Main Page Classifieds Tech Facts Member Photos Articles Links Forums Chat
Go Back   Dodge Diesel - Diesel Truck Resource Forums > 3rd Generation Ram - Years 2003 and up > 3rd Gen High Performance and Accessories (6.7L Only)
Register FAQ DTR Store Members List Mark Forums Read
Thread Tools Display Modes
Old 10-30-2009, 08:14 AM
Wolfcsm's Avatar
Wolfcsm Wolfcsm is offline
High Idle and the SMARTY
Saw a question about enabling the high idle feature within the SMARTY software. Asked the folks at MADS and got this back:
I confirm that the high idle feature is automatically enabled in all the CaTCHER levels of Smarty S67.
In automatic trucks the high idle can be controlled by the cruise control.
In the manual trucks, the Dodge kit for high idle has to be installed in order to use it.
Stefano Negrini - MADS
Now my question is what is the kit he is talking about.
Thanks,
Hal
__________________
Hal Dudley
Killeen, Texas
My toy: 2008, Dodge 2500, 4X4, 6 speed, SMARTY (thanks DTR and MADS), 4 1/2 inch leveling kit
Retired Army Command Sergeant Major
Army Civillian today
Support our troops and their families
And on the 8th day, God created the Cavalry Trooper, and all Hell stood at attention.
Old 10-30-2009, 09:51 AM
Totallyrad's Avatar
Totallyrad Totallyrad is offline
You have to install a clutch switch. The clutch switch tells the computer whether the clutch is engaged or disengaged. It's basically a safety. Unless somebody jumps in with a link you'll have to search for the info on the part numbers and install. There's allot of confusing info on this so don't be in a hurry to buy parts until you sort out the particulars.
__________________
Rick
trad@dieseltruckresource.com________________________________________
04.5 3500 Dually, Regular cab, 6 Spd/3.73's, Just black with a little chrome, TAG, Centramatics, B&W Turnover Ball, Brakesmart, Line-X, Weatherguard Box, UWA 100 Gal. transfer tank, Dodge heavy duty mud flaps
Best mileage to date, 19.98 over 646 miles
Can we bring back the rotary phone so we don't have to press one to proceed in English?
_________________________________________________
With all the sadness and trauma going on in the world at the moment, it is worth reflecting on the death of a very important person, which almost went unnoticed last week. Larry LaPrise, the man who wrote "The Hokey Pokey", died peacefully at age 93. The most traumatic part for his family was getting him into the coffin. They put his left leg in and that's when the trouble started.
Old 10-30-2009, 04:01 PM
safecracker909's Avatar
safecracker909 safecracker909 is offline
Why High Idle?
What are the benefits of having a high idle?
__________________
Neil
2007 Ram 2500HD SLT 4x4, Big Hor, 6.7L, 6 speed auto, K40, Banks Inter-cooler, Banks Ram Air, Edge Juice w/ Attitude HOT Unlocked, Smarty ME Stack. AFE 5" TBE 6" tip. Mag-Hytech Difs and BD trans pans. Amsoil everywhere. 150,000 miles.
Old 10-30-2009, 04:15 PM
Totallyrad's Avatar
In the summer it will help your alternator keep up with the demand from idling with the air conditioning on and help the air work a tad better. In the winter it will help keep things warmed up a little also.
__________________
Rick
Old 10-30-2009, 04:30 PM
Shaneus Shaneus is offline
Hi Idle mod
I have read (maybe on this forum) about grounding a wire that is in main harness near the clutch pedal that allows the hi idle to work. This wire must be the one that connects to clutch switch. The dealer install of the switch plus parts was about $300 when I asked about it at dealership.
Shane
__________________
2007 Ram 2500 4WD, 6Spd Manual, Smarty S67ME, 5" TBE w/ deletes, 2" leveling kit, goodyear 315 MTR tires.
Old 11-03-2009, 03:10 AM
donaldej donaldej is offline
Quote:
I use it in the winter all the time. I go out and start the truck, turn on high idle, run back in house and then leave in about 5 min.
Old 11-03-2009, 04:37 PM
mjf6175 mjf6175 is offline
There are many posts on this in the 5.9 section. You do not have to have use the clutch switch (which by the way is expensive). On my 04.5 I used Cummins part number 3164263, costs $12.50, and its simply a wire with a male metal pin at the end which you plug into the #22 slot/port of your ECM. Put a ring terminal on the other end of the wire and ground it (use the bolt right next to the ECM) The ECM is located on the drivers side of the engine. Total time is about 30mins including coffee/beer. Load up your Smarty or go to the dealer and have him enable the PTO high idle feature. If someone needs more PM me and I will pass along info on a good "how to post" that is on another cummins diesel forum...........
Old 11-06-2009, 01:11 AM
BroncoHound BroncoHound is offline
The process to circumvent the use of the MOPAR clutch switch is different on the 6.7L trucks than it is on the 5.9L 3rd gens. All you need to do on the 6.7L/G56 trucks is ground one particular wire under the dash within the area of the 100-pin connector. Here is a picture of where it was on mine:
__________________
08 QCSB 4WD 6.7L/G56/3.42
*HBS Level Lift
*Carli Valved 5100's
*Thuren Track Bar
*SSSSS
*Ride Rites
*325/70R17 Nitto TGs
*EV2 Boost/EGT Gauges
*Smarty
*Shaved BlueTec Badge
"Certainly there is no hunting like the hunting of man and those who have hunted armed men long enough and liked it, never really care for anything else thereafter."
Old 11-06-2009, 03:12 PM
mega-engr's Avatar
mega-engr mega-engr is offline
Quote:
Thats why you're the man! . Good accurate information.
__________________
2007.5 Ram 3500 SLT 6.7L Megacab, 4x4, 6sp. Auto, Electric Blue, Nav & 6 disc changer, Smarty S67 ME14 (SW3), Revertable EGR Plugging and Exhaust Deletes, S&B intake, Amp Research Steps, Prodigy Brake Controller, Wolf Liner O.T.R.
DTR Megacab Club Member #152
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.7
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2003, DieselTruckResource.Com
