Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > 24 Valve Engine and Drivetrain
Register FAQ DTR Store Members List Mark Forums Read
Thread Tools Display Modes
Old 11-17-2009, 09:58 PM   #1
Jeeptaxi
Help?
I have 2 small problems with my truck.
1) It leaks a little fuel from what appears the bottom of the injection pump when its idleing. I think this is the cause of my problem, but dont know what to look for. The problem is if I park the truck faced uphill for any length of time (overnight) its hard to start. Park faced down hill it starts right up.
What could this be? It also seems that when you hit WOT it sorta lays down on me. The throttle response if great and has tons of power, but if you floor it, it just sorta flattens out.
2) My dome light wont turn off. I have already replaced the headlight switch. I can hear a relay turning off after about 20 seconds and the light dims slightly but it stays on. Any ideas on this?
Jeeptaxi is offline   Reply With Quote
Old 11-18-2009, 04:39 PM   #2
dozer12216
Could the leak be the banjo bolts on side of pump? Each should have 2 gaskets and are different size. I suppose the injector line fittings at pump could also leak and tighten required. Gonna have to get personal with it to find leak.
What have you screwed with on engine/pump in last 6 months?
Return side air leak is general cause of hard uphill/ quick downhill starts.
__________________
Big Blue Beast. 2000 SLT dually heavy towing auto 2WD, stage 1 injectors, 235K and still growing.
Goldenrod. 1984 Rampage with 2.5 1/2 liter EFI engine. D8H CAT dozer and old Hein Werner excavator. Retired to play with toys.
dozer12216 is offline   Reply With Quote
Old 11-19-2009, 07:37 PM   #3
Jeeptaxi
I have checked all the lines for leaks. It seams that the fuel is leaking from between the block and the injection pump from what I can see. Is there a seal or gasket back there on the pump that could be leaking? I am new to diesels so I am kind of stumped looking at this thing.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.7
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2003, DieselTruckResource.Com
