________________
96 2500 4x4 Auto, No payments, No silencer ring, KDP barrier installed, Thuren Bar, 4" Strait Piped, Star wheel tweaked, Air Ride Rear, ~177K
92 D250 LE 4x2 5 speed, No payments, No Muffler, No rust, Locktite on Killer Bolts plus KDP, EGT and Boost Gauges on A-Pillar, Fuel screw 1 turn, Smoke screw 2 turns, Timing bump, 366 Spring. 3.54's, ~155K
91 W250 Gas to Diesel Conversion, Auto 727, 3.07's non I/C, Custom Turbo back 4 in. exhaust, KDP killed, Body off Chassis restoration ~216K
TIMMY22 is online now   Reply With Quote
Old 11-20-2009, 05:11 PM   #2
Lil Dog
Lil Dog's Avatar
Have you checked the engine crank sensor? sounds to me like it may be failing once it gets hot, typical of coil type sensors. Its mounted on front of the engine just down beside the water pump pulley facing the balancer.
__________________
97 2500 4X4 LWB CC SLT Laramie 5spd LSD 3.55.
Isspro EV's pyro/boost, #10 Plate, PEAK 3K GSK, AFC Spring, DDP III injectors, S300 Turbo, PEAK IC Boots, TAG III, South Bend 13-1.25" Con FE clutch, SCOTTY II-UNI, MBRP XP 4", KDP Tab, 16° Timing, SS DSS / 03TBK, Roda Deaco PAS. Espar D5WSC heater. B-Quiet sound deadening inside.
Dyno 09-2009 401 RWHP / 1050 Ft-lbs
'08 2500 4x4 MegaCab Laramie, 6.7, 68RFE, 3.73 LSD, S-67ME POD.
Alberta Chapter #5 Prez... PM me for details...
Lil Dog is offline   Reply With Quote
Old 11-20-2009, 05:36 PM   #3
TIMMY22
TIMMY22's Avatar
Oh, the engine speed sensor? the one that you remove during a KDP job?
Old 11-20-2009, 06:12 PM   #4
patdaly
Yep, bet you either have a bad CPS or wiring issue......
__________________
"Brownie"
1997 2500 Ext.cab SLT, 4X4 auto, 3.54 gears, posilock, 98/99 steering conversion. New TC, lovin her again! Sold 3/13/2010, gone but not forgotten.
"Greenie"
1997 2500 Ext. cab SLT, 4X4, NV4500, 3.54 gears, Ready to install SB DD3250, built just 216 trucks after Brownie!
patdaly is offline   Reply With Quote
Old 11-20-2009, 07:26 PM   #5
TIMMY22
TIMMY22's Avatar
Ok,
Thanks!
Old 11-25-2009, 08:46 AM   #6
TIMMY22
TIMMY22's Avatar
Ok,
Replaced the sensor and so far so good!
Dodge wanted $120
Cummins $63
So you know where I ended up.
Thanks Again! Happy Thanksgiving
Old 11-25-2009, 11:34 AM   #7
infidel
It's even cheaper at the autoparts.
The same ESS was used on most Chrysler vehicles of this vintage, plenty popular and available.
__________________
Bill
'95 2500 4x4 auto
'95 3500 5 speed flatbed hauler
stock for one day
infidel is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.7
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2003, DieselTruckResource.Com
