Go Back   Dodge Diesel - Diesel Truck Resource Forums > Specialty Forums > Towing and Hauling / RV
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 01-20-2005, 11:55 AM   #1
hobbyman
Gooseneck without a goose?
Anybody ever tow an empty goosneck trailer using a pumper bull hitch? I purchased a gooseneck, but I'm planning to convert it to 5th wheel (it's only a 10K trailer, and I already have the 5th wheel hitch). Thanks!
__________________
2003,HO CTD,6 spd,3.73,4X4,4dr,LWB
hobbyman is offline   Reply With Quote
Old 01-20-2005, 02:14 PM   #2
Mechanos
They make a Kingpin Gooseneck Coupler to do just what you're talking about. Look on page 3 here.
__________________
'01 2500, Quad Cab, Sport, 4x4, ETC, DTT 47RE, 3.54's, Fuel Boss, B&W, Isspro FP/Pyro/Boost/Trans, Smarty, turnbuckle, BHAF, 4" straight-piped, power/heated MOPAR tow mirrors
Mechanos is offline   Reply With Quote
Old 01-20-2005, 02:25 PM   #3
hobbyman
Thanks Mechanos - that is what I'm planning to do, although I didn't realize they made a tube / pin set-up like that (I was going to cut and weld).
I still need to get the trailer home first. I think I can just flip over my ball hitch mount so it's up has high as possible, and put a 2-5/16" ball on, then hook up the gooseneck to my bumper hitch. Does that sound right? Thanks again!
Old 01-20-2005, 02:29 PM   #4
cditrani
Assuming you can get the correct ball with the correct shank size for your ball mount, I say it sounds reasonable. Assuming also an empty trailer and that you can get it reasonably level.
__________________
Sold: '02 2500 HO QC 8' 2WD, FASS, Dana Powr-Lok, Smarty #5, BlueChip VP44.
Waiting with bated breath for a 1/2-ton diesel pickup, and passing the time in Jeep Rubicon.
cditrani is offline   Reply With Quote
Old 01-20-2005, 02:48 PM   #5
tool
You'd have to have a pretty serious lift on your ball hitch or trailer would be badly running downhill and the front would probably hit your tailgate depending on the design of the trailer and if there is any deck over the gooseneck.
I can almost garuntee that the pinweight of the goosenheck would be far too heavy for the rating of bumper style hitch. Depending on the size and the weight of the trailer. When you factor in the weight of the trailer plus the leverage of a major rise in the ball hitch. What is the tongue weight rating of your hitch? Most 7500 lb hitches are rated for only 750 lbs tongue weight.
Might be better to get a friend with a real gooseneck hitch to pull it home for you and then do your conversion.
__________________
'06 2500 Mega Cab, New Feb '07, 4x4 SLT loaded, 6 speed, Sun Roof, all the goodies, B&W Gooseneck hitch, Prodigy Controller,Stock so far. 160,000 Miles
Towing 2009 Sooner Ranch SR724 Stock trailer
Sold: '99 2500 Quad Cab 4x4 5spd. 24V CTD Short-box, Sport, Loaded, 30,000 # Draw-Tite Gooseneck hitch, stainless flares and grill insert, silencer ring gone, straight pipe with 6" tip. BHAF, Van Aaken Smartbox.
250,000 miles
DTR Mega Cab Club member #9
tool is offline   Reply With Quote
Old 01-20-2005, 03:43 PM   #6
Mechanos
Yeah, rather than cutting and welding, I would look into the coupler pin thingy. If you cut the coupler up and weld a kingpin setup on it, you severely limit it's resale potential. You'd have to find someone else that wanted a gooseneck trailer but wanted to pull it with a 5th wheel hitch. If you use the coupler, all you have to do is slide the kingpin adapter out and slide the gooseneck coupler back in when it comes time to sell it.
Old 01-20-2005, 03:51 PM   #7
hobbyman
Tool - good points! I'm going to check into it a little - weight limits and weight of the trailer, height of hitch, etc. Might not be such a good idea. Maybe I can arrange to get an adapter in advance - going to need it anyway.
