Isspro EV Fuel Pressure Gauge?
Old 04-23-2014, 09:56 PM
209trucker's Avatar
Hey guys.
Fuel pressure gauge just came in so I was gonna install it. But honestly I'm sorta confused. The two tapped inserts on the isolator only have 1 fitting that fits. So what am I supposed to do with the other side? The black plastic fitting will thread into the isolator, but I don't really know how to get it to the fuel supply? It what the plan was for some of these fittings? I'm just really confused and any help would be greatly appreciated.
The fitting circled in red doesn't go to anything? It doesn't thread in anywhere, and the tapped side is the same size as the threaded parts on the isolator. And the fitting in green is what threads into the isolator and I'm assuming is for the hose that goes to the gauge.
But then I don't know what the 1/8" OD black hose is for??
Old 04-23-2014, 10:02 PM
peckens's Avatar
You don't need everything in the kit honestly. It is kind of a universal kit. The only thing I see that you do not have is the tapped bleeder bolt that replaces the original. I got mine through DAP when I ordered the gauge.
To install starting from the block to the gauge.
Tapped bleeder bolt-> large fuel line-> isolator-> compression fitting-> small fuel line-> compression fitting -> gauge
Here is a good reference to follow.
http://www.genosgarage.com/installat...FPIsolater.pdf
Old 04-23-2014, 11:07 PM
209trucker's Avatar
I have the replacement banjo bolt. There just isn't another fitting for the isolator in the package
Old 04-24-2014, 08:55 AM
peckens's Avatar
The fittings arent anything special, you can get them at any hardware store or autoparts store. Ill try to get some pics posted tonight, if you need help still.
Old 04-24-2014, 03:54 PM
209trucker's Avatar
Did you just use fuel hose to run from the isolator to the banjo bolt?
Random Acts
12-16-2007 02:04 AM
65pacecar
10-01-2007 09:18 PM
quadstar
09-27-2007 09:52 AM
66fordcrewcab
03-21-2007 01:47 PM
deezulsmoke
0
03-21-2005 09:59 PM
Quick Reply: Isspro EV Fuel Pressure Gauge?
