Go Back   Dodge Diesel - Diesel Truck Resource Forums > 3rd Generation Ram - Years 2003 and up > 3rd Generation Ram - Non Drivetrain - All Years
Sign in using an external account
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 04-21-2009, 01:12 PM   #16
chadder1313
chadder1313's Avatar
Before i did all that work and purchasing different units to make the factory HU work; I would buy a aftermarket HU and wire a amp and sub like normal.
__________________
2006 2500 QC SB TRX4 G56
Smarty S06 TNT
Edge Juice w/ Attitude
SBC 3600
aFe Magnum Force Stage 2
aFe Blade Runner
4' Straight Exhaust
Leveling kit
Line X
chadder1313 is offline   Reply With Quote
Old 04-21-2009, 03:18 PM   #17
LFD2037
LFD2037's Avatar
I want to keep w/ the stock look.
__________________
2008 3500 DRW 4x4 SLT down here in The Lone Star !
SOLD- '06 2500 with a bunch of goodies!
2007 32' Trail Bay 3528 5'er
2005 Camo Grizzly 660
IAFF LOCAL 3164
SUPPORT THE NRA
LFD2037 is offline   Reply With Quote
Old 04-21-2009, 08:03 PM   #18
stock03
stock03's Avatar
Quote:
My thoughts exactly!
__________________
2003, 4x4, 6speed
stock03 is offline   Reply With Quote
Old 04-22-2009, 11:13 AM   #19
khsjeepr
You HAVE to tap in AFTER the amp. Like I mentioned, the best place to do this is in the passenger side kick panel area. Once again, I've learned from experience on this as well.
Like you, I thought it would be best if I tapped into the wires right as they exit the head unit (before the amp). The main reason for me to do this was to retain independent control of each sub (left and right would still balance correctly). However, after going through all the trouble to pull the head unit and tapping into the wires there, I learned that this wouldn't work. Yeah, I sound coming from the subs. BUT I couldn't control the volume. In other words, when I turned the volume down on the radio, the subs stayed at the same constant volume. The only thing I could do to change the sub volume level was to adjust the gain on the amp. Needless to say, when you wire it this way, it doesn't respond to volume.
Tap into the speaker wires in the passenger kick panel (you'll have to search for the correct colors). I think you'll be pretty happy with the sound - I am.
__________________
'06 2500 Laramie - Edge Juice w/ Attitude - 40" Donaldson - Southbend OFE - DIY air filter upgrade - H2 Wheels w/ BFG 315's
khsjeepr is offline   Reply With Quote
Old 04-22-2009, 03:20 PM   #20
LFD2037
LFD2037's Avatar
Thanks for all your info.!!!
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
