Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > 1st Gen. Ram - All Topics
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 07-18-2007, 03:59 PM   #1
Hawthorne
Intercooler plumbing questions
I'm putting together the needed parts to install a PSD i/c and a crossflow rad on my 90 CTD and I'm wondering the best route to plumb the cold side of the i/c.I could put on an intake elbow that points to the front of the engine and then a few bends down past the injection pump to the i/c.I'd like to use the cooler tubz from Tworline, but turning the tube forward to clear the master cylinder will block one of the intake/grid heater bolts.Is it possible to change the one bolt for a stud, lock it in place then slide the heater and intake tube on top?
__________________
1990 W250 5 Speed 4X4, Autometer pyro, tach & boost. Old Smoky pin, fuel screw maxed,366 spring, BHAF with home brew CAI, BD 40hp injectors,18cm/StageIV, Powerstroke Intercooler,3" Coolertubz,crossflow rad, BD exhaust brake with 60#springs & 4"straight pipe from exhaust brake . Rear air bags. New 7mm head.
Hawthorne is offline   Reply With Quote
Old 07-18-2007, 04:17 PM   #2
rbrettctd
rbrettctd's Avatar
To clear the master cylinder all you have to do is flip your intake plate-the plate thats under the grid heater. I just did mine-you will have to fab up some fuel line braces, and either go to an intercooled style throttle bracket or make an extension to use the one you have, I did this, will get pics tomorrow.
__________________
Randy
The New Rig: '99 QCSB 2500 4wd auto. Smarty, 35/12.50/17 tires, otherwise stock...
Traded:
1991 D250, 7.3 intercooler, DennyT stg 2 pin, POD's, HX35 (14cm), SB3250 DD clutch, custom intake and cooler tubes, SW Fab bumpers, Headache rack, homegrown grille inserts, piston LP
rbrettctd is offline   Reply With Quote
Old 07-18-2007, 04:43 PM   #3
Hawthorne
Do you still have space between the heater and the fuel lines? Looking at pics of i/c engines the heater sits on the next set of intake bolts which puts it real tight to the fuel lines?
thanks Andrew
Old 07-18-2007, 07:28 PM   #4
dpuckett
You can also get a 2nd Gen intake horn, which angles toward the front. This gives a two-fold advantage- it is bigger (3" instead of 2-1/2), and it smooths flow to the intake. I didnt get real detailed in my measuring in my 91, but I think it could work for you.
ANother option is to flip the intake plate, and get some intercooled lines and clamps.
Daniel
dpuckett is offline   Reply With Quote
Old 07-18-2007, 09:51 PM   #5
rbrettctd
rbrettctd's Avatar
Ya Ive got clearance between heater and lines, but they are close enough to make it easy to create new brackets. Ill snap some pics tomorrow.
Old 07-19-2007, 03:35 PM   #6
Hawthorne
Thanks guys for the input and options .Randy I searched back and found a pic of your intake plate and horn, nice polished set up!
Andrew
Old 07-20-2007, 08:50 PM   #7
rbrettctd
rbrettctd's Avatar
My fuel lines will be REAL close to rubbing, so Im gonna take some 1/4" rubber fuel line and slice it to go around the line and zip tie it in place.
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
