Go Back   Dodge Diesel - Diesel Truck Resource Forums > General > Competition / Pulls / OffRoad > Off Road / 4x4
Register FAQ DTR Store Members List Mark Forums Read
Thread Tools Display Modes
Old 11-16-2005, 02:13 PM   #1
csramsey640
Im still trying to figure out what winch I need
I tow a lot of junk cars and am looking at a good winch setup, The winch will only be used in short intervals, as I dont off road. And will be mounted on my trailer. I also do not mind using a snatch block if I have too(speed isnt a concern) I was looking at the MM 12k electric winch, but im hearing mixed thoughts.
I am also trying to fing info about a hydraulic winch setup, using an electric motor driven pump. I saw the gas powered ones, but its too much for me.
Does anyone have info about the above hydraulic, or will the electric 12k MM work for me? I only winch for periods of about 10-15 min. at a time. At most 1 time a day.
I have used my old hand crank winch for the past few years, and other than having to hand-crank it out. I dont mind it, but it gets old after a while.
__________________
-1991 D350(SRW)
-1977 w200 Crew cab
-1975 w200 Crew cab
csramsey640 is offline   Reply With Quote
Old 11-16-2005, 02:58 PM   #2
CTD NUT
CTD NUT's Avatar
Send a message via Yahoo to CTD NUT
A 12k winch is way overkill just to tow cars onto a trailer!! A 2k or 3k winch will do that just fine. A 12k winch will drag a couple cars at a time with no wheels on them! Even if you do have to drag cars that won't roll, an 8k electric winch will have absolutely no trouble at all doing this and will cost much less, weigh much less and draw less power. For this application where the winch is mounted on the trailer, I would skip going the hydraulic route as it will add needless cost and complication to the installation......a separate electric power pack for the hydro winch that will flow high enough to allow the winch to operate witha a reasonable line speed really won't draw much less electrical power than a comparable electric winch. The only way I can see that a trailer mounted hydro winch would work well is if you had a PTO driven pump with remotes with quick connects coming off the back of the truck to power the winch. The cost of this would likely be similar to that of a 12v electric power pack.
__________________
03 3500 QC DRW 4x4 6spd HO-4" PRXB w/04.5 down pipe, MBRP 304 Duals, Commander/X2 Race, Flux 1's, Icebox, home brewed intake horn, ported HE351, Turbosmart, leveled, 5100's, Dynatrac Freespin hubs, DSS, Reese Signature 18K 5ver
98.5 3500 QC 4x4 24v 5spd-SOLD
94 2500 4x4-SOLD
CJ Juggy-Goes really fast, goes really slow, lots of smiles per mile
CHAPTER PRESIDENT ONDTR #39 contact me to join or PM me for details
"Madness takes it's toll....please have exact change ready"
CTD NUT is offline   Reply With Quote
Old 11-16-2005, 03:50 PM   #3
RickCJ
RickCJ's Avatar
I have a 4500 winch on my tilt bed trailer and it isn't enough, I have to use a snatch block to pull any thing bigger than a small car! Just remember a winch is rated strongest on the 1st wrap, and a bout 1/4 on the last wrap. The last wrap is where I usually am when trying to get a car on. I have a 9000 winch on the big trailer and it works good, only had to snatch a big dump truck on.
The MM is a good winch for what you want, the 8000 would be big enough for most but the hardest pulls, always snatch them, or better yet for only a few $$$ you can get the 12000 and never have to worry. The hydraulic is very good but will cost you twice what the electric will!!
I recomened a MM 8000 or bigger with a remote!! You can sit in the car and steer while you winch yourself on!!!
