Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > Performance and Accessories 2nd gen only
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 01-20-2007, 10:16 PM   #1
Dodge12vKing
Dodge12vKing's Avatar
GSk question
Alright so I plan on getting the 3K GSK, and heres my question.
Will getting that make it continue to blow smoke through 3200 RPM's or wherever it defuels? Because mine will blow quite a bit now, but it just quits so soon.
__________________
98' 12v, 5spd, quad, shortbed dually conversion,4" MBRP straight exhaust, 235/85 Firestone Transforce A/T, #10 Plate, 3K GSK, Quadzilla Air Filter(sucks), Autometer Pyro/Boost Gauges, Starwheel all the way, Silencer gone.
Next: Clutch
Dads- 99' 3500, Edge Comp Box, AFE Stage 1 Air Intake, 4" Turbo Back straight Exhaust, Autometer Pyro, FASS Fuel System
Dads Other - 04' CTD Regular Cab, 4x4, stock. Work truck.
Dodge12vKing is offline   Reply With Quote
Old 01-21-2007, 03:52 PM   #2
mysterync
mysterync's Avatar
Yes it will make it fuel the whole time! Much more driveable, If your getting those springs might as well get 4k
__________________
01 2500 Ram
Factory ........ Mach 8+'s.........Maybe a "Little" Juice
The Videos
mysterync is offline   Reply With Quote
Old 01-21-2007, 05:53 PM   #3
NHRedneck
NHRedneck's Avatar
if you go for the 4k kit make sure to get your valve springs upgraded too as the stockers wont hold up to 4k......
__________________
97 12v 4x4 Reg Cab, Fresh paint, Suncoast billet trans, fire rings w/ ARP's, BHAF and torque tube, ISSPRO gauges, AFC gutted, 10 plate, 5" turbo back, lockup switch, synthetic fluids, 250K club
NHRedneck is offline   Reply With Quote
Old 01-21-2007, 05:57 PM   #4
mysterync
mysterync's Avatar
I ran stockers for a while! its recomended if you run way up there alot!
Old 01-21-2007, 07:01 PM   #5
Fueling around
It will probably blow more smoke as it goes higher in rpm. The stock turbo cannot pump enough air to keep up. You also need more pump timing due to injection lag.
__________________
John
1997 CTD RAM, red, auto, stock
except for select maintenance items such as Goerend trans, VB & triple TC
Fueling around is offline   Reply With Quote
Old 01-21-2007, 07:04 PM   #6
TxDiesel007
TxDiesel007's Avatar
Judgin from your mods
the 3K will fuel hard to about 3200 RPMS, the 10 plate helps alot, and as stated, your 35 will be inefficient and will produce more than 35 psi..
Far as valve springs go, im runnin stockers still and they are holdin up ok, but i dont rev very often past 3200 rpms...
Rick
__________________
05 3500, smarty, intake, exhaust, full replacements, full hitches, muds, steps, 110 gallon auxillary, R&K toolbox
95 5 spd 4x4
HUGE thanks to Gomer
(Ad removed signature violation)
TxDiesel007 is offline   Reply With Quote
Old 01-21-2007, 09:27 PM   #7
Dodge12vKing
Rick
Well I guess that sucks about the Boost gauge, but anyway. I better be getting myself a clutch before I get myself a GSK.
Old 01-21-2007, 11:35 PM   #8
TxDiesel007
Good thought
cheap insurance, cause from experience, the GSK is a night and day difference over stock springs, once u get it tuned just right...
weeeeeee!!!!!!!
Rick
Old 01-22-2007, 11:58 AM   #9
Dodge12vKing
Good thought
weeeeeee!!!!!!!
Rick
Sounds good. I can never give any of these little ricers that pull up beside me my full power, because my Clutch.
I wonder how much HP and Torque I'm putting up? I really want to get on a dyno.
Old 01-22-2007, 05:32 PM   #10
TxDiesel007
ill give u a hint
100 plate 2/3 forward, 16.5 degree timing, 4K GSK, full AFC and starwheel, with 370 injectors netted me 350 horses, take about 30-50 for a clutch that got destroyed halfway thru the dyno...
Id say with a good clutch, some timing, since i see you need it and a GSK, ud be in the 325-350 range... on stock DV's, some people have broken 400 with a stock turbo, stock 215s and big DV's, Satburn was one of those taht did it..
Rick
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
