#31 |
366 Spring Chicken
Is this from to much boost or is there a warped issue?
__________________
89 W250, powerstroke i/c, 3 turns smoke screw, 1/2 turn starwheel, full power screw 4 or 5 turns, autometer phantom boost and pryo, 4 k isspro tach, 727 tranny, 3.07 gears, factory l/s rear, S300 turbo, stans exaust, wish list, T/C, sticks. 93 w250 extended cab, rag, 6X16's, GDS 60mm, full set isspro gauges. 92 W250 with NV4500, stock engine. |
#32 |
Best Paint (Getrag category)
Lots of boost,fuel and timing= lots of cylinder presure
__________________
90 W250 reg cab, Modified knuder valve, reversed reciprocting dinglearm adjusted, High volume flux capacitor, A clutch and a hitch Coming soon Who Knows?? Stackless again July 2008 TOM INTERCOOLER, YEAH WE FINALY GOT A STINKIN INTERCOOLR The old mans ride. 91d350 n/ic, getrag,D80 stock afc cone set deep,soon to be intercooled |
#33 |
alwaysonDTR
i killed 3 also didn't fix the last one, yet
__________________
white-'91 350,4x4,getrag 5speed,SB3600DD, swapted in a 92 cummins do to head gasket failure,Garrett 60/65/12, p/s intercooler,3" tubes,twin ram intake,366,fuel screw in M&H fuel pin(M2) and timeing spacer,low pressure piston LP,gauges,4inch exhaust http://www.youtube.com/user/91ctddc blue- 91 cummins,230,xxx getrag, 4x4,250,M&H fuel pin M2, 4inch strait pipe, gauges custom made intercooler, 3in. tubes,HX35/14 DTRgoofball club member #11 |
#34 |
What are ya waitin for
How did you pop 3 |
#35 |
alwaysonDTR
i'm waiting for money to do it right, since i had an extra engine i put it in.
i poped 3 the same way you did. |
#36 |
When you say "right" you mean studs and rings and the whole ball o wax?
#37 |
alwaysonDTR
#38 |
Look what I got today, Now I gotta find a warm place to put in
#39 |
Well I got the new gasket in today took me about 7 hours and only had 1 little snafu, I strecthed 1 head bolt tryin to go to 140ft-lbs
other than that it went pretty smoothA buddy of mine turnin some wrenches ![]() ![]() looks like I need some thinner injector washers or back the timing off a little ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
#40 |
alwaysonDTR
looks good,think that 140ftlbs will hold it better?
#41 |
We never made it to 140 I was at 130 and was starting my torque sequence again and stretched the #1 bolt so we left em at 130, good thing I had an extra set of bolts
#42 |
alwaysonDTR
what was it at before? is 130 higher?
#43 |
It was at 130 before
But I ran all summer blowing 55 psi at it sled pulling and screwin around I don't know if it was a defective bolt or what I've heard of people torquing them to 150 There is a big difference between a good bolt and a bad bolt when you do the drop test Good bolt= very high pitched ring Bad bolt=dull thunk |
#44 |
Another one bites the dust
#45 |
Your not alone, I just got done doing my '93.
That top-end gasket kit is $213 as of friday night. ![]() I was bummed to see the HG says "made in china" right on it. ![]() They cheapened up the horseshoe washers, too. Ended up using some old ones to get it sealed back up. The new ones are visibly thinner and not the good old copper color.All this straight out of the 4089649 box. ![]()
__________________
Curt Driver: '93 W350 CC SRW Getrag: 3200, 370's, HX40, BHAF,HP Piston Pump, Big Lines, Pull Cable, Valet, 5" Straight Pipe, AM Tach, C2 Boost and Pyro Borgeson, 240K To do: PS-IC Puller: '89 W350 RC SRW Getrag/NV273: 6x.016's, 4200, H1C/ HT3B Twins, A1000, SBC DD, Water-2-Air IC Hydro asst Steering, Big Weight Box |
| Thread Tools | |
| Display Modes | |
