Thread Tools | Search this Thread | Display Modes |
#1 | ||
Holley Blue help
__________________
2002 Dodge 3/4 ton QC 4x4 6-speed...71K miles. Edge Juice with Attitude, dual 3 inch exhaust. Walbro 392...20psi @idle, 16 psi WOT!! Rotella 15-40, baldwin oil and fuel filter. Lucas fuel additive w/fill up, homeade VP-44 cooler tube. |
#2 |
I have a Holley Blue, but I don't remember exactly what it cost. You can look on the Advance Auto website and find out. Mine came with the bracket, and I ordered the Vulcan relocation kit from Geno's Garage, which also has a website. I left my stock pump in place for a spare and bypassed it with the new hose. If the Holley was to fail, I can have my stocker going in just a few minutes. I like the Holley Blue. I have 14# at idle and 11 at WOT.
__________________
1998.5 2500 QC SB, Guages, Edge EZ, SC VB, Mag-Hytec DD pan, Mega-flow downpipe. 2003 KZ Sportsmen, triple slide |
#3 |
the bully dog system is just a holley blue pump! I would recomend ordering a big line kit from any vendor on this site, to work with a holley blue! Make sure you stretch or remove the spring for adequate pressure! If I can be of assistance give me a call!
L |
#4 | |
Quote:
The spring??? Guess i am not following what you mean. Please explain. Also, most i have talked to run the blue in line WITH thier stock lift pump. Is this the right way to do it or does it matter? |
#5 |
Yes and no! I feel that failure of eaither pump in a two pump system can cause problems! If you want to go this way with it, You could just stretch your regulator spring a touch (right behind the big straight head screw! )
Eaither way the setup is better than stock! When just using the Holley pump some have to completly remove the spring to maintain a decent psi! While using two pumps one will just supply the other ! |
#6 | |
Quote:
http://www.holley.com/12-802-1.asp I would also just order a vulcan big line kit and call it a day. You will then have everything you need with instructions on how to install your pump and new line. Simple as 1,2,3.
__________________
Josh 1999 Dodge 2500 Goerend Billet Auto, 150 Jammers, Holley Blue, HY35, Edge Juice W/Attitude, 6" lift, 37" super swampers, and over 1000ftlbs of torque 1991 Ford Ranger 2.3 Turbo |
#7 |
there is a pump at summit that i bought that is 140 gph and 14 psi alot cheaper than holley blue.
__________________
00 4x4 quad 5spd power puck,xzillaraider,cold air (k&n) summit black 21 psi idle 13 wot 4in silencer & muffler mia fp.pyro,boost, gauge valair 13in clutch 2in level kit 33x12.5x16.5 muds.145000 on the clock and going.no 53 block!!!! |
| Display Modes | |
