Let's Screw-Up Your Steering Column With A New Tachometer and Gear Shifter!
Old 10-29-2007, 02:53 PM
rockfoot's Avatar
Question
I thought the Issopro was too long to fit into that pod?... I bought the ISSPRO (R8501) and it don't fit the pod.... too long... what is the fix?? Is there a fix?? Do I have to cut the back out of the pod to make room for the light ?
Old 10-29-2007, 05:02 PM
1st Generation Admin
BC847's Avatar
I have no experience with the R8501.
In this application, I used the ISSPRO R5503 (0 ~ 4000rpm).
Old 10-29-2007, 07:36 PM
ofcmarc's Avatar
Even the autometer tach won't fit in an autometer column pod with out cutting the studs off a bit.
That's why it's a custom install.
Old 09-10-2009, 05:05 PM
victoroneill's Avatar
Excellent write up. If I get my old Motorola Tach to work I'll get back to you.
Old 09-10-2009, 05:17 PM
1bad93's Avatar
i really got to get around to gettin one of them for mine and this just re-enforced it. nice job man looks sweet!
Old 09-10-2009, 05:42 PM
NotEnufGarage's Avatar
Is this the pod you used?
http://cgi.ebay.com/ebaymotors/New-A...Q5fAccessories
Old 09-10-2009, 05:58 PM
Yea thats it. only works on 91-93's though.
89-90 have totally different steering columns.
Old 09-10-2009, 07:50 PM
oilcan64's Avatar
hi
just found this- for anyone looking to do this mod here is a link for the gauge pod
http://www.statracing.com/buy/autometer/pn/15012.asp
right? is that the one as described?
Old 09-10-2009, 08:42 PM
921stgen's Avatar
Yes oilcan64, that the same thing, both are right. Alot of places sell them and the price verys 20-40$. so shop around.
Old 09-10-2009, 10:21 PM
schamran's Avatar
Are you guys sure they only fit the columns with tilt? Really? Thanks
Old 09-10-2009, 11:11 PM
Rick 12v CTD's Avatar
the OD buttom on the shifter is brilliant... I like that idea a lot actually. Having to lean over the the lower area of the dash is kind of annoying to say the least
Old 09-14-2009, 06:50 PM
Good thing I put a '91 tilt column in my '90.
Old 09-15-2009, 12:35 AM
archer2's Avatar
Genos sells it also
http://www.genosgarage.com/prodinfo....er=GM-DG-15012
Old 09-15-2009, 04:27 AM
Jungle's Avatar
I just found this thread. GREAT job on your write up!!!! I'll have to add it to things to do.
Old 12-07-2010, 06:58 AM
zack_76401's Avatar
Location: Lingleville TX but active duty Air Force all over the world currently
What all 2nd gen years came with the OD button on the shifter?
Quick Reply: Let's Screw-Up Your Steering Column With A New Tachometer and Gear Shifter!
