Go Back   Dodge Diesel - Diesel Truck Resource Forums > 3rd Generation Ram - Years 2003 and up > 3rd Gen Engine and Drivetrain -> 2003-2007
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 12-07-2004, 01:24 PM   #1
rementa
lift pump?
I just turned 51,000 miles on my truck and the lift pump went out. it's dam scarey when the engine stops running when your driving down the road a 50 mph. what is a lift pump. is it a fuel pump. has this happen to anyone else.
__________________
03 dodge 4x4 diesel quad cab, white, running boards, ventvisors, spray in bed liner, gauges with dash mount, dual exhaust, hummer rims, intake, and xm sat. radio.
rementa is offline   Reply With Quote
Old 12-07-2004, 02:15 PM   #2
AirGrabber
AirGrabber's Avatar
A "lift pump" lifts the fuel from the tank and supplys the injection pump.
__________________
11 2500 4X4 SLT CREW MIDNITE BLUE
05 3500 4x4 QC DRW 6SPD
70 Challenger 340 4spd
71 Road Runner
72 Road Runner 440 4spd
AirGrabber is offline   Reply With Quote
Old 12-07-2004, 03:11 PM   #3
rementa
thanks
Old 12-07-2004, 03:39 PM   #4
GasMan
GasMan's Avatar
Happened to me not too long ago. It took them a week to get the part as well. I think I had about 65 000 km's or pretty close to it.
__________________
2003 2500 SO SLT QC 4X4 SWB Grey, 47RE, 3.73, lim slip, trailer tow, tow hooks, skid plates, fog lights, prem cloth, AM/FM CD Cassette, fold flat, leather wrap steering wheel audio controls, ARE Cover, Bed Liner, Husky Mud Flaps
GasMan is offline   Reply With Quote
Old 12-07-2004, 06:41 PM   #5
rementa
i was told they didn't know how long it would take because it's a star item meaning it's comming from mich. still under warranty though. does anybody know where the pump is located. under hood or diesel tank.
Old 12-07-2004, 08:10 PM   #6
MikeyB
MikeyB's Avatar
The pump is mounted on the backside of the fuel filter housing.
MikeyB
__________________
2003 2500 2wd SWB Quad Cab Laramie, 305/555, NV5600, 3.73LS, Line-X, Westach boost/EGT combo gauge, PML diff cover, Airbox mod, Hurst 6spd Shift ****, Adjustable boost elbow, Toyo OC AT 285/70/17 E, Daystar 1.5" lift, Monroe Reflex, Raptor RP100, Lazarsmith Intake Horn, HID
SMARTY Sr./Van Aaken C3.2
MikeyB is offline   Reply With Quote
Old 12-07-2004, 08:26 PM   #7
Geico266
Geico266's Avatar
The LP is fairly easy to replace, and they should be instock at any Cummins dealer or repair shop.
__________________
"99", 265K on Original VP44 Before it Died.
300K miles And Running Strong!
2nd Full Goerend Bros Tranny & 3 Disc TC
Smarty, 2nd FASS HVLP95, ATS 3 piece exhaust manifold, 4" Exhaust, Fuel-Boost-EGT's, Sears Platinums, Marine 275's, K&N, 285's on stock rims, GMC 1 ton rear brake cylinder, Remote starter, KDP checked.
Now Driving A Ram 1500
Drive It Like You Stole It.
Geico266 is offline   Reply With Quote
Old 12-08-2004, 04:44 AM   #8
Dodgezilla
Dodgezilla's Avatar
Who's got the Cummins part number?????
__________________
04 Green/ Silver Dodge Ram 2500 4x4, 305/555 HO CTD, Custom 4" exhaust, HE351 turbo, VA C3.2
Dodgezilla is offline   Reply With Quote
Old 12-08-2004, 06:35 AM   #9
sawboywv1
Yeah, anyone got the Cummins p/n ? I like to buy one and keep it on the shelf!
__________________
2003,HO CTD,6 spd,3.73,4X4,4dr,LWB,no carpet,crank windows,manual locks,Silencer Ring GONE,No restriction Air Box. Banks S.S. 5" Exhaust tip and Straight Piped! C F M Intake Air Horn
FASS fuel pump. 2 Degrees of Timing. Adjustable Boost Elbow. Diablosport Predator set on Performace !!
sawboywv1 is offline   Reply With Quote
Old 12-08-2004, 07:24 AM   #10
Geico266
Geico266's Avatar
Just ask the Cummins parts guy. I'm sure they will have the number in their head!
The LP is a common replacement item. Some guys get 100K miles other get 30K or less. The next investment you should make is an incab fuel pressure gage to monitor the LP. If it goes bad it can ruin the $1,500 injector pump. $60 for a gauge is cheap insurance.
Search this site for "lift pump" and you'll have hours of reading and great info.
Old 12-08-2004, 07:43 AM   #11
MikeyB
MikeyB's Avatar
Geico266, no damage is done to the common rail injection pump if the lift pump dies. The truck will barely or won't run at all without the lift pump. In fact, the CP3 pump doesn't need a lift pump. But the small fuel lines and tank design require the lift pump on the Dodge. The Duramax has the same CP3 pump but doesn't have a lift pump. The major drawback of not having a lift pump is priming the fuel filter after changing it.
MikeyB
Old 12-08-2004, 08:14 AM   #12
rementa
it will just stop running no warning. i don't think a gauge will help. there were no signs at all. one minute it's running great the next it's dead. just hope it's not while your in the middle of a turn. the steering is really hard with out power. stops fast but steers s####.
Old 12-08-2004, 09:05 PM   #13
Briman
A gauge will confirm the dead pump, no guestion as to whats wrong. I know gauges are not for everyone. I used to carry a lift pump under the rear seat on my '00 after two of them failed. The VP-44 would fail if the lift pump failed.
__________________
Brian Peters, Marion UT
'04 3500 HO 4x4 Long bed QC 6 spd, 3.73 lsd, Jordan brake control, Putco Boss Bars, Glass Tite Cab High Top,
'98 Sunnybrook 29DBS TT
Briman is offline   Reply With Quote
Old 12-08-2004, 09:13 PM   #14
Geico266
Geico266's Avatar
Quote:
MikeyB
I stand corrected. (actually I'm sitting down) I fergot to read the signature. You guys and those dern fangled new trucks. Even if my LP quits the truck will run for quite a long time. I hope
Old 12-08-2004, 09:42 PM   #15
300 SDL
Mine was replaced at about 20k miles. Cam position sensor was replaced at the same time.
Reliable, economical truck.
Dodge would not next day air the pump to the dealer even if I paid the freight.
__________________
'04.5, QC, LWB, 4x4, 3.73, 6 speed, White, Silver Super Liner in bed and on lower sides,Wetokole, BrakeSmart, Pacbrake, Super Duty Air Lift, Kore, custom "antelope/deer swatter" bumpers, Stull boards, Pro Tech box, 3M window tint and clear protector. Every option except GPS, tutone and deflector.
A nice truck with crap fuel mileage.
300 SDL is offline   Reply With Quote
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
