Thread Tools | Search this Thread | Display Modes |
#1 | ||
hello 89 cummins ?
#2 |
Pickin on the wrong admin...
Welcome to DTR...Try posting your question in the first gen section..You will get alot of responds there..
__________________
1995 Dodge,280,000 miles, regular cab dually,4X4,5 speed,4:10 gears,Wastegate blocked,15 degree timing,Polyurethane control arm bushings,BHAF,KDP Tabbed,Pyro & Boost,DSS,2003 trackbar upgrade,Steerring bushing,#0 plate,3K springs,215 injectors,Laser cut DV,Con OFE. Mar 2008, Dyno: 353HP/735 Ft Lbs June 2008 Dyno:344HP/835 Ft Lbs 1978 Mercedes 450SL 1956 Chev 4 door Sedan 1977 T/A 400,4-speed 1963 Ford Falcon,2 door |
| Display Modes | |
