Hitting 450+ HP on First Gen
I'm not David's accountant, so I can't speak to how much he's got into his rig over the quarter-century he's owned it. What I do know is that I want to accept that challenge, whether you meant it that way, or not.
Let's see if I can hit 450hp+ and have a transmission that can hold it for less than $5k! (not including the price of the truck).
Saw this on the book of Faces:
FASS
FASS sump
5x14s
58mm BD turbo
3200 spring
Ground fuel pin
Timing spacer
Jumped 1 tooth on the IP gear
60lb valve springs
I also dont recommend BD. They screwed my friend over royally and forgot the courtesy lube packet.
FASS
FASS sump
5x14s
58mm BD turbo
3200 spring
Ground fuel pin
Timing spacer
60lb valve springs
1st Generation Admin
95black2615
08-22-2005 09:21 AM
600 Megawatts
06-15-2005 09:02 PM
HighTen
19
12-08-2004 03:50 PM
Hoss
23
07-09-2003 05:45 PM
