Go Back   Dodge Diesel - Diesel Truck Resource Forums > 3rd Generation Ram - Years 2003 and up > 3rd Gen Engine and Drivetrain -> 2003-2007
Register FAQ DTR Store Members List Mark Forums Read
Thread Tools Display Modes
Old 11-20-2009, 01:23 PM   #1
Coyote Man
Loss of fule pressure
I have a 2003 Dodge with manuel transmission that im having trouble with and can not find any one that knows the fix problems are.
1. Loss of fuel pressure for a split second, will go from 15000 psi to 0 and pick back up in a split second
I have replaced both fuel pumps lift pump and high pressure pump, Checked the injectors replaced the O rings and carbon dams.
engine scan does not show any codes at all. And still having the problem.
Has any body heard of this problem and if so what is the fix???
Thanks,
Coyote Man
Coyote Man is offline   Reply With Quote
Old 11-20-2009, 02:57 PM   #2
92'1stGen
92'1stGen's Avatar
What's telling you that it's going from "15k psi to 0"?, do you have a FP? Do you notice it in terms of the power that the truck is outputting? If not, are you sure the gauge is accurate and functioning correctly?
__________________
- 92' W250 "The Tank" - Ext Cab - 4x4 - Cummins 5.9 - Auto w/3.55 - Blue/Silver - 173,100 as of 2/10
___> Isspro Tach, 2nd Gen Auto Shifter with Relocated O/D Button, Repaired Odometer
- 06' Ram 3500 - DRW - Reg Cab - 4x4 - Cummins 5.9 - Auto w/ 4.10 - Patriot Blue - 45,000 as of 2/10
___> Jake Brake, Mopar Steps, Linex, Weatherguard Toolbox, EGR In-Channel Window Visors
"One of the first and the last"
Traded But Not Forgotten
- 04' 1500 - Black - Quad Cab - 4.7 V8 - 2x4
92'1stGen is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.7
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2003, DieselTruckResource.Com
