Main Page Classifieds Tech Facts Member Photos Articles Links Forums Chat
Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > 12 Valve Engine and Drivetrain
Register FAQ DTR Store Members List Mark Forums Read
Thread Tools Display Modes
Old 11-07-2009, 12:39 PM
diezel freak's Avatar
diezel freak diezel freak is offline
head retorqe
what r ur guys thoughts about retourqing the head?? when i first put the motor in 200miles later i lost the head gasket. and i really dont want to loose this one (tired of pulling the head) thank you in advance
__________________
1996 Dodge 3500 club cab 4x4 NV4500 1 3/8" input shaft, 3250 south bend dual disc clutch. current motor- 1995 stock other than free 3k gsk, gutted afc, #0 fuel plate
Race motor-Cummins bored .020 over marine pistons and marine 370 injectors HX50 street cam 191 delivery valves 5000rpm gsk#0 fuel plate BFAF air filter twin 496hp 867lb. ft torque (6 melted pistons:()
1999 Chevy K2500 6.5L TD NV4500
Member of Michigan Oil Burners club
Old 11-07-2009, 03:43 PM
JQmile JQmile is offline
Torque cold to specs, let sit overnight. Loosen one at a time and retorque with lube. Do all over again a second time. The next day (3rd day since first torque) drive the truck and get it hot and do a hot retorque to specs. Don't ever, ever get on the pedal until the truck is up to operating temp (160 deg +).
__________________
1989 D250 2wd New Era 6x16's, 3200 spring, Goerend converter, J&H Performance 727 trans, BHAF, 4-inch downpipe and exhaust, DennyT fuel pin, ported, o-ringed and ARP studded head, external wastegate, 62/65/14 S300 w/internal gate, three stage nitrous. New dyno numbers soon! Old numbers 448/842.
Old 11-07-2009, 11:39 PM
GAmes's Avatar
GAmes GAmes is offline
I torqued mine to Cummins specs. No retorque required.
__________________
97 3500, 5-speed, lightly bombed 700+k miles
(GETTING CLOSE TO 3/4 MILLION MILES!!)
Old 11-10-2009, 09:03 PM
Skip H Skip H is offline
retorquing the head
I cleaned up the bolts and lube them and torqued them one at a time to 66/89 ft lbs and then I used a torque wrench with an max torque needle on it and found out after after turning 6 of them to 90° degrees that the torque reading was between 125-130 Ft lbs. so then I torqued them all to 125.
Why I retorqued the head was because the antifreeze was slightly leaking out of the front of the engine. I had just check the valve clearances and found out that where no 1 cyl was right on before- the valves tightend up .002. The bolts seemed loose on that cyl when loosened them so I hope this clears up this seep.
So does 125 ftlbs seems to be the right torque?
__________________
1996 Monaco-5.9L- 12mm stock exhaust housing- stock plate modified, Pyrometer, 4"x 20" test muffler, boost adjusted to 32 psi, DDP-1 injectors, ATS 2 piece exhaust manifold, 3GSK
Old 11-11-2009, 09:00 PM
i also did a little test with that additional 90deg and found it to being around 130 lbs so thats where i put em to being that the bolts around #5 and 6 r difficult to do the degree thing....and taking one bolt out and then retorquing it isnt really making sence to me.
__________________
Old 11-11-2009, 11:30 PM
dodgetrucker75's Avatar
dodgetrucker75 dodgetrucker75 is offline
i pulled mine out 1 at a time, cleaned them really well, put molly grease on threads and on the head of the bolt where it contacts the head, and torqued to 135 lbs. i hit 50psi every day, and sometimes more when im not paying to much attention, been like this for the last 20k miles, and still on the stock gasket @ 200k miles
__________________
98 12v 5spd,ddp 90's,twins 62/68/13 over 75mm s400,stage2 water/meth,16.5* timing,4gsk,"custom" plate & AFC,fass fuel,2095 plug,60# springs,afe stg.2, 5" turbo back,John Deere DV's(originally v10, converted w/94 doner) pensacola injectors in the trash can.
75 power wagon, 1st. gen, getrag, 3.2gsk,DDP 80's, twin turbos, stg.2 water/meth,custom intercooler and 3in piping,5" turbo back in to twin auzzie cuts,tweaked pump,arp studs,12in lift, rear triangulated 4 link w/big rig air bags
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.7
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2003, DieselTruckResource.Com
