hard start after fuel gel
Old 04-14-2014, 10:58 PM
lensguy's Avatar
Need some opinions, truck has always been an easy starter. Ve rebuild about 90,000 miles ago, new lift pump about 50,000 miles ago. Fuel pin up to just short of run away dead. Added ic last fall. Had Fuel gel at -24 about 6 weeks ago. Got truck into heated garage, replaced filter started with 2 brief bursts of either. Since then starts ok If tank full to 3/4 full ( needs slight depression of pedal which it did not need before) 1/2 to 3/4 tank needs pedal half way down and several seconds of cranking. Under 1/2 tank hold pedal to floor lots of cranking and very stubborn start. Run fine once started. Also complete rebuild of tranny including tv cable late summer. What would you look at first?
Old 04-15-2014, 12:52 AM
simplysmn's Avatar
sucking air just a Little maybe ? it should fire with the Tap of Key .And Stay Away from Either use WD40 it's safer
Old 04-15-2014, 08:37 AM
lensguy's Avatar
Question
Thanks for the response, that would make sense and have considered it, but from where that would be affected by Fuel level? Fuel line to tank seal? More fuel less abilty to suck air?
Old 04-15-2014, 10:50 AM
cougar's Avatar
Fuel jelling can do a lot of weird and unexpected damage. Been there. From what you describe I'd suspect the lift pump is roached. The lower the fuel level, the more effort requires to move the fuel from the tank to the injection pump.
Old 04-15-2014, 01:50 PM
lensguy's Avatar
Thanks cougar i had thought about the lift pump but had dismissed that because of how new it is compared to the injection pump. If you are correct i am causing un needed wear on a $1,000 part for want of a $100 part.
Old 04-15-2014, 02:41 PM
cougar's Avatar
A mechanical gauge screwed into the fuel filter bleeder screw hole can tell you pretty quick.
Old 04-15-2014, 03:56 PM
lensguy's Avatar
Now that is a most excellent idea.
65pacecar
01-31-2011 10:27 AM
neeco123
01-30-2008 10:18 PM
azmusclecar
11-05-2007 01:58 PM
B-MAN
09-02-2007 09:44 AM
Mud Ready
04-04-2007 01:24 AM
Quick Reply: hard start after fuel gel