__________________
Rick
99 Dodge CTD 3500 4x4
5-speed with 3.55's
13" SBC CON O
SHOVP44
FASS
ISSPRO
Edge Comp
DDII's
BD E-brake
BFG A/T KO's
RickCJ is offline   Reply With Quote
Old 12-11-2005, 09:26 PM   #4
scottsjeeprolet
scottsjeeprolet's Avatar
Send a message via AIM to scottsjeeprolet Send a message via Yahoo to scottsjeeprolet
There is a boat load of affordable winch's on the market today, all u need is probably one in the 8-9000# range nothing fancy. Ramsey or Warn come to mind and the new kid on the block is Tmax and they are pretty cheap. Buy a 4x4 mag and look at all the ads for one.
scotte
__________________
1999 3500 4X4 DRW, QC, LB, Auto, 4.10 posi rear, 235 85R16 Dunlop RV, S&B Intake, Moto Blue 4" Dual exhaust,Adrenaline w/Pulse, boost elbow, ISSPRO guages, 3 on the windshield and one on the wheel, AirDog 100, BD VB & TCI Maximizer TC, B&M Super trans cooler, Secret Trans controller, DDII's for tailgaters to enjoy
Scotte
Maryland DTR Chapter #33
Wanna join? email @ MDDTR33@YAHOO.COM
Find out what's going on in MD Chapter #33 Forums
scottsjeeprolet is online now   Reply With Quote
Old 12-14-2005, 08:23 PM   #5
jtb51b
jtb51b's Avatar
Send a message via AIM to jtb51b Send a message via Yahoo to jtb51b
The gooseneck car hauler I pull from time to time has a Warn 8274 on it. While this winch is rated at 8k it will pull more than that and has a tremendous line speed. The setup I use has a battery on board as well as a charging system to keep things up to snuff. The best thing about the 8274 (other than speed) is that it is relatively efficient on the AMPs draw. The xd9000i on my jeep will NOT outpull my 8274, but is cost less and is a lot easier to mount on a jeep!
Jason
On the other hand I do hear a LOT of good stuff about "Champion" winches sold at Sams Club, the 8k winch can be had for $299 here, I think they even throw in a universal mount! You might want to take a look at this thread on a jeep forum, there is a lot of discussion on this subject.
http://www.jeepforum.com/forum/showt...reight+w inch
__________________
1998.5 24v 3500 5 speed cup smoothie and thats all for now..
05 2500 4x4 6spd QC SB Silver Big Horn Edition-Stock--Thats my story and I'm stickin to it! Gone, and it wasn't so stock after all
97 2500 2wd AUTO, 3.54 Gears, BHAF, Straight piped cat, No silencer ring. CD, Cup Smoothie!- Sadly sold on 7-29-06
jtb51b is offline   Reply With Quote
Old 12-14-2005, 11:20 PM   #6
taildragger
I'd get something like a warn m800 (can be had used fairly inexpensive). I have heard good things about the t-max as well. For what you're doing you don't need that 100' or so cable, so if you need just a little more umph you could shorten the cable some. For how little you are using the winch hydraulic is way overkill, and would be a major pain to set up. The only real advantage of getting a hydraulic is when you use the winch a lot (pulling stumps or a tow truck) or if you're like me and have a bunch of dumb friends that think their jeeps can go anywhere.
__________________
1998 12 valve nv4500 4wd quadcab. Bone stock.
timing advanced 9 degrees from 6 to 15
Game counter: 1 boar, 2 sows, largest sow at ~200+lbs
taildragger is offline   Reply With Quote
Old 12-15-2005, 09:53 AM   #7
quantrill88
quantrill88's Avatar
Send a message via AIM to quantrill88
almost every rollback car carrier is equipped w/ a 8 or 9K planetary gear electric winch which has more than enough power and can even do recoveries if rigged right.
if you ever do find yourself w/o enough winch to drag a car on your trailer you could always pick up some tire skates and hammer them under the tires (can also use trays from fast food restaurants) to make them slide right on.
__________________
2004.5 3500 qc, lb, auto, 4x4, patriot blue, Line-X, Weatherguard box, Alpine HU, CDT comps, Focal rears, 2 Adire Brahmas, amps from US Amps, Viper alarm, KORE "chase" system, BFG MT 35's, Scotty5.......to be installed: Autometer Phantom's, and possibly a box
94 Jeep wrangler.....33's, dual tricounty D44's w/detroits, rancho lift, tera-low tcase, tomken bumpers, warn winch
quantrill88 is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.7
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2003, DieselTruckResource.Com
