Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > 2nd Gen. Dodge Ram - No Drivetrain
Register FAQ DTR Store Members List Mark Forums Read
Thread Tools Display Modes
Old 11-16-2009, 06:39 PM   #1
96_12V
Exclamation Headlight switch "sparking?"
I've noticed a small "click" noise every so often while driving my truck at night. It's seemed to come without warning, and usually from the left side of the dash. But I never have seen anything (until Saturday night) and it's maybe once every month or so that it happens.
So Satruday, after having run 45 minuites or so, I happened to look down by the headlight switch *just in time* as that little "click" occured. I was shocked to see, back inside the swich itself, what looked like a very small blue or white "arc." It looked like a spark had occured. There was not change in the lights (no dimming or flicker.) Just that little click, the arc, and that was it. Nothing else at all.
So this has me moderatly concerned, since other have reported fires sourced from this switch. Do anyone know of a pending recall? Or anything else I could do that have this fixed or replaced? Or am I being just a bit too paranoid.
Also, there was no heating of the plastics around the switch or the switch itself. Any ideas?
__________________
'96 Ram 2500 CTD 12V 5-spd 2WD 353k, Celebrating 2010!
Let me get this straight... You are swapping out parts designed by hundreds of engineers that get paid thousands of dollars for something you bought at Pep Boys because your buddy who doesn't have a job told you it was 'better'?!?
96_12V is offline   Reply With Quote
Old 11-16-2009, 10:00 PM   #2
GAmes
GAmes's Avatar
It isn't that hard to pull. Check for a loose or chafed wire. The overheating issue is usually from having the instrument lights dimmed. While you have the bezel removed drill some holes in the top of the dash air outlet tube below the switch. The switch is located up there where no air circulates.
__________________
97 3500, G56 6 speed, lightly bombed 725+k miles
(GETTING CLOSE TO 3/4 MILLION MILES!!)
GAmes is offline   Reply With Quote
Old 11-17-2009, 07:36 AM   #3
b.lee
b.lee's Avatar
My headlight switch melted pretty bad
So bad it smelled horrible, had to put both windows down.
I'd replace it and if you tow trailers, make sure your trailer wiring is not going thru the headlight switch. My truck didn't have the 'factory tow package' so the trailer lights were plugged in thru the tail lights. That's a for the headlight switch.
I corrected my trailer wiring and got a new switch. No problems since.
__________________
96 CTD 2500 4x4 x-cab Goerend Trans / Triple Disc TC, BD Flex plate, Mag-Hytec Trans pan, #10 Plate, 3K GSK, 4" Down pipe/Exhaust, Isspros in A-Pillar, Boost Elbow 36psi, Prime-Loc, Amsoil 4510, 08 CTD wheels w/ 265 BFG's, KDP tabbed, 3rd Gen Trackbar kit, 408,000 Miles
98 Camaro Z28 LS1 Auto, Shift Kit, EFI Live, SLP Cold Air, C5 Thin spoke Corvette Wheels
b.lee is offline   Reply With Quote
Old 11-17-2009, 10:34 AM   #4
littlebuddie
Quote:
Originally Posted by GAmes View Post
........ The overheating issue is usually from having the instrument lights dimmed........
Out of ignorance, I ask, how do having lights dimmed create this problem? Good or bad, I like to keep my lights dimmed but will stop the practice if I am inviting a bad situation. Thanks!
__________________
1999 Ram 2500 Quad Cab 4X4 Shortbed Cummins 24 Valve, 5 speed manual, NV4500HD, NV241HD, model 60 and 80 Dana Diffs - All Stock.
littlebuddie is offline   Reply With Quote
Old 11-17-2009, 10:06 PM   #5
joelayan
Quote:
Potentiometers and Rheostats (not sure which the headlight switch would be) both adjust voltage through resistance and this causes heat. Basically what you don't use for powering the lights gets changed into heat and as you dim the lights more is turned to heat than if you turn it brighter.
I think the best course of action would be to put in a seperate relay that the headlight switch controls which would reduce the load on the circuit a lot. I plan to do this on mine soon.
