#1 |
Lift pump advice
A buddy of mine has a 04 dodge 2500 and his lift pump is going out. He wants to go with an Air Dog set up. The question is which model would be the best for him? His truck is just stock other than a cold air intake and exhaust and his truck was built 6/04 so what is it, 04 or 04.5? Any help would be great!
__________________
2005 Dodge Quad Cab 3500 Dually 4x4 Lone Star Edition w/ 6speed, Aem brute force cold air intake with amsoil filter, 4" straight pipe exhaust with mega cab resonator and 5" tip, cat MIA, silencer ring MIA, RanchHand Grill Guard, Bradford Bale Spike bed, Limo tint, Stainless fender trim, DeeZee Diamond plate runner boards,Auto meter dual pillar mount w/ egt and boost guage,Cooper STT 265/70/17 tires, SMARTY!!! 2000 Pontiac WS-6 Trans-Am SAC #76 |
#2 |
DTR 1st Sergeant
He can go with the 100gph. That alone will support over 700hp.
__________________
2004 3500 QCSB Laramie SRW 4x4, CA emissions SO 235hp, 3.73 posi, Peak Performance BB Twins, engine by Diesel Nut, Almost stock DTR "Twins" Club Member #1 11.89 @ 119.2 mph 1/8 mile= 7.76@94.94 mph 900.86 rwhp/1689.76 tq @ Left Coast Diesel 21 AUG 09 TNT member #2 SAC member #9 |
#3 |
DTR 1st Sergeant
On the other issue, have him check his valve cover on the drivers side, the HP rating is there. If it is 325hp/600tq then he has a 04.5, which is what I believe him to have. If it is 250 or 305hp, then he has an 04.
#4 |
The Admin that's here for you!
He needs to know what it is... if it has a canister mounted lift pump he has an 04.5. Look at the build date on the door. After 01 Jan 04, it is an 04.5, along with the valve cover data sticker.
It depends. If he defiantly is going to stay stock, go with the 100. If he has any doubts... go big.
__________________
Mark 04.5 3500 SRW 4X4 Smarty REVO PoD, MP8, HTT 64/71/16ss, Flux 2.5, ARP studs, ATS stage 4 with aftermarket output, Snow stage 3 water/meth, AD 150, Arson II CP3 mod. 37" BFG KM2 MT's on stock rims and ride height. 636/1266 fuel 868/1778 on a little spray David Dunbar's dyno, 7 Nov ![]() 12.46 @109 Coastal Plains, Oct 08 Many thanks to Lary Ellis and the DTR store, ATS, Don M, and Bob W... madhat@dieseltruckresource.com |
#5 |
I have the 2006 325/610 and the AD-100 GPH would have been sufficient for my truck because it is a stock engine overall, just a few intake/exhaust mods. I decided to go with the AD-150 GPH and will be installing it next weekend. If I decided to go up a little with 90hp injectors, maybe get the 'bag of parts' for the cp3, camshaft, and bigger turbo down the line, I still would not be pushing the margins of the pump. There is a rule of thumb regarding pumps, I cannot remember the exact number that applies, but it goes something like this - install a pump that has somewhere around 35% more power capabilities over what you think the max of the pump needs will be . . so, the 100 would have done the job with little to spare, and the 150 is 1/3 greater. Anyway, you should get the overall idea. I believe that I read that statement in Corky Bell's book, Maximum Boost. The text is basically about designing, testing and installing turbochargers for the gassers, but, much/most all of Bell's information in that text is the standard when it comes to turbo theory. He discusses fuel needs, rail needs and exhaust needs to support turbochargers.
CD
__________________
2006 SRW 3500 CTD 4x4 MC, G56, 373LS. CBH/Ice Box, GDP Intake Horn, Fab Shop Header, ME. PRXB. BMK-11, GDP 2-micron/big lines. ISSPRO EV2 gauges. Smarty Jr. Opie. KORE Leveling, Bilstein 5100's all around, Firestone RideRites, Helwig Rear Sway. BFG AT KO 315's on H2's. Road Armor fr bumper, Milemarker Winch, Ranch Hand r bumper & Headache Rack. Fender flares, stainless rocker panels, Dura Flaps. |
#6 |
Thanks for all the info guys, I will be sure to pass it along!
| Thread Tools | |
| Display Modes | |
