Thread Tools | Search this Thread | Display Modes |
#1 | ||
__________________
2001 ram 2500 4x4 quad cab auto 5inch stright pipe and scotty 2 intake, a scotty smart fuel system with raptor fuel pump and autometer fuel pressure gauge,egt,boost,tranny.and now new mods are quad adrenaline and stage 5 jammers and dtt tranny overhaul done by power by poole..and for air a htt 64/71/14 quick diesel turbo.. next is single 5 or 6 inch stack. |
#2 |
We could help you get a FASS high performance pump or the FASS fuel system with a fuel filter and water seperator filter. Either way it will stop your fuel delivery problems and help you keep that new VP44 running the way it should. 95gph is an ideal pump, but you could always get the 150gph just in case you ever step up to high horsepower....
But seriously you will need some kind of aftermarket fuel pump. Nothing stock is working the way it should to keep our injection pumps alive and well. |
#3 |
Get the guage hooked up and you'll know if/when you need a lp. Are you holding out on guages for the Edge attitude?
You could get a carter from cummins plus a bracket and harness from vulcanperformance and be done for $200. Its worth relocating to the frame for accessibility if nothing else.
__________________
David '02 3500 dually: Smarty/ tst ce/ mach4/ super 62/ helix 2/ 12mm arps / II Pump/ diaphragm sprung hub 3250 SBC dual disk 543/1040 uncorrected 1/12/08 |
#4 |
ive got a holley blue on the frame and it works great. i have 21 or so at idle and no less than 15 at WOT. and thats with a regulator the pump was only 140.00 or so with the regulator.
__________________
98.5 4x4 dually 5spd,4.10s, 315 buckshots, 160hp p-pump, full cut DVs, Mack plug, 3200gsk, Dr Perf 100hp injectors,valair ceramic,HD slave cylinder,Vulcan big line,Holley blue+stock lift pump, custom bent inj lines, custom intake horn 91.5 w250 auto dana 80 dually conversion 3.55s 2nd gen seats, SDX 5.014s, AFC LEVER MIA pull cable 366 spring, power screw extended and 1/2 turn from runaway,12cm timing 1/8 from head, transgo shift kit,single 5" stack |
#5 |
NCdodgeman, Do you have an HO truck?
__________________
99 2500 SB/QC 4x4: 1/8-7.1@88mph 1/4=12.1@109 on #2 only. 95 2500 Reg. Cab 2wd 12v stock for now. http://www.youtube.com/watch?v=fF8ePxWlf3w |
#6 |
no its not the ho model does that have something to do with it?
#7 |
I could be wrong, but my understanding is that the hotrod pump are best put on HO trucks, while SO truck don't benefit much if at all.
#8 | |
Quote:
#9 | |
| Display Modes | |
