Sign in using an external account
Thread Tools | Search this Thread | Display Modes |
#1 | ||
Is the lift pump required? 300HP
2003/2500 HD Laramie/5.9 CTD SO/automatic /4x4 limited slip positive track rear end/quad/long box/two extra leafs/Trailer Package/ 4" performance exhaust Gauges: EGT, BOOST, TT/Smarty Jr/S&B filter Had truck since new 155,000 km 96312.5 miles |
#2 |
No, Only if you want to run engine.
Grant 04.5 -2500-auto-48re, 4-door, white CDT 2-4-2011, 112,434 miles, still stock |
#3 |
If you are asking if the factory lift pump will handle your setup, yes, it will. Factory lift pumps can be found for $100 - $150 and are much easier and cheaper to replace than more robust systems. Keep a good Baldwin 5 micron filter (or less) in the canister and you should be good.
I have a Smarty Jr and 60hp injectors and my stock lift pump does everything I need. I get the best performance and mileage on the performance setting. I tried the economy but lost 2mpg. The 2003- 2004.5 had poor injectors, I know, I had to replace mine. If you haven't replaced them yet, you will...
2003 Dodge 2500 4X4, 4" Magnaflow, S&B Intake, 60hp injectors, fuel pressure gauge, and Smarty Jr. |
#4 |
#5 | |
Quote:
#6 |
Under normal driving conditions my canister mounted pump worked great when I was running my Van Aaken box. On the dyno, however, you could definitely hear the engine breaking up because the LP could not pump enough fuel to it in the high rpm range. I think my truck was only putting out maybe 310-320 rwhp too.
04 Green/ Silver Dodge Ram 2500 4x4, 305/555 HO CTD, Custom 4" exhaust, HE351 turbo, VA C3.2 |
#7 | |
Quote:
#8 |
Redline. I'm not exactly sure how high they go with in on the dyno but I doubt they go past the redline....
#9 | |
Quote:
5 micron filter. Baldwin pf7977 $21.79 Acklands Toronto |
