Thread Tools | Search this Thread | Display Modes |
#1 | ||
lost my clutch
__________________
2000 2500 QC 4x4 SWB, loaded w/ leather, 5 spd, white, no emblems, 3" skyjacker, 285/75/16 toyo open country AT's, bug guards, nerf bars, rhino lined, scotty II (w/ hole), silencer ring...gone!, 275 injectors, edge EZ, 4" exhaust, cat...gone, di pricol pillar gauges (EGT=pre), boost fooler, luk pro gold clutch, FASS hpfp ...it's gettin' there |
#2 |
I saw my dealers rate at 82.00 smackers an hour, about a month ago.
__________________
02 2500 HO w/6spd, blue, 2" front leveled, H2 wheels w/BFG 315's, BHAF, Dog ate the silencer ring, straight piped, Edge EZ, 3.55 gears, Diprocal FP, Boost, and Pyro Gauges, VP44 replaced under warranty at 98985 miles, holley blue pusher now and can't go below 22 PSI of fuel pressure. Best mod to date: IT'S PAID OFF. |
#3 |
the LUK pro gold clutch runs about 450-500 bucks...the ceramettalic that holds 550-600hp runs about 560-600 bucks...
#4 |
EDIT...
carolina clutch sells the 5spd LUK Pro Gold series for $325 |
#5 |
I don't know for sure if they screwed you or not but when the clutch is draggin and not releasing completely the problem is most of the time in the clutch relase system rather than the clutch itself. Replacing the clutch master and/or slave cylinder is much cheaper as far as both labor and parts cost. Do you know what parts EXACTLY they replaced? You should also always ask for your old parts back although they could still give you someone else's old parts instead.
#6 |
i saw my old clutch - it was toast. i just think i got hammered on the cost of parts and labor......
thanks for all your replys |
#7 |
I had the exact same problem and put in the Luk Progold but I did it myself. I paid 450 canadian. What happened to mine was the pilot bearing seized so it would keep turning the input shaft. So whether you paid a little too much or not if you would have kept using it you would have ruined your tranny input shaft. Sometimes you just have to get it done.
__________________
1999 2500 Quadcab 4x4 Sport 5 speed Black 4" MAgnaflow Edge Eze Isspro pyro and boost on steering column Holley Black on frame, prefiltered 03 Chrome 17" wheels 180,000 km Let those who ride decide! |
#8 |
I had the same issue. It did not seize, but the neddles fell down inbetween the disk and flywheel. Same result. Replaced it with a oem LUK do to funds. The easier the start the rougher it got. If I had a load on it she was smooth. But if I was empty and slightly down hill it would shake the back of the truck up/down two inchs. After talking with the Distibutor, they replaced it and suggested HD model. Same part # just with an HD on the end. It was a completly different clutch. Disk was slightly larger and differnt dampening. The rated it at 100 'lbs higher then stock. They could not (would not) give me a number. I did find out it has approx. 4000 (or 4500) psi form the pressure plate of compression. Stock was 3500 (or 4000). It was enough to feel it in the pedel.
We had problems a 4BT destroing the damening springs about every 100,000 miles ad would give the same result. It is a little disconserting in rush hour. Randy P.S. It was 215 for the OEM and 270~ for the HD. Jobber price.
__________________
'99 2500 4x2 5 speed 3.54 OPEN 235/85R16 Michelin LTX M/S, 174,000 miles, Topper, Autometer Ultra-lite Boost, Pyro, BHAF w/insulated box, muffler gone. Van Aaken, Holley Black, custom -8 lines and filter (factory mess gone),13" Con FE, BB pilot bearing, Red Tops, Trans Filter '97 2500 4X4 5 speed original clutch (it will slip, Con O in work), 3.54LSD,135,000 miles, QC LWB, Banks Power Pack, Maxxis Mudders 315/75R16, Thuren track bar, KDP MIA, Timing @ 16.5, 5th gear gone for now. |
| Display Modes | |
