Hy35 Vs Hx35 Pics
Old 10-03-2009, 02:24 PM
Canuckville's Avatar
Hy35 Vs Hx35 Pics
I just swapped out my HY35 for a HX35. Before the swap when doing research I found it nearly impossible to find any good pics to see the differance between the two turbo's. Here are a few pics I took to see the differance between the two.
Pic 1
HX35 Left, HY35 Right
Pic 2
Pic 3
HY35 left, HX35 Right
Pleas if anyone could add any info on exact dimensions of the turbo's that would be great. Hope this helps some.
Old 10-03-2009, 03:29 PM
The Guru
Mike Holmen's Avatar
Just get a tape or a ruler? You can measure the inducer on both turbos for the compressor and turbine. Then remove the compressor housing, you measure the exducer on the turbine/compressor. After that its just housing sizes. For kicks and giggles should put a BTH-3b or S475 beside them both. I think that the HX-35 is around the 58-60mm inducer size. The HY turbine just similar with alot smaller housings. I remember my HY-35 having a double volute. I just took my new twins out for a rip, I barely got to 1000 deg's egt and 50 psi of boost. Not bad for my little sticks, set on kill there was a little smoke on intial spool-up but after that it was clean.
Old 10-04-2009, 11:24 PM
DodgenIt's Avatar
The sizes I have on those two are...
HY-35.. 54/58/9
HX-35.. 56/58/12
I think the HY might be 54/56 just cause what I saw from size differance when I had my swap goin. But the sizes above are what I have writtin down here.
Old 10-05-2009, 07:43 AM
high bid's Avatar
thanks for posting the pics....lost of confusion in this area on folks trying to find out which one they have.
Old 10-05-2009, 10:27 AM
CODODGE2500MAN's Avatar
Why the switch?
Sorry, but I was wondering why you did the switch in the first place?
Thanks for the info....
Old 10-06-2009, 08:51 AM
I switched to help reduce my EGT's.
I chipped the truck a month ago and noticed I could spike my EGT's no problem.......1500 degree's in a snap. Crusing speed temps were around 750 to 850. I was worried then what they would be like pulling as I just purchased a 35FT holiday trailer. Those temps were just truck alone.
After the swap crusing speed temps dropped quite a bit. 120Km/h....temps 650-730 degree's. I will find out this weekend how it does pulling.
I did drop in boost pressure by about 3 PSI. But she run's a lot cooler now which I like. It also has a more noticable turbo whistle as well.
Old 10-30-2009, 02:39 PM
transdamws6's Avatar
hey you wouldnt happen to still have the hy35? would you be interested in selling if you still have it?
Old 10-30-2009, 04:48 PM
dodge_24's Avatar
how hard was to install the hx35 and what extra parts do u need does it bolt richt up thinking of doing some like this
thanks
Old 10-31-2009, 12:46 PM
Silver R/T's Avatar
you might have to use adapter such as this
http://cgi.ebay.com/ebaymotors/Holse...Q5fAccessories
Someone correct me if I'm wrong.
Old 10-31-2009, 01:42 PM
loudredram's Avatar
they are a direct swap
Old 11-01-2009, 12:04 AM
nickg's Avatar
yup, a direct swap. as you notice in the pictures there are 2 different exhaust flanges, one has 2 bolt holes the other used a band clamp to hook to the down pipe. the exhaust flanges are interchangeable, just reuse which ever you need to hook to your down pipe.
I second the lower egt compared to a hy. good upgrade IF you get a HX for cheap
Old 11-01-2009, 11:11 AM
RamW350 dually's Avatar
What year trucks used the HY35? Wasn't it the later model 2ND GENs with the 24 valve engine and automatic transmission? Would that be a good turbo to put on an older 2ND GEN 12 valve with manual trans to spool up fast (or just too restrictive on the compressor side of the turbo)??
Old 11-01-2009, 11:15 AM
Silver R/T's Avatar
My 2001.5 has HY35, as far as I know all trucks that year w/auto used HY35's
Old 11-01-2009, 11:30 AM
Silver R/T's Avatar
What about HX40, does it bolt right on?
Old 11-01-2009, 02:04 PM
loudredram's Avatar
The 40 is a bolt on swap but a new down pipe is required....they use the same down pipe most aftermarket turbos use....personally I wouldent use a HX40 I would find a hybrid 35/40 or a S300 turbo
Quick Reply: Hy35 Vs Hx35 Pics