Thanks again!
Old 01-20-2005, 07:01 PM   #8
charger 69
charger 69's Avatar
With my gooseneck trailer the front of the body would hit the ground before the hitch would connect with the ball.
__________________
White 92 ctd D350 dually 161,000 mi.automatic with a 26K add on cooler, aluminum wheels,second fuel tank, gooseneck hitch, air bags,tach.and gages. drilled air box,power screw turned in 3-4 turns, Hughes Torque Converter,Cummins flexplate, 16 cm. turbo housing. Real brakes no anti-lock valve.
charger 69 is offline   Reply With Quote
Old 01-24-2005, 11:28 AM   #9
Hyspeed
I saw something that I didn't know existed the other day. It was an adapter for a for a gooseneck to bumper hitch. It looked like a "T" bar that hooked to the front of the trailer frame and the extended forward to the bumper hitch. There was a verticle post with a ball at the top that took the gooseneck on the trailer that was adjustable for and aft for the correct position. This bar extended out about 2' beyond the gooseneck to allow clearance.
Hyspeed is offline   Reply With Quote
Old 01-24-2005, 02:25 PM   #10
bulthisl
bulthisl's Avatar
It may be alright for moving an empty trailer.
But I would hesitate pulling a loaded trailer with that adapter.
The trailer itself would be enough tounge weight and then moving it back 2' would compound the prob.
: Eddie :
__________________
96 2500, Ext. Cab 4x4, 5 spd, Stock + a little more
bulthisl is offline   Reply With Quote
Old 01-25-2005, 03:48 PM   #11
Hyspeed
Quote:
Isn't that what he asked about doing?
Old 01-26-2005, 09:23 AM   #12
Patrick Campbell
Patrick Campbell's Avatar
How far are you going and how much does it weight? Sounds dangerous...
__________________
Shares the 04 Jetta TDI with wife - no more truck!
Patrick Campbell is offline   Reply With Quote
Old 01-27-2005, 12:40 PM   #13
tool
That just sounds scary to me.
You know there will be some monkey who will try and move a loaded trailer somewhere with one of those. Can you imagine the leverage with an additional 2 feet beyond a bumper style hitch? When many of those pumper hitches only have like a 500 lb tongue weight rating under normal circumstances???Think about it. 2 feet beyond the bumper hitch??? That puts the pin location like......... what? six feet beyond it's proper location in the bed?
yikes.
Old 01-28-2005, 01:38 AM   #14
zulusafari
zulusafari's Avatar
yikes.
True, but I have seen several fellows moving new stock trailers across country this way -- as trailer "trains." They have a bumper hitch on the back of one new trailer, and the adapter connects the second trailer. Worked pretty slick, but definitely not for anything loaded!! I was also pretty scared following one of these "trains" in the Missouri Ozarks! Talk about a swaying nightmare! I really don't think it is a safe way to transport trailers. If two need delivered, I feel a lowboy semi trailer would be much safer for us all.
__________________
Joshua
Current: 2010 3500 Crew Cab Dually Longbox 4x4 Auto, Light Graystone, Bighorn Edition
Traded: 2006 3500 SRW MegaCab 4x4 Mineral Gray Metallic
Member #266 DTR Megacab Club Join Here
Some people are like slinkies...not really good for anything, but seeing one tumble down the stairs makes you smile!
zulusafari is offline   Reply With Quote
Old 01-29-2005, 07:35 AM   #15
electrifried
I have a gooseneck ball mount that fits on a set of reece rails just collecting dust. I have pulled a gooseneck trailer with a upturned ball mount with success. The trailer was not loaded and no problem to pull or manuver. Taking your time will help a lot.
__________________
99 3500 4x4 6sp
2000 2500 4x4 DTT
Thanks to Jim Jessup for the xtra go power without any "add-ons"
2001 Crew Cab Duramax to get 4 full doors that I could afford
99 Suburban 6.5 4x4 To keep me appriciating the Cummins power enough to put up with the Dodge package. Makes a great grocery-getter.
electrifried is offline   Reply With Quote
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
