Go Back   Dodge Diesel - Diesel Truck Resource Forums > General > General Diesel Discussion > Cummins Conversions
Register FAQ DTR Store Members List Mark Forums Read
Thread Tools Display Modes
Old 04-02-2009, 09:16 PM   #16
JLee
JLee's Avatar
I Just got back to having some free time and checked up on this post. I was hoping to see you had every thing going. I thought I would offer a little bit of input on the length of all that under your truck. I have had some time to drive mine a little more, that drive line is short on mine and I think I am already on my way to having u Joint issues.The 1350 off the back of the gear vendors will get hot some times not real hot but noticeable. I cheated the angle on the motor all the way back to give me just a little more of a angle on the drive line but I still may be a bit steep, If I am it is not by much just throwing that out there good luck
__________________
04 CTD retired Welding truck 60 horse extrude hone injectors afe cold air intake
83 chevy k20 with 93 cummins 160 horse 5 speed gear vendor
05 CTD Welding truck auto tone wheel mod no kitty afe cold air intake
74 jeep cj7 258 6cyl spark plugs are a pain in the butt, time to measure out a 3.9
JLee is offline   Reply With Quote
Old 05-26-2009, 02:41 AM   #17
PapeCAT
PapeCAT's Avatar
Send a message via AIM to PapeCAT Send a message via Yahoo to PapeCAT
Hi Jlee,
I actually was able to do some work on the crew cab today. I am still considering the triple OD. The problem I was facing was that the GV yoke was about 1-2" BELOW the input of the brownie, and the spacing is very short.
However, doing some measurements today on the 1990 W250 (drivetrain donor) I noticed that the crew cab frame is about 2" taller/deeper than the W250 frame, setting the xmember lower... Which could explain why the whole asy / engine seems like it is a little tipped back. I am going to ask around but I think I'm going to have to embark unto the booty fab for the first time with a custom xmember. I could possibly use some sort of a spacer on top of the existing member and fab up the braces that mate up to it and the top of the frame. We shall see.
Not to worry though, the problem mainly was that I couldn't get any weekends freed up to go up the hill and work on the thing, but I'm in the process of moving the whole project to my shop in my backyard at my new house. This will allow the progress to move faster!
Thank you for everyone who has been following the thread. I will aim to make the thread more interesting with pics and updates. I can also take pics and answer any questions you may have about a crew cab swap or OD units and the brownie box.
One thing I need to do is order a new drain plug from GV...
__________________
1989 D250 GETRAG/3.07
1972 W200 Crew Cab Adventurer Cummins/HE351CW Non IC/Getrag/Brownie D60F/D70 4:10 on 37" HMMWV tires
1993 W250 Power Ram LE Getrag/3.54
PapeCAT is offline   Reply With Quote
Old 08-09-2009, 12:26 AM   #18
JLee
JLee's Avatar
had any luck on your triple od papecat? I am dying to know how it drives hope you are having some good luck
Old 08-13-2009, 04:55 AM   #19
PapeCAT
PapeCAT's Avatar
Jlee unfortunately I abandoned ship. I found and bought a 1993 W250 that set me back and I had it all for sale for a good while, ended up parting the entire W250 donor GV and all other drivetrain parts...
simplicity's sake and cuz no one wanted to take over my project, I gave it another stab and I've got a 1991.0 Cummins and 727 in there now, the cool thing is is that it mounts in the stock smallblock/727 location with stock crossmembers! This means no changes and I can keep the brownie shift setup how it is... I've got it all bolted in now and am going to get it on the road soon... the 727 and 4:10s aren't going to run out too well on their own but the brownie will help, and I've got 5 37" hmmwv military tires mounted up to the 16.5 alloys that came on teh truck...
I scored a '76 adventurer D100 that had 60K original miles and the sheetmetal is amazing! Short bed, front clip and doors are going on the crew.. I'll get pics tomorrow.
The triple OD would've been cool but way overkill and the parasitic drag would've been a killer... Still would've been interesting keeping track of all the different gear selections...
Old 08-15-2009, 08:56 PM   #20
JLee
JLee's Avatar
Sounds like you have been busy that 727 setup sounds intresting. That help keep your forearms from looking like popeye's! Hope it works well
Old 08-20-2009, 04:07 AM   #21
PapeCAT
PapeCAT's Avatar
The latest is the cummins is in the truck... need to replace a rear cab mount and config pwr steering, brakes, and fuel...
