Thread Tools | Search this Thread | Display Modes |
#1 | ||
Who has the best injectors for the buck??
#2 |
i would try to get in touch with Formula 1 Diesel, Don M can help u out
#3 |
formula one does not deal with the public you have to go through one of his venders. I recommend Timinva (Tim Barber) great guy
__________________
2004.5 3500 srw "yard ornament" 67,000 miles 1995 mazda B2300 beater 288,000 miles |
#4 |
I just put F1's (100 hp) in my 03. I don't know how they compare on price but I sure like the way they run.
Topper
__________________
06 dually Bored 40 over Issopro egt,boost & trans temp Zilla FP & RP Single shot of Nitros Smarty TNT Hamilton big stick #110 lb springs II PS62/S474 twins FASS 2 mic ff Arson III DDP 90's fluid dampener ARPs (625) EEP pressure by pass Generation 2 1 micron oil bypass filter Full Goerend built trans w/converter BD flex plate Leveled 35s AFE Blade Runner Intake S&B cold air intake Magnaflow 5' SS dual exhaust. Firestone R R RBP Grille |
#5 |
I have found ddp 50's for 765.00
and ddp 90's for 850.00.
__________________
07 2500 4x4 g-56 Mods----- smarty,southbend sprung hub 3250, afe stge II, Dr. Performance stge III, 5" flo-pro... Coming----- II Phat Shaft, aux lift pump, some mild stix |
#6 |
II dragonflows.
__________________
Billy 2004.5 Quad 4x4 Atlantic Pearl Blue II Dragonflows Prostreet 66/71/13 Wicked's Dragonslayer Garmon tranny ProLoc T/C Smarty 652 hp/1254 tq=11.91/111.59-1/4 |
#7 |
DDP's are awesome.. You can also deal with them directly.. You don't have to use a middle man.. If you decide you need more fuel in the future, they will hook you up..
__________________
06 Dodge 2500 standard cab shortbed 2wd. 131.7 quarter, 104.7 eighth on street tires. 23 mpg at 78mph. Kodiak 4500 efi, 22.5's, 07 tahoe headlights, custom paint 94 Dodge 2500 4x4 HTS/SC trans, etc 69 Camaro with 06 LBZ built by Fleece Performance |
#8 |
F1 will test and inspect your injectors so if you had a bad injector they will fix it.
__________________
2004.5 2500 White QuadCab DTT,HTT 62/SS, F1.2s, Smarty, MP-8,Air Dog 150, II's Cp3 mod, SAC Member #3 |
#9 |
Go with Don M, nothing but the best. You don't want to drop a seat or blow a tip off.
__________________
""Chain Reaction" 2005 Patriot Blue Dodge Cummins Edge Juice Edge EZ Smarty Revo/R F1 Flux 2's F1 Sporstman Springs Scheid Street Cam Fly Cut Pistons Arp Studs AirDog fuel system Afe Intake SPS 66 Ipricol gauges with Quad RP gauge Haisley Steet Puller clutch Floor it Stage 3 Cp3 on the way![/ (Ad removed signature violation) |
| Display Modes | |
