Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > 1st Gen. Ram - All Topics
Register FAQ DTR Store Members List Mark Forums Read
Thread Tools Display Modes
Old 08-28-2008, 03:46 PM   #1
cfarmer
Exclamation key swich
shuttruck off the tummbler came out with the key. i tried to put backin but it jumbs back out
cfarmer is offline   Reply With Quote
Old 08-28-2008, 04:12 PM   #2
NotEnufGarage
NotEnufGarage's Avatar
I think there's a clip or pin that holds it in. Yours must be broken.
__________________
1990 W350 5.9L CTD G360 GV O/D 3.54:1 255K Cast Elbow to 4" 2nd gen DP to 4" Magnaflow to 5" tip, BHAF, 366 spring, DennyT StageII Fuel Pin, 16cm, 60mm, 3" Crosspipe, Custom fuel filters (10, 5, 2 micron), Isspro EGT, Boost, Tach, 12K winch, double tube rollbar with 6 x KC Daylighters (800 watts total) - Dyno 214/520 w/ pump detuned
1979 Li'l Red Express 360 4BBL
1974 Duster Super Six
1970 Challenger R/T Clone
1970 Charger Daytona Clone
1970 Charger 383
2001 BMW 750iL
2009 PT Cruiser
NotEnufGarage is offline   Reply With Quote
Old 08-28-2008, 04:16 PM   #3
HappyCamper
HappyCamper's Avatar
you might try inserting it like this
(from repair manual)
1. make sure truck is in park (if auto)
2. with key cylinder and ignition in lock position, insert cylinder into ignition switch assembly until it bottoms.
3. Insert key, push inward on key cylinder, then rotate key clockwise to end of travel.
4. check each position
This assumes that your lock is not wore out. There is a pin that normally has to be depressed in order for the lock to be removed. If that or other part have worn then a replacement is in order.
__________________
Rich
'91.0 D350 Getrag 5spd, 2WD Dually, Cab/Chassis (159" wb) with Sleeper and 9' Flatbed. 200k club
HappyCamper is offline   Reply With Quote
Old 08-28-2008, 04:55 PM   #4
wannadiesel
Ad-meany-strator
If you can't get it to go back together, we'll mess with it Monday.
__________________
wannadiesel@dieseltruckresource.com
'93 D350 - DPS 6x16's, HTT Stage IV/14wg, PowerStroke IC, Snow water/meth, Walbro 392, Con-FE, pump tampering by owner.
386 HP/774 TQ on #2 only, 408 HP/844 TQ w/ water/meth - needs more air!
"Butterscotch" - '82 Mercedes 300TD
KDP body count: 72
wannadiesel is offline   Reply With Quote
Old 08-28-2008, 05:09 PM   #5
cfarmer
that will work dave. being left handed it out of comishion the rgiht just ant the same. one thing for sure is i have MORE RESPEATE FOR A GERINDER!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.7
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2003, DieselTruckResource.Com
