It means "get a Cummins, Get a Cummins"!!!!!!!
__________________
2002 4X4 2500 Atlantic blue Auto and 3.54 LS Kodiak steps. Smarty, TST PM 3 Mach 2 HP injectors, hx35/12 over a s-400 3 piece manifold , AFE, 4" exhaust and many DTT parts. |
thats been my experience too. I drive a 07 duramax repo truck. Works great, with less weight. If I have to pull a big truck or repo an rv it really really notices the weight. My cummins ofcourse likes being hooked to the heavy stuff.
Seems like once it goes over about 10000 lbs.....is the time for a different truck.
__________________
98 12 valve,Twin turbo& triple intercooled, hx 40 (19 cm )/ht3b(26cm) 4x4,quad cab,DRW,NV5600 conversion,velvet ride shackles,KDP fixed,.020 over marines, ported head, helix 2 cam, lots of coatings, quick spool valves, ats ported and coated manifold, total seal rings,DDP4's,4000gsk, 5 dp to 4 inch home made exhaust with us gear exhuast brake, bhaf, alcoas,gauges.60 lb valve springs, southbend, magtec. |
I think the reason he was in the left (hammer) lane was so that he could not draft the dodge and give the chev any advantage.
Do I agree with people being in the left lane? No. To prove a point on video? You bet, especially if its to get a manufacturer to correct a known issue. That's just like the Chevy issues up here when they went to rear disk brakes on the their trucks. If you drove them on gravel roads, it would chew up the calipers and disks. Chevy's solution was "do not drive your 4 wheel drive trucks on gravel roads". Good video and interesting that there was NO smoke coming out of that dodge at all.
__________________
2007.5, 2500, QC, Laramie, 4X4, SB, 68RFE, 3.73, Inferno red, MaxBrake, Edge Insight w/pyro, Firestone Ride-Rite, EZ Change Drain plug, S&B drop in air filter, 250 watt oil pan heater, EGR unplugged. 2008 YZ450FX, matching 756's, Marcel Fournier ice tires, billet fuel screw, DiD narrow x-ring chain, Ironman sprockets, Scotts SS oil filter, Dr. D pipe coming, love the SSS suspension... |
| Thread Tools | |
| Display Modes | |
