Thread Tools | Search this Thread | Display Modes |
#1 | ||
Long trip
#2 |
Probly a good idea to take a extra fuel filter just incase. And make sure your back brakes are adjusted properly
#3 | |
Quote:
__________________
90 W250 LE 4x4, Getrag G360 Replaced the IP and Killed KDP and Cap bolts. Estimated 300 K miles (update), odometer quit in 2003...fixed, thanks to the great how to's in the sticky. 8000 LB Warn Winch 91 Gal Axillary fuel Tank, dual battery's, Solar battery charger, disk brake conversion, rebuilt front end and 100% antifreeze 'You do not quit running because you get old, you get old because you quit running', A variation of a quote by Oliver Wendell Holmes |
#4 |
my biggest fear on a long trip would be a fusable-link. that is given the obvious necessities are met. ie: good tires and at least one spare (with a jack and lug tools). topped up fluids (all of them). well greased U-joints. a thorough check of the brakes/steering!
#5 |
Best Paint (Getrag category)
Shoot 1000 mile trip? thats not a long one.
I usually carry a spare tire or 2 W/ chains if going into mountanous areas,alt,WP,belt, tensioner, both hoses and some tools and a pair of jumpers. I also carry some fluids with me too. I have yet to need any of it and since the middle of January I've put about 10000 miles on my 1st gens 8000 of that was on my old 90. Being you got lots of new parts I'd just get in and go.
__________________
90 W250 reg cab, Modified knuder valve, reversed reciprocting dinglearm adjusted, High volume flux capacitor,upgraded whirlygig, A clutch and a hitch 428,500 miles 307hp 672tq uncorrected 4-25-10 July 2008 TOM 93 W350 ext cab dually 5spd Stock 401,000 miles The old mans ride. 91d350 n/ic, 366, getrag,D80 stock afc cone set deep,soon to be intercooled |
#6 | |
| Display Modes | |
