Let's Screw-Up Your Steering Column With A New Tachometer and Gear Shifter!
#31
I'm thinking if you just take this Part # 4690522AB to your local dodge dealership you'll be fine. But to answer your question, I don't know. I'd guess all second gen trucks with an auto used that button shifter. Try hitting the local scrap yard to try to find one.
#34
Location: Lingleville TX but active duty Air Force all over the world currently
Well, I guess I didnt do to well. I just paid 40 for one shipped to my door. The dealer prices i saw were higher than 30.00 so i thought i was doing good, Oh well.
#35
I lucked out and found one in a boneyard. It was a gasser so be stuck just checking diesel trucks. I picked it up for $15 Works like a charm! I removed the original switch but kept the plug intact on the harness. I then installed a 3mm amber LED in the tach pod & wired it to the plug.
Stalk switch connections
Pod OD light connections
OD Off
OD on
OD On @ Night
BTW, I checked at a dealer here for the shifter stalk and they wanted over $100 for one!
OD Off
OD on
OD On @ Night
#36
I did the 2nd gen shifter mod on a 92 and a 93 . I did as suggested and hooked the switch up in parallel . and in both cases the od light works off the column switch , just for any one who wants to know.
#38
Just wondering about how much visibility did you loose of your speedometer?
Looks like you might loose sight of the trip odometer, PRND12 and the high side of your speedometer.
Might be ok for most people but for someone with OCD it could drive them crazy
Jim
Jim
#40
Received 1,637 Likes
Thank you David.....
Your help was truly appreciated, as the ISSPRO R5503 worked great. and GENO's was a breeze to purchase from.
..although my video skills are a little lacking. It's a little wobbly... sorry....
#41
Just thought I'd add some info here. If you have an older Isspro R-1604-4, 4K tach...it will not fit the steering column single pod holder due to the housing for the light that sticks off the back of the tach by about 1/2".
It will go into the gauge pod, but bottoms out about 1/4" shy of sitting flush. So I'm off to find a good deal on a new Isspro R5503 tach.
#43
Besides the 89 D250 I have a 03 hemi that I moved the OD function to the buttons located on the back of the steering wheel. These were originally for radio controls which my truck didn't use. The OD function is just a momentary switch, so any momentary switch will work. I want a tach on my 89 and have bought a harmonic balancer with grooves, oem mag pickup and mount. I'm hoping I won't need a PCM interface and wire it like a standard magnetic pickup. We will see. Great write up.
#45
question on lets srewup steering cloam i locataied the factory plug but my wires
located factoty tac plug but my wires are different colors they are gray /w lire blue srip then black orange then back looked on my 89 parts truck and its the same i have a1992 d350 5.9 a isspro gagage that was reffered to what would be the proper way to wire it please help !!!!!
