Thread Tools | Search this Thread | Display Modes |
#1 | ||
Hooked up gauges, trans temp dont work !!
__________________
03.5 WHT 2500 HD,QC,SWB, 4x4, Auto, SLT, 3.73 Limited Slip, AFE Pro Guard 7 drop-in filter, PML Trans and Rear Covers. Di/Pricol gauges. 04 Laredo 29BH 31ft 5er |
#2 |
What gauge, manual or electronic, where is the sensor installed?
__________________
2004.5 Ram 2500 QC SWB 4x4 SLT, 48RE, 3.73 LS Gauges(pyro,boost,trans temp,FP,RP), AFE Stage II, FASS 150/95, BD BOV, TC/Trans/Flexplate All Billet Race Build by HotRodDiesels, II SPS66, F1 Flux 2s, F1 Valve Springs, II CP3 Bag of Parts ARP Studs, TST PMCR R49, EZ, Smarty 12.43s @ 108.43 |
#3 |
Transmission temp sensor located in trans pan. Dipricol trans gauge, automatic transmission
#4 |
I have the same gauges as you, and installed in the same location. I almost sent my gauge back thinking it didn't work. I was wrong. Tranny temps take a LONG time to heat up. My needle rarely comes off the peg unless I'm towing, and then it will only get to 100 at cruise, or towing in stop and go traffic, then it can get to 120+, or back up the RV in the sand, then it will climb to 180 very fast. My guess is that everything is OK with you set-up. Give it some time on the road.
__________________
04 Ram 2500 SLT HO, elect shift 4x4, 48RE, 3.73 LSD, Xzillaraider (Race), DiPricol - EGT, Boost, Tranny temp, SS rocker panels, Mud flaps, fender flares, nerf bars, Revtek spacers, BFG 315 AT on AR Python's, CB, ARE canopy, Xtreme liner, AK RAM's BHAF system. Boxes owned/sold: VA C3.2, Edge EZ, Ramifier |
#5 |
False alarm...it was too cool about to get the gauge to climb.
I drove it on the highway and then stop and go traffic and it finally climbed to 115 from 100 (lowest setting) Thanks Everyone, I appreciate your help. |
#6 |
Administrator / Scooter Bum
I have mine in the HOT line from the trans to the heat exchanger.
Theoretically the hottest point in the system. At highway speeds the converter is locked, and I don't even see a reading on my 140* (lowest reading) gauge. In town traffic will see temps of 190 to 200 unloaded in the warmer weather.
__________________
'99 3500 SPORT Black Totaled 8-16-2012 Now 2012 Ram 1500 Quad Cab 5.7 Hemi Powered DTR Site Moderator |
#7 |
what did you use to get your sensor mounted in the hot line????
part numbers,etc????
__________________
03 ,quad cab,4x4,black,305HP/555lbs,laramie,48RE,.BURNT new: 04 3500,suncoast,sp62,toyo 35" MT,weld,banks exhaust,afe,air bags,edge juice,EZ,smarty,autometer, |
#8 |
The part number at the Dodge dealer is CH05011244AA.
This line works on the 47REs, not too sure if it's the same on later (48RE) years. |
#9 | |
Quote:
Gary
__________________
04.5 3500 SLT/QC/SWB/4X4 Patriot blue/bright silver 315/70/70 good year mtrs JUICE WITH ATTITUDE pioneer deh-p9400bh with sirius satellite radio ,phantom gauges , AIRAID BHAF hid conversion kit for the fog lights pacbrake brake PRXB exhaust brake and (pacbrake lock- up controller beta tester) DTT 89 % V/B T/C !! date of mfg. June 12th 2004 451.4 hp bd dyno days 2009 Yamaha Rhino 700 2011 Toyota 4runner limited A FRIEND HELPS YOU MOVE ! A GOOD FRIEND HELPS YOU MOVE A BODY |
#10 |
I've seen temps in the 220-230 range in the summer time, not under big loads in traffic.
The Hot line is usually prefered as it show the temps straight out of the trans instead of after the fluid has traveled through two coolers. By the time the pan fluid has heated up to a noticeable temp it's probbaly already cooking the trans. Running tighter aftermarket converters can also increase temps in traffic.
#11 |
I think the difference in measuring at the "Hot" line and the pan is about 30 degrees. In the pan you are measuring fluid that has already cooled. The hot line is measuring the fluid after it goes through the trans. I got lazy and got the dipstick sensor that you snake down the dipstick tube and reads the temp from the pan. I just always keep in mind that my temps are really 30 degrees higher than the guage says... (It's still better than no guage!!
__________________
04 Green/ Silver Dodge Ram 2500 4x4, 305/555 HO CTD, Custom 4" exhaust, HE351 turbo, VA C3.2 |
#12 |
Quote:
great !! thanks for the info .. i half always sided with the in line temp sensor . thinking that is the way to go .. i think i will order that hose with the fitting in it from mass diesel .. thanks again for the information Gary |
| Display Modes | |
