Getting to the shift tower
Old Aug 14, 2010 | 09:04 PM
ldornak's Avatar
I'm replacing my trans lube tomorrow in my NV5600. I plan on adding the 6th qrt through the top of the trans. Does anyone have detailed info to get the shift tower off? I've got the trim and the 4x4 shifter to worry about.
Old Aug 15, 2010 | 01:35 AM
DIESELWRKS's Avatar
when ever I change my fluid I use the top bolt hole on the pto cover to get in the extra bottle. to much hassle with the tower and making sure nothing falls in the trans. if you have a squeeze bottle with a tip that is what I use, takes a little longer but less hassle to me,
Old Aug 15, 2010 | 02:50 AM
Tate's Avatar
Its just a bunch of phillips screws that hold the boot and console on. The 4by shifter boot just snaps into the console, give it a good yank. The tower is held on by 4 bolts. Can't remember if they are cap screws, or socket head cap screws.
Old Aug 15, 2010 | 08:11 AM
Junk Man's Avatar
On many vehicles you can snake a clear plastic hose from above (ie engine compartment or fender well)into the fill hole. I haven't checked the Ram. Pull whichever fill plug you decide to use & buy hose to fit. Perhaps jam a funnel into the top end of the hose. Look up the capacity in the FSM & start there if you've drained it. This works for filling anything under the truck. Remember to pull the fill plug before the drain plug.
Old Aug 15, 2010 | 02:38 PM
DIESELWRKS's Avatar
yes I have done this and its still a slow process, my squeeze bottle I have isn't to slow. but then I do the 5600 I take a off both pto sides change the filter I have on the pto cover get in to the tranny with gloves and be amazed on the crap that is left in the bottom of the tranny. thanks for the tip.
Old Sep 6, 2010 | 03:23 PM
ldornak's Avatar
Tate, you were right. It was very easy to get to the shift tower. This is the 2nd time I've changed tranny fluid and from now on, I'll be filling through the shift tower. That was much easier than trying to fill with a squeeze bottle while laying on my back.
Dieselwrks, you were right about the amount of crap in the bottom of the tranny. Cleaned it all up and filled with Royal Purple. If the RP does not work out, I'll probably replace with Redline or Amsoil.
For those 1st timers trying to get to the shift tower, here's what I did.
1. Pull back the bottom of the shifter boot to gain access to the phillips screws.
2. After unscrewing the boot from the console, unscrew the shifter from the shift tower stub.
3. The 4by shifter boot just snaps into the console. Like Tate said, just pull up on the boot and it will pop out.
4. Unscrew all the cap screws that attach the console. You will need to remove the rubber pieces in the cup holders to gain access to 2 screws and there's also screws under the 4by shift boot.
5. Once the console is loose, snake the 4by shift boot through and remove the console.
6. There's another boot covering the shift tower. Remove the cap screws and slide the boot off of the shift tower.
7. Remove the 4 bolts holding down the shift tower and remove the shift tower.
8. Fill the tranny and re-assemble.
Fisherguy
Nov 14, 2008 07:34 PM
pete97
Jan 8, 2007 09:05 PM
CATCRACKER2
Oct 11, 2006 07:06 AM
Dieselcamper
Jul 13, 2006 10:36 PM
shoffs30
Jan 27, 2006 03:37 PM
