Thread Tools | Search this Thread | Display Modes |
#1 | ||
home made intake horn (in progress)
__________________
2003 qcsb black sport 4x4 Smarty, intake, exhaust,ats ex man, floor it diy, built trans fuel boss with 2 micron last on the list for now, linex the box and rockers! |
#2 |
How thick of tubing is that? let us know your results
#3 |
here it is, tubing is 16 gauge i believe needs some paint and i have to weld a bolt to hold the oil dipstick. What did you guys do with the wires that connected to the old intake
#4 |
16 gauge but how wide inside? When are you going to start marketing them? Looks good!
__________________
06 5.9 Lonestar with HO 6 spd trans G56 4x4 1-ton DRW Upgrades Predator module Superchips programmer cold air intake 4inch exhaust 2 1/2 inch level kit 2 inch spacer in back 35/12.50/17 BFG Mud T/A's |
#5 |
3 inch no im not gonna start marketing them just showing ya what i got thanks
#6 |
finished it tonight and broke my oil dipstick at the same time errrrrrrrrr but i tapped it back together. The intake definitly spools the truck quicker and i took it for a pretty good drive and the intake itself wasnt even hot like the stock one. I sprayed it down with some high temp paint from advance auto parts and it looks pretty good . now alls i need is a dipstick and a dipstick holder
you cant beat the price either freeeeeeeeeeeee |
#7 |
Thats good cucv, do you have a finished picture of the horn? Dipstick is not too expensive, get this mine was missing when I purchased my truck, but didnt care because the price of the truck was VERY REASONABLE. Dip stick cost me less than 10 bucks at the dealer. Yeah it was that cheap! I will see if I muster up the will to make one on my own. I have a tubing bender just dont have a die that size to make the bend. I will attempt to make it this summer. Too busy right now with work full time and school full time....
#8 |
i left the wires hangin'. They dont move that much
__________________
2006 BIg horn QC shortbox, inferno red, 4x4, auto, manual t-case. Edge Attitude with Juice, Optix, and autometer guages. Mag-hytec front-rear- DD trans. covers. BF AT tires. Kerby COndersor guard, amsoil bypass, 2 micron fuel filter. DPP cool red hose, PSM air box mod, silencer ring MIA, Diamond Eye 5" stirght piped :-) |
#9 |
Is that stainless??
Jim
__________________
03 3500 drw HO auto slt 2wd bhaf J&J stainless boards extang full tilt tonneau |
#10 |
it was now it is painted i like flat black!
#11 |
Did you tig it?
__________________
gpshemi '06 White 3500 MegaCab SRW 275 Hankook RF10 on 18" MB Torque Wheels 2" Top Gunz Spacers & Blocks / 5100 Bilsteins Bully Dog - Triple Dog (Crazy Larry) / Outlook / Boost gauge Quadzilla Boost Fooler / Stainless Cooler Tubez Intake Elbow K&N filter w/ DIY PSM intake mod 5" dual black tips / Donaldson muffler / cat delete Trans cooler Viper Smart Start Pullrite 18K Superglide Air-Lift wireless airbags (sucks) 2010 Cyclone 3612 Boss 9' SD DTR Megacab Club Member #126 |
#12 |
you sure its stainless? the flange looks like mild steel with a MIG weld. once its painted im sure it looks great, i might have to try a turn at it since i got some bends left over from building my twins... i like free too!
__________________
'97 2500 5k gsk, 21ish* timing, rack plug, 5x.014's, pump turned up, twins, O-ring, studs, ported, valve job, 60lb springs, bored .020 over, industrial pistons, internally balanced, and a 1 jigawatt flux capacitor. KDP killed 12-30-07 '02 Yamaha R1 '08 Yamaha R1 MARYLAND DTR CHAPTER #33 To see a wrong and not expose it, is to become a silent partner to its constituance. Last edited by BigErksG2; 04-16-2009 at 10:01 AM.. Reason: add something |
#13 |
I have 1 similar to yours, painted with Rust-o-leum Hammered finish.
Turbo spools up much quicker with a little more low end power... Very happy with mine.
__________________
#14 |
the pipe is stainless and yes the flange is steel. no i just mig welded it and ground the welds looks good enough for me
#15 |
Both of you guys intakes, look great.
__________________
| Display Modes | |
