Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > 1st Gen. Ram - All Topics
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 10-24-2011, 10:26 PM   #1
mhuppertz
mhuppertz's Avatar
What the heck is this?
It has been under my seat since I bought the truck, but it's like an appendix, can't find a use for it. Looks like a factory piece...
Click the image to open in full size.
__________________
MARK
'93 W250, HTT Stage IV/16cm, POD's, cut AFC pin, Pump advanced, Pyro, Boost, Fuel Pressure Gauges all non functional, burned wiring, 3/8” fuel line, BHAF on custom intake, 3,200 Spring, ARP Studs, New Head at 392K, Detroit Locker, NV4500, other stuff…
mhuppertz is offline   Reply With Quote
Old 10-25-2011, 12:12 AM   #2
9MM
My regular cab doesn't have that?
9MM is offline   Reply With Quote
Old 10-25-2011, 05:06 AM   #3
NJTman
That sure is different.
Looks like something that you'd be covering over the guys head who steals tires and rims from the side of the road, that fell off of your truck while you were driving.
...... after you've buried him somewhere in the badlands up to his neck in sand.
__________________
T.
1992 W250 LE. 518 auto,3200 spring, 4" Diamond Eye, 3" front springs, Derale Deep pan, Linex Bed liner, Jim Lane's headlight relays, LED tail lamps, class 5 hitch / frame strentheners, KDP KILLED, Rear diff Power Lock Spider Gear Clutch pack replaced, Western Plow and a pocket full of receipts
NJTman is online now   Reply With Quote
Old 10-25-2011, 06:45 AM   #4
Crossy's son
looks like the lid to a secret stash compartment
maybe your truck was used to transport illegal drugs across the border?
__________________
91.5 W250 4x4 5 speed LE Red/Grey, 270k miles, 3.54's w/ Power-Lok, 4" Exhaust, BHAF, DennyT Pin, 3200 Spring, Piston LP, Power screw maxed, HX35/12cm, DAP 5x14 Injectors, Valair 13" 550hp K/C clutch, 4" Skyjacker soft-ride lift, 315/75R16 Mickey Thompson Baja ATZ tires, 16-17 MPG
89 D150 3.9L TBI/A999 Auto, beater while ^^^ gets restored
Attending LTI for Diesel Truck Technology, graduate December 2013
Crossy's son is offline   Reply With Quote
Old 10-25-2011, 08:06 AM   #5
Buddy Stewert
Buddy Stewert's Avatar
kick panel vent cover??
Buddy Stewert is offline   Reply With Quote
Old 10-25-2011, 10:39 AM   #6
mhuppertz
mhuppertz's Avatar
It was just laying under the seat so I though it was covering up something under there until I bumped it with the vacuum and it moved, and nothing was under it except the unbroken expanse of carpet.
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
