Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > Performance and Accessories 2nd gen only
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 06-11-2007, 05:52 PM   #1
EverydayDiesel
EverydayDiesel's Avatar
Installing A Transmission Temp Gauge
Do you have to drop the pan and tap a hole to install an transmission temp gauge on a 2001 CDT auto?
__________________
2007 6.7L A6 - !DPF !EGR, Smarty, Edge Insight
2001½ CDT 24V Auto
Mexi-block, BFAF & shield, Silencer ring lost, Juice w/Attitude, FASS Pump with Air/Fuel Separator
Please give a few bucks to help this site!
EverydayDiesel is offline   Reply With Quote
Old 06-11-2007, 08:09 PM   #2
Roadrunner
Roadrunner's Avatar
I have been wanting a trans guage also.I was going to get a manifold from Summit or Jegs and plumb it with that.I think we can do it in the return line.
__________________
00 Laramie,174,000 miles,Edge EZ box, straight piped 3", BHAF w/outerwears, FASS I pump, fuel guage, 2nd VP44. New trans & billet converter!
Roadrunner is offline   Reply With Quote
Old 06-11-2007, 08:16 PM   #3
2500Ram
2500Ram's Avatar
You want it in the hot line not the return. Either way, a gauge in pan, hot line or return line is better than no gauge.
http://www.dieselmanor.com/dm_products/DM-CLG2.asp is pretty popular for the hot line crowd, I lost maybe a 1/2 qt of ATF installing this line.
Good luck.
__________________
2002 Dodge Ram 2500 CTD, 47RE SB QC 4X4.
Edge EZ, Full Set Autometer Ultra Lite Gages, TST J Hook, Walbro GFS-392 LP, 17 idle 13 WOT, Silencer Ring Back On, Mystery switch. 95,000 on the clock. Dave Goerend trans 48RE input, triple disk, VB and a few other goodies:)
New VP-44 5-23-08 warrantied by Dodge
2500Ram is offline   Reply With Quote
Old 06-11-2007, 08:41 PM   #4
Roadrunner
Roadrunner's Avatar
This site rocks! Thanks 2500RAM!
Old 06-11-2007, 10:16 PM   #5
EverydayDiesel
thanks ram...thats alot better then dropping and tapping the pan
Old 06-11-2007, 10:38 PM   #6
1stGen545
1stGen545's Avatar
Use the manifold. It is the only good accurate way to get the real temps. in the pan is after it goes threw the cooler and back into the pan maybe 50* cooler than it realy is.
__________________
92 350 4x4 srw over 500,000 miles POD's, full 5" home made exhaust, HX35-12cm, K&N ,pump mods, SouthBend Con FE, NV4500 DennyT Power Pen, timming maxed, 3200GSK, auto meter pyro & boost, and PULL CABLE KILL. 96 2500 4x4 SLT with to many mods to list. '08 Inferno Red, Lone Star, 6.7, 68RFE auto, 4X4, QC, SB, EDGE ATTITUDE, 305-65 BFG KM II's Big Mac and cheese button, More to come.....
1stGen545 is offline   Reply With Quote
Old 06-12-2007, 02:18 AM   #7
wcbcruzer
wcbcruzer's Avatar
There is a cheaper way you can do that.
http://www.dieseltruckresource.com/d...apa+temp+gauge
__________________
1996 Ram 2500, Club Cab, Long Bed, 4x4, 47re, 3.54
wcbcruzer is offline   Reply With Quote
Old 06-12-2007, 07:39 AM   #8
74dart
74dart's Avatar
I used the adapter from Diesel Mannor that plumbes it into the Line Pressure check hole. Cost $14.00 for the adapter.
__________________
96 4x4 ext cab LB, #10 Plate Factory Position, 3gsk, s-300 turbo, 4" straight exhaust (homemade glasspack in the works).
Quote:
Originally Posted by PoorMansCat View Post
I had a Detroit diesel calendar one time; I had to return it to the dealer and file a warranty claim on it due to it leaking oil all down my wall!!
04 30' Wildcat Fifth-Wheel
89 Jeep YJ, 2.5" lift, 31x10.50s, powered by a stock TBI 5.2l v8.
/],[____],
l---L –[]lllllll[]-
()_)-()_)--o-)_)
74dart is offline   Reply With Quote
Old 06-12-2007, 08:51 AM   #9
EverydayDiesel
another option i have been looking at is a double deep pan.
it has the 1/8 npt fitting for temp sensor built in
http://www.genosgarage.com/prodinfo....=MH-727DD-9803
Old 06-12-2007, 12:43 PM   #10
Sea:\>Drive
Sea:\>Drive's Avatar
Less than 10 bucks and it's done! This is what I used on my '01:
http://www.genosgarage.com/prodinfo....ber=VULCAN_VTA
__________________
'01.5 2500 CTD QC SB SLT 2WD, Auto (Goerend), 3.54LS, TruxPort, J-hook, AEM Workhorse, Boost/Pyro/FP/Trans Temp, 4" Pinnacle Power Exhaust, Vulcan Big Line Kit w/Raptor, Edge Comp, DD1s, DEI Remote Starter, KoolVue Tow Mirrors, 20% Tint, LED tail ,brake, and turn signals and HIDs.
Keith
MD DTR Chapter #33
TOM June 2008
Sea:\>Drive is offline   Reply With Quote
Old 06-12-2007, 02:17 PM   #11
wcbcruzer
wcbcruzer's Avatar
Pan is ok, but hot line is better. That's where mine is going...
Old 06-12-2007, 02:25 PM   #12
DL1221
Quote:
Exactly.
See this post for more info:
http://www.dieseltruckresource.com/d...=1#post1550103
__________________
  • 1996 12-Valve, 2wd, 2500, Auto, Reg Cab, 3.54 Gears, 92k Miles, KDP Fixed, Timing 16°, Full Gauges, 215 Injectors, 100 Plate, 3k GSK, AFC Spring Kit.
  • 2001 24-Valve, 2wd, 2500, Auto, Quad Cab, 4.10 Gears (I hate them), 90k Miles, Full Gauges, Carter Campaign Pump.
DL1221 is offline   Reply With Quote
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