Rebuilt the whole front end with 1992 pieces... front and engine xmembers, front spring eyelets... (beefier than the 1972 ones that were CRACKED)
Added a 6th leaf to the stock military wrap packs on there.. looks slightly positive with all drivetrain installed...
Engine starts and runs though, good to go.
Green truck is front clip, doors and bed donor! ADventurer trim too!!!
Old 08-21-2009, 09:37 PM   #22
cLAYH
Aww man! You're not really going to break up that '76 are you? Its a clean looking truck!
__________________
2003 3500, dually, SO, 6spd, full load, SBC, Edge Hot Juice,AFE intake, BD exhaust.
Dad's truck now:
2001.5 3500 auto, 4x4, extended cab, loaded Sport, BHAF w/shroud, Juice w/Attitude, RV275 nozzles, DTT Torque Converter and Valve body, WG turnbuckled(32psi), Holly Blue pushing into stock pump(14psi @ WOT), DSS steering system, CIPA towing mirrors
cLAYH is offline   Reply With Quote
Old 09-14-2009, 12:20 PM   #23
PapeCAT
PapeCAT's Avatar
Yes it is a clean truck! It needs a pinion bearing in the rear axle though. And it needed to still be smogged in CA...
The 1976 bed, and front clip is going on the crew.
Everyone loves that clean little 1976 D100 Truck, not sure why haha...
The drivetrain will serve someone good as well, with a clean low miles engine and trans like that.
Old 09-14-2009, 12:55 PM   #24
cLAYH
I had a '73 Club Cab Short Box 4X4 in that same green with that same grill.
<sigh>
Old 09-14-2009, 03:25 PM   #25
PapeCAT
PapeCAT's Avatar
with the waffle grille? Or the quad kidney style grill laying on the grass?
Old 09-28-2009, 09:20 PM   #26
PapeCAT
PapeCAT's Avatar
Truck is sorta getting done... drove it yesterday and today... Not a resto, just an engine transplant, really.
Old 10-03-2009, 11:02 PM   #27
PapeCAT
PapeCAT's Avatar
drove the truck a couple hundred miles today in the mountains to loon lake, it ran out great. In OD on the brownie with 4:10 and 37" hmmvw tires the speedo was reading 25 mph slow!!! wow... I think I need to get an alignment, it twitches and jerks when turning left... otherwise I was able to cruise at 70 all day long.. earplugs a must for long rides though at this point. I need to trim the fenders a bit more as well... flexed it out a bit much today and found that one out quick lol. pics and vids were taken if anyone is intersted.
Old 10-04-2009, 08:44 AM   #28
JP-4.5
JP-4.5's Avatar
Is that really how the mirrors mount? Looks crazy? I have never noticed them like that but will be looking around to see a older Dodge to compare with? My 2004.5 is the 1st Dodge truck for me so the older ones I know nothing about.
__________________
2004.5 SRW 2500 Graphite 4x4 SLT CTD QCLB 48RE 3.73LS, Autometer guages, Nasta Stainless Steps, Bridgstone R250, Flares, Rickson 19.5, Banks Air w/SuperScoop, Rancho 9000s, Diamondback powdercoated black, TST R49, Smarty, GDP 392 Perf. w/2 micron kit, Silverline 5" , Kilby tray/grill guard , Billet DTT , II Silver62, SolidAxle free-spin hubs
JP-4.5 is offline   Reply With Quote
Old 10-04-2009, 12:34 PM   #29
PapeCAT
PapeCAT's Avatar
nah, they are installed incorrectly (intentionally) by the PO. They're designed to come straight out and the bar that the mirror sits on is supposed to be perpendicular to the ground. (huge towing mirrors) I don't know how they figured it out to install them this way but I have a pair of doors, front clip and bed from my 1976 adventurer that will be going on there soon.
Old 11-16-2009, 12:02 PM   #30
perkins
perkins's Avatar
I had a 5831 spicer in my 75 Ford with a MT40 allison 6speed none OD the spicer rob's some power and never wouldn't stop leakingfor very long after putting new bearings and seals.A old mecanic that worked on these when they came out said the 5831 were very bad for leaking.I had a small air ram for shifting from Dir,to Od.and it was noisy also.
your truck look great doing a nice job.good luck with you build.
Dale
__________________
1972 C10 chevy 5.9 cummins 5sp
1975 Ford 6.0 Perkins 6cyl.Twins,10sp
2007 Dodge 2 WD pulling truck
perkins is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.7
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2003, DieselTruckResource.Com
