Thread Tools | Search this Thread | Display Modes |
#1 | ||
Hey Quad if 12-14 is optimal....
__________________
05' DodgeRam2500CTD4x4 Too much stuff to print 617rwhp/1200+trq on Dynojet Peace thru superior firepower |
#2 |
The way we alter timing now won't allow us to advance that far without the ECM having fits.
We are working on something that will stack with our products and a lot of other products that will put you at the optimum. Also when I say optimum, I am talking throttle responce and power as well as egt, and mileage. You can get to the point of no return on mileage, but you can drastically alter your power curve when you advance the timing further. |
#3 |
#4 |
Interesting....
MikeyB
__________________
2003 2500 2wd SWB Quad Cab Laramie, 305/555, NV5600, 3.73LS, Line-X, Westach boost/EGT combo gauge, PML diff cover, Airbox mod, Hurst 6spd Shift ****, Adjustable boost elbow, Toyo OC AT 285/70/17 E, Daystar 1.5" lift, Monroe Reflex, Raptor RP100, Lazarsmith Intake Horn, HID SMARTY Sr./Van Aaken C3.2 |
#5 |
Quad: you aren't saying that 12 degrees would be optimal across the RPM range are you ?
12 degrees of advance at 750 RPM is a lot. I can see that 12 degrees at 2900 isn't. I think the limit of the advance is going to be set at the low RPM range. |
#6 |
Boost is the only thing that matters, I posted this in the camshaft sensor thread also, you can read a little more there.
| Display Modes | |
