Go Back   Dodge Diesel - Diesel Truck Resource Forums > 4th Generation Ram - 2010 and Up > 4th Gen High Performance and Accessories 2010 and Up
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 09-19-2011, 02:50 PM   #1
stidwell
stidwell's Avatar
H & S Tuner Purchase
I am looking at purchasing a DPF delete kit with an H & S tuner from Alligator Performance.
They have been very helpful with any quesitons I have had.
Now I have a few questions for those of you that have installed these types of systems before.
1) Once I install the Delete pipe for the DPF, what do I do with the sensors?, the pipe i'm getting comes with no bungs.
2) What level are you running the program on?
the have told me that i have a choice from 0, 40, 80, 175 HP.... I don't want anything crazy, and i want to play it safe... its my daily driver....
I tow on a regular basis, although i may not max out the rating on the truck, i don't want to risk getting the EGTs too high.
My main reason for doing this is to get better mileage, I don't know how much longer I can afford to get 13 mpg...
Any information or help will be greatly appreciated.
Thank you
__________________
2010 6.7L CTD, 2500 SLT, MegaCab, 4x4, Auto Tranny,4.10 Anti-Slip, Rugged Brown Pearl.
H&S Mini Maxx, Flo-Pro CAT and DPF Delete Pipes,
2006 Bannens 16' Gooseneck Stock Trailer
2000 Jayco 243RKS 5th wheel w/ GN Adapter.
DTR MegaCab Club Member #339
stidwell is offline   Reply With Quote
Old 09-19-2011, 02:56 PM   #2
cbrahs
cbrahs's Avatar
Location: misplaced Idahoan stuck in Albuquerque, Roughneckin on RIG 41
leave the sensors in the factory exhaust and route the harness (body side) away from any exhaust.
tow in level 1
SIDE NOTE: I am going to be in El Paso this saturday. lets gather the wagons and have lunch at Rudy's
__________________
2011 3500 CC LB Laramie (now a dually), 19.5" visions w/ 245x70x19.5 toyo's, S&B CAI, weathertech, Ravelco, cabin filter mod, 120 gal aux tank w/FASS 150 xfer pump, B&W, T-Rex steering brace, Pro Tech, mag-hytec's
My Marine son protects your honor student
Disabled Combat Rescue USAF Vet.
September 2010 TOM Winner! (with the bucket)
SAC Member #1
cbrahs is offline   Reply With Quote
Old 09-19-2011, 05:44 PM   #3
stidwell
stidwell's Avatar
Another Question!!!
Just how much is removed with the EGR delete...
I want to be able to return it to stock if i have problems...
Should I just do an EGR block off instead?
Will a block off kit allow a pyrometer installation as easily as the delete kit?
Old 09-19-2011, 05:49 PM   #4
cbrahs
cbrahs's Avatar
i have everything to return to stock if I had to. Don't throw ANYTHING away. the v-band clamps for the front cross over tube are $96 ea at the dealer! if you leave EGR stuff there and just unplug it, you will have to drill the exh manifold to get EGT probe.
Old 09-19-2011, 07:02 PM   #5
SOhappy
SOhappy's Avatar
Quote:
Originally Posted by cbrahs View Post
i.. if you leave EGR stuff there and just unplug it, .
Sorry to jump in here, I'm in the same boat as the original poster. It's my understanding that you want to leave the EGR plugged in- or you lose 50hp, or is that an old wives' tale? Doesn't the H&S keep the EGR closed?
Also, a note to the original poster- I found the sticky at the top of the page on this subject to be of great help.
__________________
2011 Ram 2500 SLT 6.7 Auto Crew Short bed 4x4, airbags, leveling kit, BW hidden ball hitch, Hankook 285/70s
2005 Sandpiper Sport and various toys to haul in it
SOhappy is offline   Reply With Quote
Old 09-19-2011, 07:03 PM   #6
cbrahs
cbrahs's Avatar
that is on an untuned (OEM programming) truck. if you do the deletes (Smarty or H&S), the EGR system is removed and sitting on the shelf
Old 09-20-2011, 09:19 AM   #7
Mike Holmen
The Guru
Mike Holmen's Avatar
H&S has dpf installed and race only tunes. No sure about the dpf tunes, I still have my egr and egr cooler installed/throttle butterfly valve. The second cat and dpf are still brand new in storage. Been that way for nearly 2 years. I run my tuner on mild and I typically get around 18-20mpg. I have 50000miles on mine now, its been deleted from day one.
__________________
-white 02 sport QC, SB, 3/4 4X4 SDX 7X10's 300 bar, Stock HX-35 water/meth
-black 2010 3500 Laramie CCSB, H&S Blackmaxx/overdrive, passenger airhorn, home made 4in exhaust
Mike Holmen is offline   Reply With Quote
Old 09-20-2011, 11:16 AM   #8
stidwell
stidwell's Avatar
Thanks for all the help. How many parts are involved in the EGR delete.
Im being lazy about returning it to stock if the need is there...
I'm hoping to get at least 17mpg with the upgrades.
When you say "mild", I assume that you are refering to the 40HP setting. Am I correct?
Old 09-20-2011, 11:29 AM   #9
cbrahs
cbrahs's Avatar
if you want to see one in person, i will be there in El Paso on saturday and you can check mine out if ya wanna. Going to get ahold of Rockcrawler304 and see if he wants to meet up for lunch at Rudys on the west side of town. more than welcome to join
Old 09-20-2011, 11:38 AM   #10
stidwell
stidwell's Avatar
Thanks for the Invite. I am going to be busy working at the county coliseum this weekend. if i get a chnce i might run over there.
Old 09-20-2011, 11:41 AM   #11
cbrahs
cbrahs's Avatar
right on.
Old 09-20-2011, 02:48 PM   #12
Mike Holmen
The Guru
Depends on which tune your running. Some have more power than others. I would guess 40-50rwhp, I dynoed 330rwhp on mine, but that was with 6.8.11 tune. You also gain 1-2mpg with the mild tune vs stock.
Old 09-20-2011, 04:27 PM   #13
stidwell
stidwell's Avatar
When talk with the techie, he told me that i would bet better mileage with the middle tune (80hp) than i would with the mild.
I don't completely understand how.
Currently getting 13 mpg, with the DPF delete, I am hoping to get around 17 to 18.
I am also going to do the EGR/Cooler delete.
Old 09-20-2011, 04:34 PM   #14
cbrahs
cbrahs's Avatar
higher hp tunes that are driven lightly to get max mileage gets better mileage than the lower hp tunes driven the same way.
Old 09-20-2011, 04:41 PM   #15
Mike Holmen
The Guru
The timing is more advanced on the higher power tunes, and you get more duration event on the injector cycle. Just another advantage of running H&S over stock. As for why, EPA restricts how much tail pipe emissions.
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
