Go Back   Dodge Diesel - Diesel Truck Resource Forums > General > Natl. and Regional Chapters / Special Events > ABDTR #5
Register FAQ DTR Store Members List Mark Forums Read
Thread Tools Display Modes
Old 11-14-2009, 02:12 AM   #1
1-5-3-6-2-4
1-5-3-6-2-4's Avatar
Holmenator lets give it a try..........
say we get one of these......build a chassis around it. put a seat between the turbos. 16v2000 MTU its not THAT heavy and we could plonk it up to 2500-3000hp.
Then take it down the strip
__________________
Luke
'97 Chevy V3500 CC DRW 6BT 22" Alcoas
'98.5 24v 2500 QC 5spd 4wd Demon hot-rod *sold*
'90 VW Jetta 1.6L oilbrnr 5spd coupe wolfsburg
'73 RS/Z-28 Survivor.
1-5-3-6-2-4 is offline   Reply With Quote
Old 11-14-2009, 08:32 AM   #2
Totallyrad
Totallyrad's Avatar
It'll never work. Alternator's too small.
__________________
Rick
trad@dieseltruckresource.com________________________________________
04.5 3500 Dually, Regular cab, 6 Spd/3.73's, Just black with a little chrome, TAG, Centramatics, B&W Turnover Ball, Brakesmart, Line-X, Weatherguard Box, UWA 100 Gal. transfer tank, Dodge heavy duty mud flaps
Best mileage to date, 19.98 over 646 miles
Can we bring back the rotary phone so we don't have to press one to proceed in English?
_________________________________________________
Totallyrad is online now   Reply With Quote
Old 11-14-2009, 11:52 AM   #3
1-5-3-6-2-4
Old 11-14-2009, 12:42 PM   #4
19Fury69
19Fury69's Avatar
Send a message via MSN to 19Fury69
Need at least 2 more snails on there
__________________
Fred - 01 2500 QC LB 4x4 3.55's, Goerend Billet tranny w/Lockup switch, BD 155's, GT-3788R, AFE Bladerunner, Edge EZ, Dana 80 w/Detroit true-trac, FASS, BHAF, 4" Magnaflow, D25 springs, DT Profab Trackbar (Junk), Eagle Alloy 64's with 35" Procomp M/T's, Viper Alarm/Starter.
19Fury69 is offline   Reply With Quote
Old 11-14-2009, 12:44 PM   #5
1-5-3-6-2-4
.....those are things among others that we need to do to make 2500hp with it. I never said OEM was good enough
Old 11-14-2009, 12:45 PM   #6
19Fury69
19Fury69's Avatar
Haha good point, what kind of tranny would you fab up to that thing for 1/4 mile use??
Old 11-14-2009, 12:53 PM   #7
1-5-3-6-2-4
you can bolt an allison behind it no problem.
Old 11-14-2009, 06:41 PM   #8
Mike Holmen
Mike Holmen's Avatar
What size NOS tank should we get? I wonder what class we would run in?
I do like the way that engine looks, sitting in a rail (dragster) I would if a power glide would take the abuse that our right foot would dish out.
I was talking to my buddy down here in Chicago, he has a friend that has a rail 5.9LIts for sale at $27k. Run 7's
__________________
02 sport QC, SB, 3/4 4X4 DDP stg 3 sticks, back to single little tiny turbo GT3782R
-Kore Recon and a few DSS parts stuff on the front.
-Half worn out DTT Race tranny and the cruise control still works.
-2500 watts stereo, four amps and twelve speakers cranked to the limit
Mike Holmen is offline   Reply With Quote
Old 11-14-2009, 11:44 PM   #9
Nomad
hey, i'm working on a shovel right now with twin V-16's with twin turbos like that one and yup, rated at 3000HP each. The shovel is an "8000 Hitachi", and sound badass when they power up.
Cheers!
__________________
'97 2500 C/C 4x4, Triple lock, B&M cooler w/custom 316 SS lines., BHAF, 4" Straight pipe, airbags. Gauges, #11 fuel plate. 440K. worked hard...
Nomad is offline   Reply With Quote
Old 11-15-2009, 12:01 AM   #10
Bark
DTR's Volcano Monitor
Bark's Avatar
Good plan!! Should be easy to do BUT: The color is just not quite right.
__________________
Remember, 50% of the people are below average. And average aint that great.
Stock 2003 Ram 2500 Full size q cab, Cummins, six speed with 3.73 gears. Always towing 06 Arctic Fox 22GQ.
Bark is offline   Reply With Quote
Old 11-15-2009, 02:48 AM   #11
morkable
morkable's Avatar
Mike that must be benz's rail. They have been trying to sell for awhile now
__________________
03 2500,
Almost Stock
10.84 @ 128 MPH
April TOM Winner
morkable is offline   Reply With Quote
Old 11-15-2009, 02:54 AM   #12
krh
forget custom chassis, Id gladly find a way to stuff it into the bed of my truck if that got donated to me.
__________________
05 2500 long box crew cab
fresh rebuilt engine with stage 2 colt cam, ddp 50 horse nozzles, headstuds and isspro gauges
A whopping 340 horse and 840 pounds. Got a ways to go...
Have tools will travel
krh is offline   Reply With Quote
Old 11-15-2009, 07:40 AM   #13
Mike Holmen
Kev, I was told that it doesn't have the typical skinny tires on the front, if that helps. I never got the fella name on the rail. My buddy, didn't have too much info besides it was a rail/5.9L engine combo and ran 7's
Old 11-17-2009, 12:58 PM   #14
Lil Dog
Lil Dog's Avatar
You would need a huge rear ratio.. Somthing about 1800 rpm is pretty hard to get down the track... The torque would be good... I estimate 7300 ft-lbs..
__________________
97 2500 4X4 LWB CC SLT Laramie 5spd LSD 3.55.
Isspro EV's pyro/boost, #10 Plate, PEAK 3K GSK, AFC Spring, DDP III injectors, S300 Turbo, PEAK IC Boots, TAG III, South Bend 13-1.25" Con FE clutch, SCOTTY II-UNI, MBRP XP 4", KDP Tab, 16° Timing, SS DSS / 03TBK, Roda Deaco PAS. Espar D5WSC heater. B-Quiet sound deadening inside.
Dyno 09-2009 401 RWHP / 1050 Ft-lbs
'08 2500 4x4 MegaCab Laramie, 6.7, 68RFE, 3.73 LSD, S-67ME POD.
Alberta Chapter #5 Prez... PM me for details...
Lil Dog is offline   Reply With Quote
Old 11-17-2009, 01:13 PM   #15
Tate
Tate's Avatar
Quote:
3.55's would be fine, just don't install a tranny. Direct drive FTW!
__________________
'98 3500 4x2 Quad Cab, 24v, 5 spd, 3.55s, No Plate, 4k GSK, 23° Timing, DDP Comp Injectors, Silver Bullet, Big Stick Cam, FASS, BD Short Shifter, SBC DD, Fluidampr
Alcoa Magnums, GM Brake Cylinders, HID Headlights, DSS
'98 2500 4x4 Reg Cab, 12v, 5 spd, 3.55s, 0 plate, 3k GSK, 15° Timing, SBC DD, F1 370's, 64/71/0.80 Turbo, Fluidampr
Alcoa H2's, Lorado Tonneau Cover, HID Headlights, Espar D5, EMS Hub Conversion
Tate is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.7
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2003, DieselTruckResource.Com
