Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > Performance and Accessories 2nd gen only
Register FAQ DTR Store Members List Mark Forums Read
Thread Tools Display Modes
Old 08-18-2006, 06:55 PM   #31
Katmandu
Katmandu's Avatar
Thumbs up
Quote:
Originally Posted by P.J
Your Order ItemCost1 42790 Air
Filter
$29.41Subtotal: $29.41Shipping: $10.32*Total: $39.73
__________________
1998 12 Valve, loaded SLT Laramie, QC, Short Bed, 4x4, 5 Speed, Leather, #10 Plate, 3K GSK, BHAF, Timing 16.5*, Waste gate Blocked, AFC Forward, 4" Straight Exhaust, Turbo Silencer Gone, KDP Killed, '03' Track Bar, DSS bar, 3.54 LSD gears, 285/70 Revos. 400 HP/923lbs TQ
Click the link below for some pics.
http://katmanduonline.net/pics/98_Ram_CTD/
Katmandu is offline   Reply With Quote
Old 08-18-2006, 07:04 PM   #32
Kroner
Kroner's Avatar
Does the BHAF flow more than the K&N cone filter?
__________________
1996 2500 ex-cab long bed, Kolbs Pump, FASS, 435s, 16.5*, K&N, SP66, 4K GSK, Snow Stage 2, SB DD
Kroner is offline   Reply With Quote
Old 08-18-2006, 09:10 PM   #33
SSweeney
Do I need one under 300hp. Does it lower egts any? I am still under warranty. I quess I would have to put back on orignial in needed.thanks
__________________
2002 2500 quad Laramie slt 4x4 auto, edge ez, DD tranny pan,afe filter, bilsteins, egt,boost,fp guages
07 plans-DTT TQ.VB
SSweeney is offline   Reply With Quote
Old 08-19-2006, 09:38 AM   #34
Clunk
Clunk's Avatar
Question
I'm considering the air temperature under the hood. In cool weather, my BHAF is ok but it's HOT out there now and the Scotty with the big cowl inlet would get cooler outside air to the turbo which means more hp.
Does the Scotty flow as much air as a BHAF?
__________________
'01 2500 4x4 Red QC Sport HO SWB, 6spd.,cowl hood, 4" ex., BD Comp wire tapped, Banks boost & pyro pillar mount, single Carter 4601hp lift pump next to the fuel tank Sept. '04, US Gage & 5 grease gun lines for fuel pressure monitor, Power Service in the tank, Amsoil in the trans and Valvoline in the pan, Vulcan Big Line kit, 8psi WOT on 3X5, BHAF, cheapo fuel cooler, big hole injector nozzles, Cat C300G 62-65-.70a/r
What's yer lift pump fuel pressure?
Clunk is offline   Reply With Quote
Old 08-19-2006, 01:39 PM   #35
dodgeguy71
dodgeguy71's Avatar
I checked air temp with a digital meter in the cab and the lead hooked right on the bhaf. It was in the high 80's or low 90's when I checked. In VERY heavy stoplight traffic the under hood temp of the filter was as high as 100-103 I think is the highest I saw one day. As soon as I started, fan would blow and you could just about watch the numbers starting to drop. I got on the highway and started to go and it dropped down to like 78-80 degrees. I don't do much city driving so that temp for as little as I care to be in the city is no big deal.
__________________
02' something 4x4 5 speed BHAF w/outerwears , American Eagle wheels, Arrowcraft dually conversion, Diablo Sport Power Puck, Dipricol, Fuel Pressure, boost, Pyro, AMSOIL 15W40 plus filter
One of Uncle Sam's Misguided Children
dodgeguy71 is offline   Reply With Quote
Old 08-19-2006, 02:12 PM   #36
RJF
RJF's Avatar
Quote:
What kind of ambient temps? I have the Juice, which reads intake temp in the manifold and have seen 135* on 100* ambient temps. In cooler weather I am under or around 100* intake temp.
Here is my BHAF and custom air box I made.
A new filter that has just hit the market is the Amsoil 4090. These are nanofiber synthetic filters that do not use oil, can be blown out and reused, and flow more than a BHAF and a little less than a bad filtering oiled filter. I would have one if they come out with a red color line.
__________________
2001.5 Ram Cummins 2500 4x4 ETC.
Red Sport QC long bed, black leather, billet everything, flip out mirrors.
EDGE HOT JUICE with attitude/ 5" MBRP exhst, Axiom/Suncoast trans, Amsoiled up.
2002 Ram Cummins ETH H.O. 6 spd 3500 4x4.
Black sport QC longbed DRW, black leather
DonM Mach 1.6's, SB Con OFE, guages, Amsoiled up.
RJF is offline   Reply With Quote
Old 08-20-2006, 06:37 AM   #37
Clunk
Clunk's Avatar
Thumbs up
Kroner, I like the BHAF lots better than my K&N...turbo inlet wheel is cleaner too.
SSweeney, Need one? nope, but if you want a greater airflow capacity and turbo sounds, the BHAF lets sound out as good as it lets air in.
Nice box RJF, right color too.
On 100 degree days the turbo compressor really heats up the air...I can't hardly touch mine after getting home and motor idling. The aftercooler cools it back down near ambient before it goes to the engine intake.
Dodgeguy's temperature research indicates there's alot of air under the hood and some doesn't go through the radiator.
Another benefit of a cowl air source is a possible air pressure improvement to the turbo inlet at highway speeds. There was a seat of the pants power improvment at a 70 mph punch between the scoops on my long gone '70 W-30 open vs stuffed with towels.
Old 08-20-2006, 08:15 AM   #38
TRCM
Well, I have put a BHAF on the flow bench, and it flowed more air than the bench could measure...I'm curious as to what these other brands really do flow.
TRCM is offline   Reply With Quote
Old 08-20-2006, 11:01 AM   #39
Clunk
Clunk's Avatar
Thumbs up
Do you mean the water column(red) wouldn't even come up to 1"?
If you get any inches of water, you can do a conversion as described in the Superflow black book.
Old 11-24-2006, 09:06 AM   #40
Marine
Marine's Avatar
Send a message via MSN to Marine
Just to set the story on the Marine version BHAF straight:
It is the same as the BHAF, except that it has a wire mesh internal. This is in case the filters do get wet, the suction will not pull the wet media into the turbo. It is unnecessary for our trucks.
If you search back to my posts in01/02, you will see the specs on the research I did.
__________________
Mike
2001.5 2500 4x4 QC, Comp, NADP 91% Single Disk TC and Series 450 Trans., Pulse/Adrenaline, Amsoil Nanofiber 4510 Air filter, Vulcan Performance and GDP Fuel System, Tow & Camp Pkg, JRE 4", High Idler, Isspro EGT, Man. Press and Trans Temp, Nordskog Digi. FP Gauge, Back-up lights. HTB2 62/13SS, HTT Pulse Manifold, Silicone boots, DDP 95 HP Sticks. BMK-11 Bypass Amsoil throughout. NRA Member and Instructor.
"Make no mistake, our freedom will be defended." GWB
Marine is offline   Reply With Quote
Old 11-24-2006, 01:48 PM   #41
1-5-3-6-2-4
1-5-3-6-2-4's Avatar
Love the sound
__________________
Luke
'97 Chevy V3500 CC DRW 6BT 22" Alcoas
'98.5 24v 2500 QC 5spd 4wd Demon hot-rod *sold*
'90 VW Jetta 1.6L oilbrnr 5spd coupe wolfsburg
'73 RS/Z-28 Survivor.
1-5-3-6-2-4 is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.7
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2003, DieselTruckResource.Com
