Thread Tools | Search this Thread | Display Modes |
#1 | ||
HE351 Turbo question
__________________
77 Dodge Xplorer 307 Frank Ind 26-ft Class A Motorhome 1st Gen '93 Cummins swapped in, stock 47RH/NP241, stock turbo, PS intercooler, fuel pin, starwheel, fuel screw turned, 366 spring, BHAF, 4-inch down pipe + DNA muffler, Dana 60 front, Dana 70 rear, 4.10:1 gears, ARB lockers front and rear, 19.5 Rickson wheels, 33-inch tires, High-Angle driveline. |
#2 |
HE351cw= 04.5-06 from 5.9L HO Cummins (325hp/66ft-lb). Wastegated. This is the one you want.
HE351VE/VGT=07-present 6.7L Cummins. Variable vane exhaust turbine. Not as simple to control boost, but can be done with just a wastegate actuator and some tuning.
__________________
-93 W350, auto, DRW, 210k. Screw lengthened, DDP 45lpm, DennyT II, 366, full gauges, Borgeson, timing 3/16", 4" unique exhaust system, dual batts, maxi fuses, PS I/C, Cooler Tubez, HE351CW, 3/8" lines/4601HP lift pump. -89 D250, auto, 83k, utility bed, very clean. 2,000hr military IP, 4" exhaust, free mods -09 Jetta TDi, Malone stage II and DSG tune -10 Kawasaki KLR650 -83 Kubota B8200 |
#3 |
iirc the he351cw also came on the early 07 trucks, right?
__________________
2003 F250 SD 4x4 3.73 SCSB Rebuilt Cummins, Rebuilt VE, 181/210 Hamilton Cam, 374, DennyT#1, M&H KSB spacer, KSB on a switch, Custom AFC, Maxxed pump, 5x.016, HPLP/regulated @ 18psi, 3/8" fuel lines, A1 Studs, 60#, ATS manifold, ATS Aurora 4000, 4" Ex, Turbo/manifold blankets, 3" cooler tubes, PS intercooler, custom intake (Amsoil Ea4091 filter), NADP 4R100, PCS Controller, gauges (pryo, boost, trans temp, fuel), 4" Lift, 35" BFG MT ~ Amsoil 5W-30 Series 3000 synth. w/ bypass. |
#4 |
IDK, as long as it was a 5.9L High Output.
#5 |
Was the 5.9 HO the standard engine that came in the 04.5-07.5 trucks?
#6 |
Yes.
__________________
-John- 1992 Dodge Power Ram 250, PATC 46RH with Suncoast FP, TC and VB, Flex-a-lite HD trans cooler, PDR Injection Pump, New Era 6 x 14's, HPPLP with a Mallory Regulator, PDR S357/HT3B, PDI manifold, 4" exhaust, 7.3 PS I/C, and Cooler Tubez... |
| Display Modes | |
