Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > Performance and Accessories 2nd gen only
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 03-29-2006, 02:40 PM   #1
Sea:\>Drive
Sea:\>Drive's Avatar
J-hook Install - Do I need one?
I recently installed a Van Aaken box on my truck and am currently loving the increased response with it. Since I have an '01.5 with the solid tube, an elbow wont work, so through research I've found the j-hook solution. So after playing under the hood and looking, the wastegate actuation mechanism seems to be buried under the turbo.
1st - do I need one? Does it totally block the wastegate? My turbo comes up quick and occasionally breaks the 21lb barrier (by .4lbs at most). Am I going to have issues after installing one?
2nd - how the heck to you install it? I can't get my meat hooks under the turbo to even touch the darn thing. Does the turbo need to come off to install one of these buggers?
Just curious to hear anyone elses experience with the VA and j-hook. I love it now, but more ooomph for ~$25 bucks sounds like a winner to me.
__________________
'01.5 2500 CTD QC SB SLT 2WD, Auto (Goerend), 3.54LS, TruxPort, J-hook, AEM Workhorse, Boost/Pyro/FP/Trans Temp, 4" Pinnacle Power Exhaust, Vulcan Big Line Kit w/Raptor, Edge Comp, DD1s, DEI Remote Starter, KoolVue Tow Mirrors, 20% Tint, LED tail ,brake, and turn signals and HIDs.
Keith
MD DTR Chapter #33
TOM June 2008
Sea:\>Drive is offline   Reply With Quote
Old 03-29-2006, 03:49 PM   #2
Gotlift01
Well I don't have a J-hook on mine but I do have a turnbuckle and mine is completely locked shut.
The J-hook still allows the wastegate to operate, it just holds the gate shut longer to build more boost.
They are kind of a bugger to get to, I had a heck of a time getting my paws under there but I somehow managed to do it. Taking the turbo off would be the easiest way to get to it......but that might end up turning into more work than needed.
I definetely recommend one though........not only does it add performance but also helps cool your EGT's with more boost!!
~Nick
Gotlift01 is offline   Reply With Quote
Old 03-29-2006, 08:10 PM   #3
Sea:\>Drive
What kind of boost numbers are you seeing? You've got more of a box than I do, but I'm curious. I guess no one with a J-hook is reading tonight?
Old 03-31-2006, 02:38 PM   #4
ib516
ib516's Avatar
Post I have a J-Hook
I have one, but I don't have a boost gauge. I think if you add one, you also need to add a boost fooler that plugs into the MAP sensor (unless the box you are running has one already).
It it relatively easy to put on. It connects solidly to the round diaphram pot portion of the wastegate on one side, then has a spring, then has a J-hook at the other end that attaches to the wastegate valve. The J-Hook does not prevent the gate from opening, just delays it until higher boost is reached. I think stock is ~ 20 psi, J-hook is ~28 psi. It is possible to get to it from above, easier to reach, but it is hard to see from up there. Easy to see from under the truck, but harder to reach unless you have long arms or a tall creeper. I did it with help from my BIL. He was under the hood, me under the truck on a creeper. Hope that helps.
If you get one and install it (good idea), let me know what kind of boost #s you see B4 and after.
__________________
2007 3500 SRW Megacab 4x4 5.9L Cummins w/48RE and 3.73 rear
Hypertech Max Energy, 4" MBRP turbo back, built 48RE
DTR Megacab Club Member #218
ib516 is offline   Reply With Quote
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