Joel
__________________
96 2500 4x4 Extended Cab LB w/ 187k miles
3.54 w/ 285's
Gauges (Boost/Pyro/Trans), Goerends w/ Triple, #10 plate, free gsk, blocked wastegate, Timing @ 15.5, 4" AFE exhaust.
joelayan is offline   Reply With Quote
Old 11-18-2009, 08:01 AM   #6
GAmes
GAmes's Avatar
I keep the dash lights dimmed also because doing that increases your vision outside. After about a half hour of night driving place your hand on top of the dash directly above the switch. If it is barely warm, no problem. Drilling the holes will dissipate the heat from the heat sink that is attached to the switch. On my 3500 I also replaced all the running lights and tail lights with leds, which made quite a bit of difference. I also have my trailer lights on a separate circuit through a fuse and toggle switch. If your harness is burned there is an improved version available. A search should give you the part #.
Old 11-18-2009, 10:36 AM   #7
littlebuddie
Thanks for your response to my question joelayan and GAmes.
I thought that might be the reason but I like to ask when in doubt. Is this a problem with certain years of trucks or all of them?
Old 11-18-2009, 09:50 PM   #8
GAmes
GAmes's Avatar
The burned wires is a problem in 96 and earlier 3500s due to the amperage draw of the running lights. The new wire harness is installed in 97s. 2500s don't usually have a problem, and I have never heard of the overheating causing sparks, thus my original recommendation to look for loose or chafed wires.
Old 11-19-2009, 12:18 AM   #9
littlebuddie
Thanks GAmes!
Old 11-19-2009, 04:50 AM   #10
n2moto
My 97 melted the harness. I changed it some years ago and no problems since.
__________________
97 5 spd Banks, Rickson 19.5 Wheels 290k
04.5 juice with attitude. nv5600 worst shifting transmission I've ever driven 3.73 laramie brite box bulbzilla pac brake
n2moto is offline   Reply With Quote
Old 11-20-2009, 09:24 PM   #11
b.lee
b.lee's Avatar
my 96 2500 CTD overheated bad. Melted the switch really bad. Almost caught fire by the smell of it.
I had to replace the switch in my previous 95 1500 360 gasser too
Old 12-06-2009, 09:40 PM   #12
TIMMY22
TIMMY22's Avatar
I went through about 5 headlight switches.
About 2 years ago, I took the headlights and the parking lights off the headlight switch. I ran the headlight wires to a 50amp toggle and the parks to a 25amp toggle. Absolutely no problems ever since.
I still have my dash dimmers and turn for interior on the "old" switch.
Between that and my "pull cable" solenoid, it makes for good theft deterrent. "Not only will it not start, the headlights woun't come on"
__________________
96 2500 4x4 Auto, No payments, No silencer ring, KDP barrier installed, Thuren Bar, 4" Strait Piped, Star wheel tweaked, Air Ride Rear, ~177K
92 D250 LE 4x2 5 speed, No payments, No Muffler, No rust, Locktite on Killer Bolts plus KDP, EGT and Boost Gauges on A-Pillar, Fuel screw 1 turn, Smoke screw 2 turns, Timing bump, 366 Spring. 3.54's, ~155K
91 W250 Gas to Diesel Conversion, Auto 727, 3.07's non I/C, Custom Turbo back 4 in. exhaust, KDP killed, Body off Chassis restoration ~216K
TIMMY22 is online now   Reply With Quote
Old 12-06-2009, 09:50 PM   #13
RoadDiesel
I found a used H/L switch lasat spring and installed it..the used one now is starting to go bad..Ill look for a new aftermarket one this time...
__________________
1994 Ram Auto, 2500 4x4 std Cab long box
"KDP" killed at 205,000 miles.was out 1/8"
silencer ring removed
AutoMeter NV (Night Vision )Boost/EGT/Trans gauges
BF-P235/85/16
Boss V-plow
Slt trim pkg
Mod's in the plan
Amsoil "Everything"
Tips/Advice welcome
Black Hills S.D. Deadwood-Summertime
Can-Am 800c Vtwin
God Bless America !
RoadDiesel is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.7
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2003, DieselTruckResource.Com
